  4. Make locking the screen easier
23 Posts 8 Posters 3.2k Views 4 Watching
  • Rob Kelleyundefined Offline
    Rob Kelley
    Hi
    When riding and it starts to rain I need to lock the Next/Nav screen but this is too fiddly whilst riding.
    Can a padlock be added to the nav screen which will take a simple tap to lock the screen and have it as an optional feature under the settings so it can be removed when not wanted?
    Thanks
    GSA1250
    HD Street Glide
    HD Sport Glide
    XT500 x 2
    • Rob Kelleyundefined Rob Kelley
      Hi
      Thanks
      @Rob-Kelley Itโ€™s only two taps to do this now.
      First tap to open navigation menu, second tap to lock the screen.
      Rob Kelleyundefined 1 Reply Last reply
        @Rob-Kelley yeah, sorry. Won't dedicate a permanent on screen button for this ๐Ÿ˜‰
          Rob Kelley
          @Nick-Carthew I know how to it but when I'm wearing thick gloves and doing 70 on a motorway in the rain and snow (yesterday going to the NEC) it's dangerous to try and do this.
          Not everyone has a large screen and remote control, I'm using an iPhone and the text is small and almost impossible to select with big gloves on.
          GSA1250
          HD Street Glide
          HD Sport Glide
          XT500 x 2
            @Rob-Kelley Screen space is valuable, so as Corjan has said none will be used for a lock button.
            You could always set the lock before you leave, especially if you expect to see some of the wet stuff.
            • richtea999undefined Offline
              Maybe a double-tap on a non-map area of the screen?
              Like the directions area, top left, which is an easy area to aim for during a ride/drive.
              A nice bright confirmation popup saying 'Locked' could let the user know the double-tap has worked.
              It would also be wise to add a new Setting option to actively enable it just in case innocent new users starting double-tapping randomly, and lock the app.
                Rob Kelley
                wrote on last edited by Rob Kelley
                @Nick-Carthew Ref screen space, it depends on the device being used and as I suggested to have this as an optional object so it can be hidden or shown in the same way some of the other objects are such as Current Road, etc.
                Currently it takes 3 taps on my iPhone 14 Pro:
                1: Tap the 3 dot menu button which is often hidden so hope I'm tapping in the right place,
                2: Scroll down the menu,
                3: Tap Lock Screen (2nd from the bottom).
                This then places a padlock on the screen to be able to unlock it, why not keep this padlock on the screen when it's unlocked and simply tap it to lock/unlock? it doesn't use much space.
                Considering UK law on phone use I really feel having to take eyes off the road for the amount of time to do this is not good and risks a heafty 6 points and fine, yes this will still be the case for one tap but much less likely to be caught as it'll only take a second to do.
                GSA1250
                HD Street Glide
                HD Sport Glide
                XT500 x 2
                  @Rob-Kelley The developer of the app has already stated that there'll be no on screen button for this.
                  If youโ€™re concerned about having your collar felt by the boys in blue,๐Ÿ‘ฎ lock your screen before leaving, or invest in some bar buttons.
                    Rob Kelley
                    @Nick-Carthew I'm sure he'll still be open to use case scenarios/persuasion as all good software devlopers are, or go with another idea as suggested by richtea999 above.
                    GSA1250
                    HD Street Glide
                    HD Sport Glide
                    XT500 x 2
                    Neil qundefined 1 Reply Last reply
                      Neil qundefined Offline
                      Neil q
                      @Rob-Kelley On Android there's an app called Touch Lock that overlays a lock button. Just tried it and it works with MRA. Maybe something similar for iPhone??
                      I tend to agree it would be a useful feature in MRA tho, DMD2 has it.
                      Google Pixel 7 Android 16
                      Samsung Active Tab 3 Android 13
                      Lenovo TBX606X Android 10
                      • Neil qundefined Neil q
                        Rob Kelley
                        @Neil-q
                        I've tried iOS Guided Access which kinda works but it's a bit fiddly to enable/disable by triple tapping the side button and it overlays a grey semi transparent box.
                        GSA1250
                        HD Street Glide
                        HD Sport Glide
                        XT500 x 2
                          @Neil-q
                          Rob Verhoeffundefined Offline
                          @Rob-Kelley Thereโ€™s a new feature on its way (now in test in beta). Just two little clicks to lock and only one click to unlock.
                          ๐Ÿ’ป Routelab on MacBook Air & iMac (Tahoe & Ventura)
                            Rob Kelley
                            @Rob-Verhoeff said in Make locking the screen easier:
                            good news, thanks for the update.
                            GSA1250
                            HD Street Glide
                            HD Sport Glide
                            XT500 x 2
                              It's already live in update 4.3.4 ๐Ÿ˜‰
                              The button has been moved up in the menu or long press the menu button itself (while navigating) to lock the screen.
                              Rob Kelleyundefined richtea999undefined 2 Replies Last reply
                                Rob Kelley
                                @Corjan-Meijerink said in Make locking the screen easier:
                                fantastic, just tested and it works.
                                Thanks
                                GSA1250
                                HD Street Glide
                                HD Sport Glide
                                XT500 x 2
                                • Bouke Entundefined Offline
                                  stupid question from me but how to onlock ?
                                    Rob Kelley
                                    @Bouke-Ent
                                    When locked a padlock icon will appear on the screen, tap that to unlock.
                                    GSA1250
                                    HD Street Glide
                                    HD Sport Glide
                                    XT500 x 2
                                      @Bouke-Ent
                                      @Rob-Kelley said in Make locking the screen easier:
                                      @Bouke-Ent
                                      thanks, hope it will not effect rain. ok but i will try next spring.
                                        @Corjan-Meijerink Excellent work, Corjan. Thank you.
                                        I knew you could make it happen. ๐Ÿ˜€
                                        • Lenny Oundefined Offline
                                          Lenny O
                                          Ok, just my 2 cents on this....
                                          I would love to be able to lock the screen with menu (3 dots) and all the other buttons above it not taking room on the screen. Is that too much to ask for? Maybe a tripple tap or whatever other means are there. There is not that much room on the phone screen to begin with.
                                          richtea999undefined
                                          Lenny Oundefined
                                          Lenny O
                                          Bouke Entundefined
                                          Rob Kelleyundefined
                                          Rob Kelley
                                          Neil qundefined
                                          Neil q
                                          • Routes laden zonder wifi / data verbinding
                                            Charles Rijken 0undefined
                                            Charles Rijken 0
                                          • Font for the distance to the next turn to smal
                                            richtea999undefined
                                          • Public Groups?
                                          • Audio Volume
                                          • Laden route gaat mis
                                            supergundefined
                                            Thomas Neumeyerundefined
                                            Thomas Neumeyer
                                            6.2k
                                          • Black screen during navigating
                                          • Favorites created in the webplaner are not syncronized with the NavApp
