  4. Skipping Waypoints....
11 Posts 8 Posters 664 Views 4 Watching
  • Simon qundefined Offline
    Simon q
    When skipping waypoints, it would be better to see what the waypoint is called rather than just a number.
    I rename most of my waypoints. It would be nice to also see what the name of the next approaching waypoint is rather than just a number.
    Rob Verhoeffundefined Herman Veldhuizenundefined Brian McGundefined 3 Replies Last reply
    • Simon qundefined Simon q
      Rob Verhoeffundefined Offline
      @Simon-q I don’t have that need at all. Shaping points are only meant to shape your route so that you follow exactly the path that’s needed. If I ever wanted to rename a route point, it would always be a via point and never a shaping point.
      Bikerlouundefined Con Hennekensundefined Simon qundefined 3 Replies Last reply
        Bikerlouundefined Offline
        Bikerlou
        wrote on last edited by Bikerlou
        @Rob-Verhoeff
        @Rob-Verhoeff
        I'm with Simon - I use via points more than shaping points as I find them a more reliable way to ensure I follow my chosen route, and I also use them to add notes/names, so that I know where I am! I would also find it very helpful to know the name of the 'via' point. (The terminology is always confusing - waypoints vs via points vs shaping
        points)
        • Bikerlouundefined Bikerlou
          @Rob-Verhoeff
          @Rob-Verhoeff
          points)
          @Bikerlou said in Skipping Waypoints....:
          points
          Confusing? What’s confusing about it then? The terms don’t seem open to multiple interpretations to me! A shaping point is used to shape your route, while a via point is a location you always want to visit along your route. What’s so difficult about that?
          Furthermore, I really don’t understand you guys (no offense!). Besides, the space for that box is too limited to display a full name as you want, I think. But anyway, different people, different preferences...
          white.mouseundefined Dae 0undefined 2 Replies Last reply
            points
            white.mouseundefined Offline
            @Rob-Verhoeff
            I do agree with Rob. The terminology is quite clear but not everyone has it in sharp focus. And as for skipping points; please let it remain numeric; Then it will continue to correspond to the numeric points as they appear on the map. And please let sit also remain numeric for clarity.
            Ik ben het wel met Rob eens. De terminologie is best duidelijk maar niet iedereen heeft deze scherp voor ogen.
            En voor wat betreft het skippen van punten; laat het a.u.b. numeriek blijven; Dan blijft het overeen komen met de numerieke punten zoals deze op de kaart staan. En laat sit ook graag numeriek blijven voor de overzichtelijkheid.
            met een R1250RT met TFT en BMW Connected Ride App; de Garmin Zumo XT en My Route App in combinatie met de Carpuride W702 (voor Android op de Motor!)
              @Rob-Verhoeff, I can think of many reasons why I would rename a shaping point (I often do). I see no reason why to limit some functionality to shaping points. In fact I think it is more work to limit something, than to generally make it available. The sole difference between shaping points and via points is their auto-skip behavior (and please keep it like that!) 😉
              @Simon-q, to be honest, I think your suggestion is a bit stretching the screen estate in the app. Often WP names are really long, and in by far most cases senseless addresses. So generically showing all waypoint names is not a good idea I think.
              Are you aware of the fact that, when a WP (Yes Rob, Shaping as well as via points! 😉 ) contains a note, the name and the note are displayed by a single tap on the waypoint?
              In my opinion your suggestion could lead to two (probably rather easy) improvements:
              A)
              This picture shows a single tap on a waypoint with a note (or a picture). On this info field a button "continue from this waypoint" could be added. More than enough space!
              B)
              This picture shows a long press on a waypoint. The information about the waypoint could be completed with the name and the note of this waypoint.
              Would that suffice in your view?
                @Simon-q I agree with you. One can always give a point the name of the number if one wants too. So the user decide. For example : Point 3 can have the name "3".
                  points
                  Dae 0undefined Offline
                  Dae 0
                  @Rob-Verhoeff said in Skipping Waypoints....:
                  points
                  I can see why some people get confused with terminology if they have used other apps in the past. Scenic uses the term “via” for what MRA calls a shaping point, and “stop” for what MRA calls “via”. Garmin themselves even used to have different terminology before they changed some years ago.
                  https://forums.garmin.com/apps-software/mac-windows-software/f/basecamp-windows/159083/pois-waypoints-via-points-shaping-points-101
                    Simon q
                    I never mentioned shaping points....just waypoints. Sometimes you don't need to visit them.
                      @Herman-Veldhuizen said in Skipping Waypoints....:
                      That does not work for dynamic numbering of waypoints... What if you add a WP in between others? Waypoints will always have a number to define the order.
                        Brian McGundefined Offline
                        I tend to agree with @Simon-q having the point name in any popup/notification would be a lot more informative than just a number.
                        Distinguishing between via & shaping points in this regard is IMO a nonsense, they are all points & should be treated the same, making a distinction just adds useless complexity.
                        What I also think would be useful & might make the numbers a bit more meaningful is if the option to "Show Next Waypoint Information" actually did what it says.
                        At present I believe this option only shows the point information when within a certain distance of the point.
                        If the point name was shown immediately after the previous point was passed, then the user would have time & maybe able to associate this point name with the number on the waypoint/skip button.
                        If the user selects to see the next point name show it to them, don't hide it with some hidden filter. IMO this is a poor design choice.
                        BlackView BV7100, Android 12, Offline mode with Offline Maps
                        Simon qundefined
                        Simon q
                        Dae 0undefined
                        Dae 0
                        Bikerlouundefined
                        Bikerlou
                        • 12 Tage in den Seealpen mit MRA und es war eher NICHT gut..
                          Martin Wilckeundefined
                          Martin Wilcke
                        • Ungewollte Abweichung von der Originalroute
                          Frank Schefflerundefined
                          Frank Scheffler
                        • Looking for a Route from Roermond to Ijmuiden, Netherlands?
                          steve 2kundefined
                          steve 2k
                        • Route en avance sur la position
                          LE DIZES Freddyundefined
                          LE DIZES Freddy
                        • Scenic routing & RouteXpert library improvements
                          Edwin_Mundefined
                          Edwin_M
                          2.2k
                        • Hoe kan ik verschillende gpx bestanden samenvoegen?
                        • android auto
                        • New beta! 4.4.0 (400)
                          CD130undefined
