  2. Camper Discussion
  3. Missing motorhomes in library selection tab
Scheduled Pinned Locked Moved Camper Discussion
24 Posts 7 Posters 15.5k Views 3 Watching
  • Inge Bakermans Inge Bakermans
    Dear MRA developers, in the library I am missing the possibility to select motorhomes in the 1st tab (riding, cycling, walking). Is it possible to add the possibility to select motorhomes to this tab?
    Would be hugely appreciated.
    @Inge-Bakermans which tab exactly? A screenshot would help a lot!
      Inge Bakermans 1 Reply Last reply
        @Inge-Bakermans The majority off. The routes are created in the profile. Car. Just a couple of routes die walking and cycling. As far as I know there are no routes made for mobile homes.
        My advise, take a route that you like change the profile to mobile home to get a route suitable for that purpose. Have fun
        Inge Bakermans
        Inge Bakermans
        Inge Bakermans
        @Marinus-van-Deudekom That is what I have been doing. Though would be nice to see motorhomes in the pop-up. Since riding refers to 2 wheels not four.
          Inge Bakermans
          Inge Bakermans
          Inge Bakermans
          @Marinus-van-Deudekom Spot on!
            @Inge-Bakermans RouteXpert routes are created using the car profile in transport mode. There is no point in having a motorhome profile in the search box because there are no routes specifically for motorhomes. You can save a RouteXpert route to your library and change the transport mode to motorhome to see if any changes are required.
              Inge Bakermans
              Inge Bakermans
              Inge Bakermans
              @Nick-Carthew That obviously is an option - however Iexpect more motorhome/ car routes to appear as time progesses. Since MRA is catering for rv's why not being able to select it.
              Marinus van Deudekom HABVEN aka MrMRA 2 Replies Last reply
                @Inge-Bakermans hoi Inge
                Zoals Nick al aangaf worden allen routes in de bibliotheek door de RouteXperts gemaakt in het profiel auto. Met andere woorden er worden geen routes (meer) gemaakt voor andere profielen. Daarom heeft het geen zin om een mobile home knop toe te voegen. Bovendien zou een knop zoals jij bedoelde niet kunnen gaan werken omdat je in het profiel mobile home nog veel verschillen zou kunnen hebben. Ze zijn immers niet allemaal gelijk qua afmetingen.
                De optie om een van onze mooie routes om te zetten naar jouw profiel lijkt daarom nog het beste
                Als je meer hulp nodig hebt, vraag het gerust.
                Hi Inge
                As Nick indicated, all routes in the library are made by the RouteXperts in the car profile. In other words, routes are not (anymore) created for other profiles. Therefore, it makes no sense to add a mobile home button. Moreover, a button like you meant could not work because you could still have many differences in the mobile home profile. After all, they are not all the same in terms of dimensions.
                The option to convert one of our beautiful routes to your profile therefore seems to be the best
                If you need more help, feel free to ask
                • Bert Mulder
                  Bert Mulder
                  Bert Mulder
                  Bij het tab blad "Route informatie" bij een route kun je de afmetingen van je voertuig opgeven. Iedere camper heeft immers andere afmetingen.
                    Hi Inge
                    Inge Bakermans
                    Inge Bakermans
                    Inge Bakermans
                    @Marinus-van-Deudekom Ah, dat wist ik niet dat er geen andere profiel routes meer werden aangemaakt, behalve dan het autoprofiel. Dat maakt het vinden van routes dan ene stuk makkelijker.
                    Qua afmetingen heb je gelijk - die heb ik meteen toen die mogelijkheid er was goed ingesteld.
                    • Bert Mulder Bert Mulder
                      Inge Bakermans
                      Inge Bakermans
                      Inge Bakermans
                      @Bert-Mulder Dat heb ik vanaf dag 1 gedaan.
                        @Inge-Bakermans veel van de routes zijn ook geschikt voor campers maar, het merendeel van de RouteXperts zijn motorrijders maar er zijn ook niet motorrijders onder ons. Kijk bv eens naar de routes die Jan Cabrio heeft gemaakt. Bij mijn eigen routes in Luxemburg zijn er ook een aantal goed te rijden met één camper. Have fun
                          Inge Bakermans
                          Inge Bakermans
                          Inge Bakermans
                          @Marinus-van-Deudekom Dank je wel Marinus - ga ik zeker doen.
                            @Inge-Bakermans
                            Er zijn ook (nog) geen RouteXperts die routes voor campers maken. En tot op dit moment wordt alleen het autoprofiel ondersteund in de RX Bibliotheek
                              @Inge-Bakermans
                              Inge Bakermans
                              Inge Bakermans
                              Inge Bakermans
                              @Hans-van-de-Ven-MR-MRA Dank je wel Hans. Jammer dat er nog geen RV-experts zijn.
                                @Inge-Bakermans misschien kun jij de eerste worden 😎
                                • MotoCon
                                  Ben ik heel erg cynisch als ik zeg dat campers niet bedoeld zijn om scenic routes te rijden? Dit vooral met het oog op het overig verkeer...
                                  HABVEN aka MrMRA Marinus van Deudekom Nick Carthew Inge Bakermans 4 Replies Last reply
                                    Zie deze route samenvatting: https://www.myrouteapp.com/nl/motor-en-auto-routes/pt/Vila-Real/8684527/Route-66-Portugal-01-Chaves-Penacova
                                      @Con-Hennekens ze doen er soms alleen wat langer over 🙂
                                        @Con-Hennekens said in Missing motorhomes in library selection tab:
                                        Large motorhomes are very noticeable on the NC500, a lot of the roads are single track and not suitable for these large vehicles. They also do not pay for accommodation and rarely eat in pubs and restaurants so they do not add much to the local economy. The NC500 was designed to boost the economy of the north of Scotland. There is a growing resentment towards motorhomes from the local population.
                                          Inge Bakermans
                                          Inge Bakermans
                                          Inge Bakermans
                                          @Con-Hennekens Wat mij betreft ben je dan erg cynisch.
                                          Bert Mulder
                                          Bert Mulder
                                          Inge Bakermans
                                          Inge Bakermans
                                          • Download club route folders
                                          • Passwords
                                          • Live tracking problem on Android tablet
