  2. Camper Discussion
  3. Missing motorhomes in library selection tab
Scheduled Pinned Locked Moved Camper Discussion
24 Posts 7 Posters 13.1k Views 3 Watching
  • Inge Bakermansundefined Offline
    Inge Bakermans
    Dear MRA developers, in the library I am missing the possibility to select motorhomes in the 1st tab (riding, cycling, walking). Is it possible to add the possibility to select motorhomes to this tab?
    Would be hugely appreciated.
    Marinus van Deudekomundefined Corjan Meijerinkundefined 2 Replies Last reply
    • Inge Bakermansundefined Inge Bakermans
      @Inge-Bakermans The majority off. The routes are created in the profile. Car. Just a couple of routes die walking and cycling. As far as I know there are no routes made for mobile homes.
      My advise, take a route that you like change the profile to mobile home to get a route suitable for that purpose. Have fun
      Inge Bakermansundefined 1 Reply Last reply
        @Inge-Bakermans which tab exactly? A screenshot would help a lot!
            Inge Bakermans
            @Marinus-van-Deudekom That is what I have been doing. Though would be nice to see motorhomes in the pop-up. Since riding refers to 2 wheels not four.
              Inge Bakermans
              @Marinus-van-Deudekom Spot on!
                @Inge-Bakermans RouteXpert routes are created using the car profile in transport mode. There is no point in having a motorhome profile in the search box because there are no routes specifically for motorhomes. You can save a RouteXpert route to your library and change the transport mode to motorhome to see if any changes are required.
                  Inge Bakermans
                  @Nick-Carthew That obviously is an option - however Iexpect more motorhome/ car routes to appear as time progesses. Since MRA is catering for rv's why not being able to select it.
                  Marinus van Deudekomundefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
                    @Inge-Bakermans hoi Inge
                    Zoals Nick al aangaf worden allen routes in de bibliotheek door de RouteXperts gemaakt in het profiel auto. Met andere woorden er worden geen routes (meer) gemaakt voor andere profielen. Daarom heeft het geen zin om een mobile home knop toe te voegen. Bovendien zou een knop zoals jij bedoelde niet kunnen gaan werken omdat je in het profiel mobile home nog veel verschillen zou kunnen hebben. Ze zijn immers niet allemaal gelijk qua afmetingen.
                    De optie om een van onze mooie routes om te zetten naar jouw profiel lijkt daarom nog het beste
                    Als je meer hulp nodig hebt, vraag het gerust.
                    Hi Inge
                    As Nick indicated, all routes in the library are made by the RouteXperts in the car profile. In other words, routes are not (anymore) created for other profiles. Therefore, it makes no sense to add a mobile home button. Moreover, a button like you meant could not work because you could still have many differences in the mobile home profile. After all, they are not all the same in terms of dimensions.
                    The option to convert one of our beautiful routes to your profile therefore seems to be the best
                    If you need more help, feel free to ask
                    • Bert Mulderundefined Offline
                      Bert Mulder
                      Bij het tab blad "Route informatie" bij een route kun je de afmetingen van je voertuig opgeven. Iedere camper heeft immers andere afmetingen.
                        Hi Inge
                        Inge Bakermans
                        @Marinus-van-Deudekom Ah, dat wist ik niet dat er geen andere profiel routes meer werden aangemaakt, behalve dan het autoprofiel. Dat maakt het vinden van routes dan ene stuk makkelijker.
                        Qua afmetingen heb je gelijk - die heb ik meteen toen die mogelijkheid er was goed ingesteld.
                        • Bert Mulderundefined Bert Mulder
                          Inge Bakermans
                          @Bert-Mulder Dat heb ik vanaf dag 1 gedaan.
                            @Inge-Bakermans veel van de routes zijn ook geschikt voor campers maar, het merendeel van de RouteXperts zijn motorrijders maar er zijn ook niet motorrijders onder ons. Kijk bv eens naar de routes die Jan Cabrio heeft gemaakt. Bij mijn eigen routes in Luxemburg zijn er ook een aantal goed te rijden met één camper. Have fun
                              Inge Bakermans
                              @Marinus-van-Deudekom Dank je wel Marinus - ga ik zeker doen.
                                @Inge-Bakermans
                                Er zijn ook (nog) geen RouteXperts die routes voor campers maken. En tot op dit moment wordt alleen het autoprofiel ondersteund in de RX Bibliotheek
                                  @Inge-Bakermans
                                  Inge Bakermans
                                  @Hans-van-de-Ven-MR-MRA Dank je wel Hans. Jammer dat er nog geen RV-experts zijn.
                                    @Inge-Bakermans misschien kun jij de eerste worden 😎
                                      Ben ik heel erg cynisch als ik zeg dat campers niet bedoeld zijn om scenic routes te rijden? Dit vooral met het oog op het overig verkeer...
                                      Hans van de Ven MR.MRAundefined Marinus van Deudekomundefined Nick Carthewundefined Inge Bakermansundefined 4 Replies Last reply
                                        Zie deze route samenvatting: https://www.myrouteapp.com/nl/motor-en-auto-routes/pt/Vila-Real/8684527/Route-66-Portugal-01-Chaves-Penacova
                                          @Con-Hennekens ze doen er soms alleen wat langer over 🙂
                                          Bert Mulder
                                          Inge Bakermans
                                          • 5000km probleemloos!
                                            Ewout Dundefined
                                            Ewout D
                                          • How to switch to 3D mode on CarPlay?
                                            ConiKostundefined
                                            ConiKost
                                          • Rij met XT3 maar bestand 1.2 heeft altijd problemen
                                          • test Myroute APP
                                            KurtvPouckeundefined
                                            KurtvPoucke
                                          • Duizend bochten
                                            Guztundefined
                                            Guzt
                                          • Google Street view not working?
                                          • High Contrast Maps
                                            TuonoPantsundefined
                                            TuonoPants
                                            1.2k
