  4. Add Picture after save Tracklog from Gallery
7 Posts 4 Posters 1.4k Views 2 Watching
  • Tegel Wernerundefined Offline
    wrote on last edited by Tegel Werner
    Hi all Users of MRA
    when you have an active Tracklog (green Button) is very easy to add Picture from I-Phone Gallery with the correct Geo-Tag to the Track. I miss the same function for an stored Tracklog so I can easy add Picture in the evening when I spent a pint of Beer. Knows anyone how it works?
    thanks
    • Tegel Wernerundefined Tegel Werner
      Hi all Users of MRA
      thanks
      @Tegel-Werner not possible!
      Something I still wish to add.
      You’d have to do it manually on the website 😞
      Con Hennekensundefined Tegel Wernerundefined Motobummlerundefined 3 Replies Last reply
        @Corjan-Meijerink, that would be very nice!
          @Corjan-Meijerink it was only add a Button on Tracklog Tab (add Photo) the same Function as an active Tracklog. You can ask your Team if this is easy to do (I hope so).
          Regards Werner (I like MRA)
            Motobummlerundefined Offline
            Motobummler
            @Corjan-Meijerink, Which might be cool. I take the photos while driving a route. My track is active. In the evening, or perhaps later, I would like to add the photos to the track. I have to tell the track exactly where I want to insert this photo. What would be really cool would be if the geodata from the photo is saved and the point on the track is automatically selected based on the data. 😇
            iPhone XR (iOS 18.01)
            iPhone 11 (iOS 18.01)
            Oukitel RT3 (Android 13) + 64GB SD without SIM / connecting with tethering
            Wired CarPlay (KIA Sportage PHEV - 2022)
            Tegel Wernerundefined 1 Reply Last reply
            • Motobummlerundefined Motobummler
              @Motobummler Hi Motobummler i work with two iPhone one is Routing and the Second is for Picture. When I finished the Tour I add all Picture from the Tour to the Tracklog before I saved the Tracklog so all Picture on the correct Geo Position. Later I can delete Picture from the Tour which are not interested. -> This is easier as Position every Picture to the Correct Place. -> This is only a Workaround
              Gruß nach Erding von Ulm
              Motobummlerundefined 1 Reply Last reply
                Motobummler
                @Tegel-Werner, das ist auch ein guter Weg. Danke für den Tipp.
                Mit den zwei Apple Geräten hast du natürlich den Vorteil der iCloud und den Foto Sync. So das beim speichern des Tracks die Fotos von deinen Aufnahmen zur Verfügung stehen.
                Bei mir funktioniert das so leider nicht da ich mit meinen iPhone zwar die Fotos mache aber über meinen RT3 (Android) navigiere und somit beim beenden der Route die Fotos nicht auf dem Gerät zur Verfügung habe.
                Daher dachte ich mir eben ob es nicht so eine Möglichkeit gebe um im Nachhinein den Track mit den Bilder zu bestücken und dabei die geodaten auszuwerten. Das hätte den Vorteil das es Geräte übergreifend funktionieren kann. Vielleicht liest @Corjan-Meijerink das und findet es auch interessant 🤭
                Einen schönen Gruß aus Erding ins schöne Ulm
                Michi
                Motobummler
                  paul69undefined
                • Segmentation
                  Lenny Oundefined
                  Lenny O
                • Herberekenen werkt niet.
                • Seasonal closures
                  MotorMakkers 0undefined
                  MotorMakkers 0
                  5.1k
                  Thomas Neumeyerundefined
                  Thomas Neumeyer
                  1.8k
                • Onbekende fout, 3 problemen
                  Klompenmaker1undefined
                  Klompenmaker1
