  4. Dangerous/difficult curves
6 Posts 5 Posters 1.6k Views 2 Watching
  • wim Bleijenbergundefined Offline
    wim Bleijenberg
    Dangerous/difficult curves.
    I use normally Calimoto, because it give me on the map the curves which are dangerous or diffilcult to ride.
    My route I also use and the above mentioned add is not in the road map. Is this a possible suggestion??
    Kind regards Wim
    Rob Verhoeffundefined Peter Levisundefined 2 Replies Last reply
    • wim Bleijenbergundefined wim Bleijenberg
      Kind regards Wim
      Rob Verhoeffundefined Offline
      @wim-Bleijenberg This question has been asked on the forum before. Just run a search term for it. Long story short: you can place a waypoint with the text 'watch out!' or something similar for a series of 'dangerous bends.' Besides, a screen won't help you. Your attention should be on the road, not on your screen. But that's just my opinion.
        Kind regards Wim
        Peter Levisundefined Offline
        Peter Levis
        @wim-Bleijenberg
        I kind of agree with Rob, I don't see much value having markings for a dangerous bend. I consider ALL bends potentially dangerous and ALL junctions. I too use Calimoto and have never found that feature of much use. However I do sometimes zoom the map out when riding unfamiliar roads to get a heads up of what is coming. I really think learning to read the road is more important. One of the problems with all these navigation maps is the tendency to spend too much time looking at them and not the road. Something I'm guilty of.
        Loving my test with MRA but still struggling with the text size for distance to next turn. Guess Calimoto has spoilt me with that one feature.
        • Peter Levisundefined Peter Levis
          @wim-Bleijenberg
          @Peter-Levis there you go. I consider all curves and bents not dangerous. The only thing dangerous over there is the driver 😁
          Peter Levisundefined richtea999undefined 2 Replies Last reply
            Peter Levis
            @Marinus-van-Deudekom said in Dangerous/difficult curves:
            HaHa could be right thereπŸ˜€
              richtea999undefined Offline
              Quite true - the rider needs to be wide awake, looking, thinking.
              Calimoto might give you a little extra information - not a lot - but at the cost of looking ahead.
              There are plenty things that Calimoto won't tell you:
              • the road surface (potholes, gravel, mud, shiny, oil, diesel, leaves)
              • the weather (rain, frost, ice, lying water/blocked gutter)
              • the oncoming driver (who is also looking down at Calimoto as he crosses the centre line 😡😰)
              • the tractor that is just out of sight round the corner, but you saw the open farm gate, right? Calimoto didn't.
              richtea999undefined
              Peter Levis
              wim Bleijenberg
                AWDC LAOundefined
                1.9k
                5.4k
                paul69undefined
              • Adding a waypoint in the middle while navigating?
                John S Parryundefined
              • Imported gpx File has errors when converted to Here map.
                Rob Veermanundefined
              • App stΓΌrzt bei aktiver Route immer wieder ab
                NigelTundefined
                NigelT
                17.2k
