  3. Offline maps and routing
34 Posts 13 Posters 25.7k Views 4 Watching
    @Bouke-Ent, Je route staat gecached, dus die gaat gewoon door. Je kaartweergave zal leeg zijn, maar de routelijn is nog steeds conform de werkelijkheid. Op het moment dat er iets van herberekening moet plaatsvinden ga je de mist in. Vraag me niet hoe ik dat weet... 😉
    @Con-Hennekens bedankt voor uitleg.
      @Doug-Robinson
      Thanks Doug. The app is really not very intuitive, and it seems the offline navigation isn’t really offline navigation if it will only run a pre calculated route, and only then if started from the download folder.
      Why would I read a manual? If I have to read a manual to do something very basic then there’s an issue with the app. Especially if it’s for something like offline navigation which I would use only if I couldn’t use online navigation.
      Some different thinking form the devs needed here, maybe.
      @Berin many of the functions are very intuitive for basic operation. If you play with it long enough and try everything possible on the screen, eventually you learn most of it. I had a lawyer complain to me that the new phone system we installed should be intuitive enough that he should not have to attend training. I told hom that I'm sure he can figure out how to receive and make phone calls, but if he wants to learn how to make full use of the features of the system he should attend training. He eventually did.
      A Former User? 1 Reply Last reply
        A Former User?
        A Former User?
        A Former User
        @RetiredWingMan Fascinating story, I'm sure.
        However all this was resolved about 2 months ago.
        Jorge del Valle 1 Reply Last reply
          Jorge del Valle
          Jorge del Valle
          Jorge del Valle
          wrote on last edited by Jorge del Valle
          #25
          I've tried using offline navigation today for the first time, and it didn't work. I had both the country map and the route downloaded. My phone was in airplane mode when I launched the app. I selected the route from the downloads list, and then tapped the button to start navigation, which then resulted in this screen.
          I've checked the online manual and the forums and as far as I can tell it should work as long as I've downloaded the region map and the route. Am I missing something?
          Edit: I've found a forum post that I somehow missed in my initial search, where another user says they solved the problem by rebooting the phone and then waiting a few minutes when they got the message and the routing eventually started working. I'll give that a try, but is that (having to wait several minutes for offline navigation to work) expected behaviour for the app?
          Jorge
          • Jorge del Valle Jorge del Valle
            @Jorge-del-Valle Try turning off Calculate from current location to see if that makes a difference.
              Jorge del Valle
              Jorge del Valle
              Jorge del Valle
              #27
              @Nick-Carthew Thanks Nick, that worked. However I'm a bit puzzled by the meaning of that option.
              What I mean is, when I turned it off it traced a route from my current location to the start of the downloaded route, so even though I'm disabling an option named "calculate from current location" it seems to actually do just that (calculate a route from my current location). It doesn't seem to do what one would expect based on the name, or maybe I'm misunderstanding its function? A search for the option in the online documentation doesn't yield any results for me.
              Another thing that's strange is that, after stopping the navigation and closing the app, I then reopened it (again in offline mode) and then tried loading the same route and starting the navigation again. And this time it worked even though the "calculate from current location" was back to enabled.
              Jorge
                @Berin, on the contrary, the app is VERY intuitive. Even intuitive software has a certain learning curve, especially if you previously used another tool for the same thing. I did not read the manual either, and I think it is VERY intuitive 😉
                The app makes perfect sense if you understand what it is doing. What it is doing is probably a bit different from what you are used to. Downloading offline maps is not the only thing needed to navigate completely offline. Offline maps are there mainly to prevent bandwidth usage while navigating. And of course offline maps are obligatory for offline navigating. Offline navigation is enabled in the settings: Navigation settings - Functional.
                Pay attention also to the setting at the arrow. This one automatically makes available for offline usage all previously chosen routes. You only need to enter the download folder if at the time of choosing a route, you have no internet connection. The folder-view you see when tapping the Routes button in the main menu is a view into your online routes library. It is not so strange that it is not available when not having an internet connection. If you compare this to downloading routes to a Zumo or Rider, it is pretty much the same thing. With the added benefit of not having to do that at all, if your phone is connected to the internet. See? Pretty intuitive 😉
                NineLizards
                NineLizards
                NineLizards
                wrote on last edited by NineLizards
                #28
                @Con-Hennekens Dit is een oude thread, maar hij roept bij mij een nieuwe vraag op.
                In een van de posts staat een afbeelding van het 'Functional' menu, met daarin de optie 'Gebruikte Routes en Tracks automatisch downloaden voor offline gebruik'. Die optie zie ik bij mij niet staan. Kijk ik ergens overheen?
                In one of the posts there's an image of the functional menu, with an option to automatically download maps and tracks. But I don't see it on my phone. Am I overlooking something?
                MRA Routeplanner (Gold) / MRA Next (Android) / MX-5 (Fun)
                • NineLizards NineLizards
                  @NineLizards that option is gone with the resent synchronisation implementation.
                  NineLizards 1 Reply Last reply
                    @Jorge-del-Valle if you enable the calculate from current position then the time and distance shown will, jnclude the time and distance to you starting point. If you disable the option then the map only shows the route and the time and distance for the route. When you hit/tap navigate, you are still shown directions to your route starting point.
                      NineLizards
                      NineLizards
                      NineLizards
                      @RetiredWingMan Ah, okay. But now I'm completely confused about offline navigation...
                      What are the current steps for using offline navigation? I'm mightily confused now.
                      Let's assume I plan to travel through Belgium, through an area where there's no coverage. (It happens to me this week.) I assume I should download the offline maps of the region upfront, right? (It's currently giving an error message 'could not fetch latest map update information', I'm not sure if that matters).
                      But... how do I get my route offline? Is there a step by step manual somewhere?
                      RetiredWingMan Con Hennekens 2 Replies Last reply
                        @NineLizards first, i presume the map error is temporary. I've seen it before and it normally corrects itself. You need to resolve the issue before you can download maps. If you continue to have problems raise a support contact. User manuals are available on the support page.
                        Second, I suggest enabling the synchronisation of all routes. This makes all routes available offline.
                        To operate in offline mode: 1. Download all maps for the areas to be traveled. 2. Synchronise your routes. 3. Turn on offline navigation in the options.
                        That's it, you're ready to go.
                          @NineLizards, I see your question has been answered perfectly fine by @RetiredWingMan 😉
                          in short:
                          • download offline maps
                          • enable sync (preferably all, then you will never have to look at it)
                          • let it complete a sync once, it will resync every time you start the app or enter the routes menu automatically and download changes only (if there are any)
                          • enable offline navigation in the app menu
                          No need for confusion ever again (concerning offline routes that is... 😉 )
                            @Berin you really do need to review the manuals. The questions you are asking are very basic. To fully use offline you need to: 1. Downloads maps for the region(s). 2. Download the route(s). 3. Set offline opperation / navigation in the options. 4. Start your route navigation from the Downloads folder.
                            Yes, you can delete maps, use the X beside downloaded maps.
                            Enjoy!
                            Nigel Ralphson
                            Nigel Ralphson
                            Nigel Ralphson
                            @RetiredWingMan Hi, I've done all that....I think....but still can't access the map offline..... I've downloaded the region map but when I try to download the route I don't get the "offline" option on the export scroll wheel just the GPX 1.1 etc.
                            So when I go to use offline mode it says "no routes could be calculated using your offline maps and I need to turn off offline maps.
                            I'm confused!
                            Dikke Wim
                            Dikke Wim
                            NineLizards
                            NineLizards
                            Nigel Ralphson
                            Nigel Ralphson
                            Jorge del Valle
                            Jorge del Valle
                            A Former User?
                            [[global:former-user]]
                            • Routenplaner on iPad
                            • Rondrit generator ervaring
                              Sam Kramer
                              Sam Kramer
