  4. Android Tablet or CarPlay?
39 Posts 15 Posters 25.1k Views 5 Watching
    @paul69 said in Android Tablet or CarPlay?:
    i have bought a Ram X grip and a double ended flexi arm, 450mm
    Hmm, with such an arm you can put your tablet right in your face... 😉
    Are you not afraid such a long arm will swing around with vibrations on the bike? Especially since it is flexible?
    hi @Con-Hennekens said in Android Tablet or CarPlay?:
    there is danger this may happen, I may be able to wrap the flexi arm around or through my bars, maybe even use cable ties, this is to try and stop it from obscuring the TFT, it is arriving today, i will have to experiment.
    although if it does not work it will an expensive experiment, i will just have to sell it on ebay.
    K1600 GTL
    iPhone 13 Pro, carpuride 702b
    • Ron Z Ron Z
      @paul69 My setup with the TFT and Connected App has been very stable with my iPhone. I have all the latest updates to the TFT software, Connected App and phone.
      But the issue I have with it is the lack of shaping points and the app’s recalculation algorithm. If BMW ever gets these things fixed I might go back to it. Having the ability to control everything - nav, music and phone via the bike’s control wheel and not having to take your hands off the bars is very nice.
      @Ron-Z said in Android Tablet or CarPlay?:
      hi @Ron-Z
      my devices and connected app are all updated, iPhone 13 pro, I went for a a short ride on Sunday, approx 3.5hrs, the TFT lost map view 3 times, my helmet remained connected as did my phone, the music was still playing. it is only the map view that drops out. This is why I will not trust it at the moment, oh yeh and also the continuous announcement of every way/via/shaping point or whatever label/name you want to use.
      TBF the connection between phone, intercom and TFT is seamless, hopefully BMW will sort out the map view.
      I could have purchased an XT or tomtom, but my tablet works perfectly fine.
      as previously stated, i just need to find a suitable way of attaching it. see my reply to @Con-Hennekens, I might even super glue it to the screen of the bike 🤣 🤣
      K1600 GTL
      Ron Z 1 Reply Last reply
      • Gerard Wullink
        Gerard Wullink
        Gerard Wullink
        Imho one evident advantage of using a tablet/phone on which you install the MRA Navigation Next app over using a dedicated GPS device is missing.
        If you use MRA Navigation you do not have to export a gpx file (which version do I have to use?) in a certain format and copy thay to a device over a third party app/drive/system from Garmin/TomTom or upload them over USB to a device and hoping all information in the gpx will be used during the conversion of the gpx to a route on your device, using the maps en settings of your gps device, to stay on the route the planner intended. That's a lot of steps, one of them being the user. This is a very annoying pain in the a.. for a lot of gps device users out there.
        When using MRA Navigation Next you just open the route (no gpx conversions!) on your phone/tablet, make it available offline (maps/route) and hit navigate. No conversions, so no missing data and when riding no connections needed. Easy as eating a banana.
        This method also makes the MRA development team independant of gpx format definitions and limitations of gps devices. They could add everything they want. Example: add a url to a hard point in the route which gives you info about the opening times etc etc. No Limits!
        If you want to use CarPlay or Android auto, there is a chance version may conflict or some new functionality is missing.
        For me: tablet, absolutely. Downside: most normal tablets/phone use a USB micro or C connector, which does not fit the job. Too fragile and not watertight. Find a rugged one with pogo ins for power supply. Should you be needing Internet on the tablet for something else than MRA, use the hotspot on your phone and keep the phone safe in the pocket.
        • paul69 paul69
          hi @Ron-Z
          Ron Z
          Ron Z
          Ron Z
          @paul69 You have to make sure Auto Join hotspots is off and ask to join hotspots is off. I also have my phone to never screen lock when I’m using the Connected App. I haven’t had any disconnect issues with these settings.
          2009 BMW K1300GT
          Garmin zümo XT
          Samsung Galaxy Tab Active 5 w/RAM mount
          2023 BMW R18 Transcontinental
          iPhone 14 Pro Max w/QuadLock mount
          Apple CarPlay in Carpuride W603D w/front-rear cameras
          paul69 1 Reply Last reply
          • Ron Z Ron Z
            hi
            i will definitely try this option. i never have an issue with the initial connection via the wifi, it is almost instant.
            thanks for the tip
            K1600 GTL
            • Albert van den Elsen
              I use a Carpuride W702 in combination with Apple CarPlay. This works excellent for me.
              iPhone 15,
              Garmin Zumo XT3
              Carpuride W702 Pro
              Sena 20S EVO headset
              Harley Davidson Road King M8
                Hi, I use an outdoor tablet about a year (a Oukitel RT3) it works perfect for me and I love the extras you do not have with an CarPlay display or Auto Andriod.
                PieterG
                PieterG
                PieterG
                wrote on last edited by PieterG
                #35
                @Jörgen said in Android Tablet or CarPlay?:
                Oukitel RT3
                That seems a very good solution!
                What type of bike mount do you use, please?
                I drive a BMW R1250GS and I have the idea to make a custom adapter myself that fits into the original BMW navigator mount 😊
                Ron Z 2 Replies Last reply
                • PieterG PieterG
                  Oukitel RT3
                  Ron Z
                  Ron Z
                  Ron Z
                  @PieterG said in Android Tablet or CarPlay?:
                  Oukitel RT3
                  I was using a center stem RAM ball mount with a RAM USB-C powered dock for the tablet.
                  I have since switched bikes to an R18 Transcontinental. Therefor my 8" Android tablet is no longer suitable due to it's size.
                  I now have a Carpuride W603D 6.3" CarPlay screen with front and rear dash cams.
                  2009 BMW K1300GT
                  Garmin zümo XT
                    It remains a personal choice. A CarPlay or Android tablet is relatively cheaper than a premium rugged tablet. But Android Auto and Apple CarPlay are less stable because you are dependent on multiple systems.
                    Jan 50
                    Jan 50
                    Jan 50
                    @Michel-van-Hagen-MRA-Founder Hi Michel, why should it be less stable? Other apps work fine with AA or AC. The functionality is less, but it can be very stable. I never had problems with Google Maps, Waze, Go Ride, Tom Tom. Only the MRA app seems to have problems with the Here map and AA. I think it takes a bit of development to improve the app, which i think is really a great app. Maybe,in stead of creating new options the focus should be on improving the AA and AC app?
                    • PieterG PieterG
                      Oukitel RT3
                      Ron Z
                      Ron Z
                      Ron Z
                      @PieterG Also, if your bike has the BMW navigation cradle, check out Carpuride's W502B Pro or W702B Pro CarPlay screens - they'll connect directly to the BMW mount with no adapter needed.
                      2009 BMW K1300GT
                      Garmin zümo XT
                      PieterG 1 Reply Last reply
                      • Ron Z Ron Z
                        PieterG
                        PieterG
                        PieterG
                        #39
                        @Ron-Z
                        Thanks for your reply!
                        I know the models you mention. In fact, the manufacturer has screwed a loose BMW adapter to the back of these models, just like with my Carpuride W619B. What I want to do is use such a kind of adapter in combination with a small rugged tablet so that I can also place it in the BMW cradle. This way I can always easily choose between using my BMW navigator IV, the Carpuride W609B or a tablet running the MRA Navigator Next app. 🙂
                        Makro
                        Makro
                        PieterG
                        PieterG
                        Gerard Wullink
                        Gerard Wullink
                        Jan 50
                        Jan 50
                        HighPeakRider
                        HighPeakRider
                        Ron Z
                        Ron Z
                        No6671
                        No6671
                        Triqster
                        Triqster
                        • Béta to no-béta
                          Parantapa
                          Parantapa
                          John Matthews 0
                          John Matthews 0
