  4. time and duration panel
4 Posts 2 Posters 891 Views 2 Watching
  • Cookie On Tour
    Cookie On Tour
    Cookie On Tour
    Hello,
    I searched for the time and duration pane while navigating as there are different tiny symbols appearing and I liked to know their meaning. However, I was not able to find the possible icons that can be displayed at the instructions. Is there a list of icons that indicate and describe their meaning?
    I saw on my screen a yellowish circle for example with an arrow up/ arrow down or a finishing flag, but there were some others I can't recall right now. Is there a list of icons that I didn't find?
    Joerg
    (Cookie-On-Tour.de)
    Duster LaurΓ©ate SCe 115 LPG 4x2 Β· Everest Minicamp by Niewiadow (B1300)
    Carpuride W701 Pro Β· iPhone 15 Pro Max
    • Cookie On Tour Cookie On Tour
      Hello,
      @Cookie-On-Tour said in time and duration panel:
      This is the offline indicator icon. If this one appears, your're in offline mode. Either initiated by yourself with the "offline switch" in the settings, or by the app automatically when internet is lost. If you did not set the switch to offline yourself, the app should move back to online mode whenever it determines internet is back again. This may take a minute or so.
      Can you recall which icons you additionally saw?
      Perhaps some of the ones you saw are explained in the inbuilt "tutorial" you can activate. It guides you through a lot of the menus and their meaning.
      Edit: after reading your post another time, the information below already discusses your seen icons.πŸ˜‰
      There are no additional icons, except for the fuel icon that may appear on the left side of your screen, just below the navinstruction fields, which shows the next fuel station ON your route, not in the neighborhood of your location, but ON your route.
      Regarding the "finishing" flag, it is mentioned in the tutorial:
      This field can either show the distance to the next waypoint (invertedπŸ’§ icon), the next via point (βœ‹πŸΌ icon) or the destination (🏁 icon) of the route. Tap the field to iterate through the options.
      Cookie On Tour 1 Reply Last reply
        Cookie On Tour
        Cookie On Tour
        Cookie On Tour
        wrote on last edited by Cookie On Tour
        @Stefan-Hummelink many thanks, you helped a lot. I think the green circle with the white dot did have different colours too, but I might be wrong.
        Joerg
        (Cookie-On-Tour.de)
          @Cookie-On-Tour That circle is the "track recording" icon! If it is red, you are not tracking your route, if it is green, it is tracking your route. Upon saving the track you get a tracklog in your account.
          In the settings you'll find the option to Auto-Start a track when navigating a route. There is no Auto-Stop.
          Cookie On Tour
          Cookie On Tour
          • Route wordt afgesneden
            Wim Hompes
            Wim Hompes
          • Problem with HERE, getting the route correct ??
          • Map blurred when editing POIs
          • Maps Michelin
            Jacob Waterweg
            Jacob Waterweg
          • App failed to start; reinstall locked me out!
            Anonymouse
            Anonymouse
          • OSM Routing with MRA
          • Weer een positieve ervaring!
