  4. Moving Map without Accidentally Adding Unwanted Waypoint
9 Posts 4 Posters 1.3k Views 3 Watching
  • David Howarthundefined Offline
    David Howarth
    I am using MRA on a Macbook with Trackpad and I am getting fed up of accidentally adding a Waypoint when just trying to move the map on the display. I know if I hold down the trackpad and move the cursor the map moves/scrolls (which is what I want to do) but so many times I accidentally click the trackpad which the just adds an unwanted waypoint which I then have to undo. This is so frustrating. I can't see any tool to allow me to scroll/move (like in Basecamp) and I have tried various combinations of holding down a key but nothing seems to work. Does any body know of a way I can move the map view without inadvertently adding a waypoint Thanks
    • David Howarthundefined David Howarth
      Dae 0undefined Online
      Dae 0
      The same goes for the search box. I want to search for something and have the map move to where it is, not add a waypoint to the route.
      Dave J 0undefined 1 Reply Last reply
      • Dave J 0undefined Offline
        @David-Howarth In the Page Menu, select ‘Place Waypoint Button”:
        You will then see a cursor which you place where you want to insert a waypoint by moving the map and then select the button ‘Place Waypoint’.
        I use an iPad for most of my route planning and this stops the inadvertent waypoint insertion when touching the map. You can also use the ‘Lock Waypoints Button’ - See reply below.
        Ducati Multistrada V4 Rally
        iPhone 15 Pro
        CHIGEE AIO-6 LTE
        • Dae 0undefined Dae 0
          @Dae-0 Use the lock Waypoints button. When you search, the map will move to where you have searched without inserting a waypoint.
          Whilst adding waypoints is locked, you can still add POIs as waypoints through the Points of Interest Menu if they are selected on the screen.
          iPhone 15 Pro
          CHIGEE AIO-6 LTE
          David Howarthundefined Dae 0undefined 2 Replies Last reply
          • Dave J 0undefined Dave J 0
            David Howarth
            wrote on last edited by David Howarth
            @Dave-J-0 Thank you Dave, that has really worked for me and will now save me hours of frustration.
            Incidentally, I too was a Blood Biker (with Derbyshire Blood Bikes for 6 years) and actually moved over to Shropshire, Staffordshire and Cheshire Blood Bikes in 2021 but unfortunately (due to ill health) did not manage to continue. My brother in law is still a volunteer with Shropshire, Staffordshire and Cheshire Blood Bikes, usually using the bike from Uttoxeter. Small World......
              Dae 0
              @Dave-J-0
              Thanks. That’s helpful, even if it’s a bit of a fudge.
              What would be handy would be to change the search box and, for example, allow shift+enter to search without adding to the route.
              In nearly all cases that I’m searching, I’m looking for an area or general thing, rather than a specific point that I’m immediately going to add to the route.
                @Dave-J-0
                Stanisławundefined Offline
                @Dae-0 I prefer the "Ask for waypoint name" parameter - in this case I can press ESC or use Cancel button and avoid placing unnecessary waypoint:
                Staszek
                  Dae 0
                  @Stanisław That’s probably a better workaround as it avoids lock-search-unlock every time.
                  I’d still like an option though similar to my suggestion above, or even a tick box to stop the auto creation of waypoints when searching.
                  Maybe I’m using MRA differently to everyone else, except my wife as she does 90% of our tour planning also finds the auto-add annoying.
                    @David-Howarth Indeed a small world. Might 'bump' into you sometime.
                    iPhone 15 Pro
                    CHIGEE AIO-6 LTE
                    Dave J 0undefined
                    David Howarth
                    Stanisławundefined
                    Dae 0undefined
                    Dae 0
                    • Joining a planned route from a differant position.
                    • Problemen route opslaan naar plan.tomtom
                    • running myRoute-app on a carpuride
                    • Rijrichting in route
                      1.4k
                    • What exactly am I looking at?
                    • MRA basic
                      b0hd1undefined
                    • Exporting route from app to Garmin XT webpage not available
                    • Track prefix name when exporting through web or andorid MyRouteApp
                      Will Brooksundefined
                      Will Brooks
