  4. Curvy Track re-routing problem
19 Posts 5 Posters 211 Views 4 Watching
  • GT JWRundefined GT JWR
    @Jörgen I've experienced that as well, and while my route had numerous possibilities, the app insisted, for 23mi, that I do a u-turn and go back....makes it hard to 'trust' the app 😕
    https://forum.myrouteapp.com/post/49267
    @GT-JWR : @Jörgen
    Recommendation only the 1.) s. Image to use if you want to remain flexible and still want to keep an eye on the goal.
    • 1.) this is a route that is adjusted again and again when leaving
    • 2.) , 3.) and 4.) are fixed tracks / tracks that are absolutely to be driven, the app leads you hard back to the exit point when you leave and from there you only kindly continue without an announcement...
    @Corjan-Meijerink 👋
    Suggestion: also 2.) should be a route with a higher proportion of curves than under 1.).
    Under 1.) it is still unclear to me with which avoidances the route will probably be calculated. Setting motorcycle and then?
    This should also be supplemented by avoiding under 1.). 👋
    GT JWRundefined Hubert Thoringundefined 2 Replies Last reply
      @GT-JWR : @Jörgen
      @Corjan-Meijerink 👋
      GT JWRundefined Offline
      @Hubert-Thoring thanks for the input. In my example, it was a very simple A-B route, and the fact that it did not reroute after a couple of miles, to me, was extremely odd. There were no waypoints, just a start and a finish. (see the link, it explains what was going on, complete with screen shots).
        @GT-JWR : @Jörgen
        @Corjan-Meijerink 👋
        @Corjan-Meijerink : Eine Bitte könntest Du das von zuvor noch beantworten ?
          @Hubert-Thoring to what?
          What you state in the image is indeed correct.
          Fastest option is A-B route navigation.
          Rest is track navigation.
            @Corjan-Meijerink : Sorry … Die Frage ist leider noch offen geblieben.
            • Könnte man in der 1.) A-B Route Navigation diese Auswahl s. Bild als mögliche Auswahl wohl ergänzen ❓
            • Oder geht das nur in der reinen Track Navigation ❓
              @Hubert-Thoring as the options are only available in track navigation that is indeed by design 😉
              The route navigation by HERE don’t support these settings.
                @Corjan-Meijerink : Hey Corjan, Herzlichen Dank für die klare Antwort. Ich werde es allen meinen Freunden so erklären 👋 Dir weiterhin viel Erfolg beim + MRA Route Thema, das ist auch eine schnelle Möglichkeit für unterwegs jetzt schön zu fahren
                Danke auch dafür 👋
                • Jörgenundefined Offline
                  Hi, I used an A to B Track (curvy Route) and deviate from the org. Track.
                  And now there was a recalculation to get back to the track. 😳
                  What happened? How is this possible? Was there some change since beginning of July.
                  • Jörgenundefined Jörgen
                    @Jörgen nothing 😉
                    It all depends on the track and where you deviate.
                      @Corjan-Meijerink Ok, thanks. I was very surprised
                      I thought something had changed.
                      Then it would be nice to know when a recalculation takes place and when not?
                      Or what a recalculation depends on.
                        @Corjan-Meijerink :
                        @Jörgen
                        I tested the topic of track today with Guru Maps and MRA, there is a positive other behavior with Guru Maps maybe this is an idea that can be found in MRA 🤔
                        • Route remains as it is
                        • Position is displayed with the straight but shortest dashed line to the route
                        • Distance position to the track as the shortest connection
                        • you can drive and only get the audio hint once to return to the route
                        • it is probably always a dashed line that shows the shortest connection, on which ges. Route to the deviation of the actual track
                        • if you are back on the track then it goes normally to the destination
                        I deliberately just drove out of there
                        Then shortly afterwards comes the announcement, which is also as text in the display at the top
                        Then the new reference line to the track comes a little later ...
                          @Corjan-Meijerink :
                          @Jörgen
                          @Hubert-Thoring Please use the language of the topic. In this case it is in English.
                            @Nick-Carthew Okay, it's done
                            GT JWRundefined
                              Carl Leeundefined
                              Carl Lee
                              7.4k
                              haweboundefined
                              hawebo
                            • Track vs Route
                              Roger Needham 0undefined
                              Roger Needham 0
                            • Camperroutes
                              stuart marrittundefined
                              stuart marritt
