  4. Curvy Track re-routing problem
19 Posts 5 Posters 211 Views 4 Watching
  • Jörgen Offline
    Jörgen Offline
    Hi, I made a curvy track just by entering the target and use of curvy road.
    Then I did not follow the given Track.
    MRA wants me to turn around!
    Turn around always for a long way and not trying to take the shortest possibility back to the track.
    Even not when I am 30m away from the track!
    What is going wrong here?
    Hubert Thoring GT JWR 2 Replies Last reply
      Hubert Thoring Online
      @Jörgen
      s. Route von A zu B schneller anpassen
      Hey Jörgen, schau mal da, genau das hat mich auch schon oft geärgert, jetzt weiß ich das nur der direkte Weg s. 1.) flexibel reagiert. Die Kurven Strecken 2.),3.)4.) sind feste Tracks die Du starr folgen sollst (scheinbar musst) auch wenn es für dich keinen Sinn macht.
      Hey Jörgen, look there, that's exactly what has annoyed me many times, now I know that only the direct way reacts flexibly. The curve stretches are fixed tracks that you should follow rigidly (apparently have to) even if it doesn't make sense to you.
      • Corjan Meijerink Online
        Previously people complained that when you’d deviate from the track, too much of the original track would be lost. Now too much is attempted to be preserved 🙂
        I do understand this isn’t exactly the desirable situation too but we unfortunately do not have control about the rerouting logic for tracks in that level of detail (compared to route navigation).
        Jörgen 1 Reply Last reply
          Jörgen Offline
          Jörgen Offline
          @Corjan-Meijerink One question, did I properly miss the start point and was this the reason I was guided back?
            @Jörgen probably
              GT JWR Offline
              GT JWR Offline
              @Jörgen I've experienced that as well, and while my route had numerous possibilities, the app insisted, for 23mi, that I do a u-turn and go back....makes it hard to 'trust' the app 😕
              https://forum.myrouteapp.com/post/49267
              • GT JWR GT JWR
                @GT-JWR : @Jörgen
                Recommendation only the 1.) s. Image to use if you want to remain flexible and still want to keep an eye on the goal.
                • 1.) this is a route that is adjusted again and again when leaving
                • 2.) , 3.) and 4.) are fixed tracks / tracks that are absolutely to be driven, the app leads you hard back to the exit point when you leave and from there you only kindly continue without an announcement...
                @Corjan-Meijerink 👋
                Suggestion: also 2.) should be a route with a higher proportion of curves than under 1.).
                Under 1.) it is still unclear to me with which avoidances the route will probably be calculated. Setting motorcycle and then?
                This should also be supplemented by avoiding under 1.). 👋
                GT JWR Hubert Thoring 2 Replies Last reply
                  @GT-JWR : @Jörgen
                  @Corjan-Meijerink 👋
                  GT JWR Offline
                  GT JWR Offline
                  @Hubert-Thoring thanks for the input. In my example, it was a very simple A-B route, and the fact that it did not reroute after a couple of miles, to me, was extremely odd. There were no waypoints, just a start and a finish. (see the link, it explains what was going on, complete with screen shots).
                    @GT-JWR : @Jörgen
                    @Corjan-Meijerink 👋
                    @Corjan-Meijerink : Eine Bitte könntest Du das von zuvor noch beantworten ?
                      @Hubert-Thoring to what?
                      What you state in the image is indeed correct.
                      Fastest option is A-B route navigation.
                      Rest is track navigation.
                        @Corjan-Meijerink : Sorry … Die Frage ist leider noch offen geblieben.
                        • Könnte man in der 1.) A-B Route Navigation diese Auswahl s. Bild als mögliche Auswahl wohl ergänzen ❓
                        • Oder geht das nur in der reinen Track Navigation ❓
                          @Hubert-Thoring as the options are only available in track navigation that is indeed by design 😉
                          The route navigation by HERE don’t support these settings.
                            @Corjan-Meijerink : Hey Corjan, Herzlichen Dank für die klare Antwort. Ich werde es allen meinen Freunden so erklären 👋 Dir weiterhin viel Erfolg beim + MRA Route Thema, das ist auch eine schnelle Möglichkeit für unterwegs jetzt schön zu fahren
                            Danke auch dafür 👋
                            • Jörgen Offline
                              Jörgen Offline
                              Hi, I used an A to B Track (curvy Route) and deviate from the org. Track.
                              And now there was a recalculation to get back to the track. 😳
                              What happened? How is this possible? Was there some change since beginning of July.
                                @Jörgen nothing 😉
                                It all depends on the track and where you deviate.
                                • Jörgen Offline
                                  Jörgen Offline
                                  @Corjan-Meijerink Ok, thanks. I was very surprised
                                  I thought something had changed.
                                  Then it would be nice to know when a recalculation takes place and when not?
                                  Or what a recalculation depends on.
                                    @Corjan-Meijerink :
                                    @Jörgen
                                    I tested the topic of track today with Guru Maps and MRA, there is a positive other behavior with Guru Maps maybe this is an idea that can be found in MRA 🤔
                                    • Route remains as it is
                                    • Position is displayed with the straight but shortest dashed line to the route
                                    • Distance position to the track as the shortest connection
                                    • you can drive and only get the audio hint once to return to the route
                                    • it is probably always a dashed line that shows the shortest connection, on which ges. Route to the deviation of the actual track
                                    • if you are back on the track then it goes normally to the destination
                                    I deliberately just drove out of there
                                    Then shortly afterwards comes the announcement, which is also as text in the display at the top
                                    Then the new reference line to the track comes a little later ...
                                      @Corjan-Meijerink :
                                      @Jörgen
                                      Nick Carthew Online
                                      Nick Carthew Online
                                      @Hubert-Thoring Please use the language of the topic. In this case it is in English.
                                        @Nick-Carthew Okay, it's done
                                        • "The selected profile only works in the HERE / TomTom map"
                                          siebo vd berg
                                          siebo vd berg
                                        • Transport modes?
                                        • Navigation Route Line Colour
                                        • Little issues, night mode in tunnel, recalculation
                                        • No navigation instructions
                                          Hans-Udo Erdmenger
                                          Hans-Udo Erdmenger
                                        • Google maps and Streetview
