  3. [Web] Announcements
  4. Route overview improvements!
42 Posts 15 Posters 39.5k Views 7 Watching
  • Dae 0
    Dae 0
    Dae 0
    This is fantastic and a feature that I really missed from using Basecamp.
    What would take it to 11 out of 10 would be a toggle to automatically show the other routes stored in the same folder as the one that the route that you are editing is stored. This was the fantastic thing about Basecamp. As my routes are stored in folders corresponding to areas, I could highlight a folder that covers the rough area I’m interested in and see all routes in that folder/area.
    It can be done using your new functionality, but would currently require manually adding all the routes in the folder to all the other routes in the folder, so would grow exponentially as the number of routes increases.
    Hubert Thoring CD130 3 Replies Last reply
    • Dae 0 Dae 0
      @Dae-0 said in Route overview improvements!:
      Jetzt kann man eine Option leicht einblenden, Schotter Pass Abkürzung zum Beispiel ..
      • Dae 0 Dae 0
        @Dae-0 Dein Vorschlag ist auch sehr Guter Verschlag !!
        • Dae 0
          Dae 0
          Dae 0
          Sorry. I only speak English or Spanish
          • HighPeakRider
            HighPeakRider
            HighPeakRider
            Very good, but i’m still exporting mine into basecamp to get an overall view, I mainly ride in the peak district and it makes it easy to pick an old route to ride or plan somewhere that’s not been ridden.
            I guess the next challenge is to be able to select a folder and have a ‘View All’ option.
            Dae 0 1 Reply Last reply
              Good afternoon! 👋
              After the massive app update that included the new in-app Routeplanner, we dedicated some time to the website MRA Routeplanner 🎉
              In the latest website update we improved the POI functionality.
              This update now improves the route overview possibility.
              A big frustration for a lot of users was that while adding additional routes to a route, you had to do this over every single time, the colours would be the same and you had to start searching all over again every time. These issues have all been solved 💪
              In the image above, you can see I am creating a route and 2 others are shown (nothing new). If I however reload the page / use another device, these same added routes are still displayed with the selected color 💥
              If I add a tracklog, this will get a random color assigned and also shown on the map.
              You can still add more routes / tracks and change the colours as you are used too!
              Simply use the applicable menu.
              If you choose to add another route, the same folder as where you were before will open 😏
              This minor yet awesome improvement will make your planning life just a bit more convenient.
              Note: the app won't show additional routes
              Best,
              Corjan ❤
              @Corjan-Meijerink I am super impressed .....
              I only requested this exact feature a few days ago 😂 😂
              @Brian-McG said on 29 July 2024 in Route-overlay switching:
              Hi @Thomas-Schäfer I also use the overlay routes & my process is very similar to yours
              a big frustration I have with this process is that the overlay routes I have carefully added are lost when I click away, it is a long proces to keep adding & re-adding the same routes
              it would be nice if there was a selection like in the new POI menu where you could select the overlay to be remembered & this selection was stored with the route
              If all features are implemented at this speed MRA is going to be truly awesome 😂 😂
              • HighPeakRider HighPeakRider
                Dae 0
                Dae 0
                Dae 0
                @HighPeakRider That’s exactly my use case and the suggestion I made above 😀
                Show all the roads in a particular area that are covered by existing routes, and then either choose a route that covers a road I fancy riding, or create a new route that goes on a road that none of my existing routes use.
                • Dae 0 Dae 0
                  Totally agree. That would make the pleasant update even better 👍
                    Good afternoon! 👋
                    Best,
                    Corjan ❤
                    @Corjan-Meijerink this is awesome, great update!
                    One of my primary uses of this feature will be to communicate about multi-day trips with other participants. In that light, it would be great if the added routes would also persist when adding the route to a group or event. Or even better (as others have mentioned), if that could be automated so there's an automatic overview of the routes in the group or event.
                    But it's already great to be able to do it once for my own routes and then have it persist.
                    Brian McG 1 Reply Last reply
                      Your wish, is my command 😃
                      Showing all* data in a folder** with one click coming up! 🎉
                      *Limit of 20 items per time due to keep things working kinda smoothly
                      **Not including contents from subfolder
                      CD130 1 Reply Last reply
                        There we go! 🎉
                        https://forum.myrouteapp.com/topic/7533/further-route-overview-improvements
                          @Corjan-Meijerink Wow, fantastic, really very happy with it!!
                          Now the possibility for subfolders. Nice challenge for the future 👍👍
                          • HighPeakRider
                            HighPeakRider
                            HighPeakRider
                            @Corjan-Meijerink Your a star.........thank you...
                            • CD130 CD130
                              @CD130 thanks! 🙂
                              Won’t happen. Not so much about the challenge but just severely complicates stuff regarding performance / experience.
                              If you want a subfolder added, it’s just 2 clicks (open folder & add all) - not worth it to automate 🙂
                              Brian McG CD130 2 Replies Last reply
                                @CD130 thanks! 🙂
                                @Corjan-Meijerink amazing work 👏
                                for you next miracle trick could you add a visibilty check box for each of the additional added routes, something similar to how we can select which sets of Point of Interest to show on the map
                                the reason I ask is sometimes the added routes will overlap the main route that is being planned, you can then loose where the main route goes as you are not sure which added route it is hidden under
                                I think the only way to refind the main route at the moment is to remove the added routes which takes us back to the scenario of having to re-add routes
                                I do have to say the new sticky visibilty of added routes is a brilliant "addition" to the web planner, it will save me hundreds if not thousands of clicks & tens & tens of minutes over a year. Many thanks 👏 🍻 👏
                                • paul69
                                  hi @Corjan-Meijerink
                                  you seem to be acting on almost every wish, could you point me to every bar that sells free beer with chips and curry wurst 🤣
                                  K1600 GTL
                                  Oukitel RT3
                                  iPhone 13 Pro, carpuride 702b
                                  paul69 Corjan Meijerink 2 Replies Last reply
                                    @CD130 thanks! 🙂
                                    @Corjan-Meijerink What I would find very cool is the ability to see the entire library in one overview. This way I can easily see if I have driven a certain road before. I thought this would be possible by adding subfolders, but so the problem is more in the limit of 20 routes? Hope this is still possible in the future. I think @HighPeakRider indicates the same wish.
                                    But, as mentioned, this is already a fantastic update 👍👊
                                    • paul69 paul69
                                      @paul69 said in Route overview improvements!:
                                      wrong grammar, you can't sell free beer, 😂
                                      K1600 GTL
                                      Oukitel RT3
                                      • paul69 paul69
                                        @paul69 come by the office! 😉
                                        paul69 1 Reply Last reply
                                          @Corjan-Meijerink said in Route overview improvements!:
                                          come by the office!
                                          it's a date sir
                                          K1600 GTL
                                          Oukitel RT3
                                          Dae 0
                                          Dae 0
                                          HighPeakRider
                                          HighPeakRider
                                          Tim Verhaaf
                                          Tim Verhaaf
                                            Sam Kramer
                                            Sam Kramer
                                          • Routenplaner on iPad
                                            Risto Motorcycling
                                            Risto Motorcycling
                                          • Missing info from CarPlay
