  3. [Web] Announcements
  4. Route overview improvements!
42 Posts 15 Posters 41.3k Views 7 Watching
    Good afternoon! 👋
    After the massive app update that included the new in-app Routeplanner, we dedicated some time to the website MRA Routeplanner 🎉
    In the latest website update we improved the POI functionality.
    This update now improves the route overview possibility.
    A big frustration for a lot of users was that while adding additional routes to a route, you had to do this over every single time, the colours would be the same and you had to start searching all over again every time. These issues have all been solved 💪
    In the image above, you can see I am creating a route and 2 others are shown (nothing new). If I however reload the page / use another device, these same added routes are still displayed with the selected color 💥
    If I add a tracklog, this will get a random color assigned and also shown on the map.
    You can still add more routes / tracks and change the colours as you are used too!
    Simply use the applicable menu.
    If you choose to add another route, the same folder as where you were before will open 😏
    This minor yet awesome improvement will make your planning life just a bit more convenient.
    Note: the app won't show additional routes
    Best,
    Corjan ❤
    Stefan Hummelink Bart De Medts MotoCon Hubert Thoring BMcG 6 Replies Last reply
      Good afternoon! 👋
      Best,
      Corjan ❤
      @Corjan-Meijerink this is a huge one! Woa! 😎♥️
        Good afternoon! 👋
        Best,
        Corjan ❤
        @Corjan-Meijerink cool update!
        • Stanisław
          Wow, this is a brillant improvement, very useful, thank you!
          Staszek
            Cool, super update! Thanks
            What is the maximum of additional routes?
              @Jörgen said in Route overview improvements!
              This is your challenge should you accept to take it on 😁
              Jörgen 1 Reply Last reply
                @Nick-Carthew said in Route overview improvements!:
                👍 Not today.
                Could be interesting to get an overview of my routes for e.g. the Eifel. 😁
                  Good afternoon! 👋
                  Best,
                  Corjan ❤
                  @Corjan-Meijerink, this is a nice one! Again! 😉
                    Good afternoon! 👋
                    Best,
                    Corjan ❤
                    @Corjan-Meijerink said in Route overview improvements!:
                    @Corjan-Meijerink : Herzlichen Dank, ich plane gerade Italien und Slowenien, und wurde davon bei der Arbeit überrascht. Vielen Dank dafür. Schön wenn die Routen in Sichtfeld verbleiben, also mit gespeichert werden, das hilft sehr. 😎
                    • Dae 0
                      Dae 0
                      Dae 0
                      This is fantastic and a feature that I really missed from using Basecamp.
                      What would take it to 11 out of 10 would be a toggle to automatically show the other routes stored in the same folder as the one that the route that you are editing is stored. This was the fantastic thing about Basecamp. As my routes are stored in folders corresponding to areas, I could highlight a folder that covers the rough area I’m interested in and see all routes in that folder/area.
                      It can be done using your new functionality, but would currently require manually adding all the routes in the folder to all the other routes in the folder, so would grow exponentially as the number of routes increases.
                      Hubert Thoring CD130 3 Replies Last reply
                      • Dae 0 Dae 0
                        @Dae-0 said in Route overview improvements!:
                        Jetzt kann man eine Option leicht einblenden, Schotter Pass Abkürzung zum Beispiel ..
                        • Dae 0 Dae 0
                          @Dae-0 Dein Vorschlag ist auch sehr Guter Verschlag !!
                          • Dae 0
                            Dae 0
                            Dae 0
                            Sorry. I only speak English or Spanish
                            • HighPeakRider
                              HighPeakRider
                              HighPeakRider
                              Very good, but i’m still exporting mine into basecamp to get an overall view, I mainly ride in the peak district and it makes it easy to pick an old route to ride or plan somewhere that’s not been ridden.
                              I guess the next challenge is to be able to select a folder and have a ‘View All’ option.
                              Dae 0 1 Reply Last reply
                                Good afternoon! 👋
                                Best,
                                Corjan ❤
                                @Corjan-Meijerink I am super impressed .....
                                I only requested this exact feature a few days ago 😂 😂
                                @Brian-McG said on 29 July 2024 in Route-overlay switching:
                                Hi @Thomas-Schäfer I also use the overlay routes & my process is very similar to yours
                                a big frustration I have with this process is that the overlay routes I have carefully added are lost when I click away, it is a long proces to keep adding & re-adding the same routes
                                it would be nice if there was a selection like in the new POI menu where you could select the overlay to be remembered & this selection was stored with the route
                                If all features are implemented at this speed MRA is going to be truly awesome 😂 😂
                                • HighPeakRider HighPeakRider
                                  Dae 0
                                  Dae 0
                                  Dae 0
                                  @HighPeakRider That’s exactly my use case and the suggestion I made above 😀
                                  Show all the roads in a particular area that are covered by existing routes, and then either choose a route that covers a road I fancy riding, or create a new route that goes on a road that none of my existing routes use.
                                  • Dae 0 Dae 0
                                    Totally agree. That would make the pleasant update even better 👍
                                      Good afternoon! 👋
                                      Best,
                                      Corjan ❤
                                      @Corjan-Meijerink this is awesome, great update!
                                      One of my primary uses of this feature will be to communicate about multi-day trips with other participants. In that light, it would be great if the added routes would also persist when adding the route to a group or event. Or even better (as others have mentioned), if that could be automated so there's an automatic overview of the routes in the group or event.
                                      But it's already great to be able to do it once for my own routes and then have it persist.
                                      BMcG 1 Reply Last reply
                                        Your wish, is my command 😃
                                        Showing all* data in a folder** with one click coming up! 🎉
                                        *Limit of 20 items per time due to keep things working kinda smoothly
                                        **Not including contents from subfolder
                                        CD130 1 Reply Last reply
                                          There we go! 🎉
                                          https://forum.myrouteapp.com/topic/7533/further-route-overview-improvements
                                          Tim Verhaaf
                                          Tim Verhaaf
                                          Dae 0
                                          Dae 0
                                          HighPeakRider
                                          HighPeakRider
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            Hanza 0
                                            Hanza 0
                                          • 1 bij app icoontje
                                            Jack 13
                                            Jack 13
                                          • Weather as a service
                                            Jack 13
                                            Jack 13
                                          • Units of Measurement
                                          • Eindtijd zichtbaar.
                                            Ruurt Visser
                                            Ruurt Visser
