  4. Route-overlay switching
4 Posts 3 Posters 2.1k Views 2 Watching
  • Thomas Schäfer
    Thomas Schäfer
    Thomas Schäfer
    I am slowly developing my workflow for planning with MRA.
    I use routes I have travelled in the past as a ‘painting template’ for my new routes. As I rarely ride an old route 1 to 1, the function of using an old track as a route is of little use to me.
    I proceed as follows:
    To plan a day trip in the Harz Mountains, for example, I use the overlay function to place 2 to 3 old routes on the screen and then click together a new route from these templates.
    As the display of the old routes (coloured via the colour selector) and the new route (black) are the same width, they cover each other, so it doesn't matter which one is on top.
    It would be nice if you could switch the overlay routes on and off with a click. If I click away an overlay route, it is completely deleted from the screen and I have to show it again in several steps.
    I hope I was able to explain my idea clearly.
    Freundliche Grüße/Kind regards/Met vriendelijke groeten
    Thomas
    • Thomas Schäfer Thomas Schäfer
      @Thomas-Schäfer Have you tried using the route line transparency option in the toolkit?
      Thomas Schäfer 1 Reply Last reply
        Thomas Schäfer
        Thomas Schäfer
        Thomas Schäfer
        I have tried this, but it reduces the visibility of my planning route or sets it to zero. However, I would like to dim the routes used as an overlay.
        Thomas
        Brian McG 1 Reply Last reply
          Hi @Thomas-Schäfer I also use the overlay routes & my process is very similar to yours
          a big frustration I have with this process is that the overlay routes I have carefully added are lost when I click away, it is a long proces to keep adding & re-adding the same routes
          it would be nice if there was a selection like in the new POI menu where you could select the overlay to be remembered & this selection was stored with the route
          Thomas Schäfer
          Thomas Schäfer
            rpluckengmail.com
            rpluckengmail.com
          • Kaart niet zichtbaar
          • Google maps
          • RouteXpert display on the map
            Corrado Miniati 0
            Corrado Miniati 0
            Tim Verhaaf
            Tim Verhaaf
          • Disabling Waypoints?
            Jannes van Dijken
            Jannes van Dijken
            Emanuele 5
            Emanuele 5
            2.1k
          • Comparison route remains on map
