  4. Follow up about my first test of the new version (4.2.0)
21 Posts 9 Posters 6.2k Views 3 Watching
  • paul69
    hi,
    new version update
    i have just returned from an 8 day trip around the highlands of Scotland.
    All my maps and routes were dowloaded prior to leaving.
    all navigation was done offline. MRA did not let me down at all, except on one of the trips,
    for some reason it tried to get me to do a u-turn for two waypoints that i know i passed on my route. eventually it automatically skipped both of them. I checked the route and the waypoints were placed exactly in the middle of the road and there were no diversions. unsure why this happened.
    one of my routes had to be changed due to a road closure, fortunately i found this out the night before so managed to amend the route, and i used the MRA routplanner, in the next app, i could use this as i am a beta tester, this was very easy to use and worked perfectly the next day when I drove the route.
    i can only speak from experience but MRA worked very well this time, i have now definitely stopped using all other navigation devices for planning and touring,
    thanks @Corjan-Meijerink and the team,
    i know this will not be much help to @Michael-Doherty-0 but you should try to stick with it as this app really works well. there will be reason you had issues, and once you get to the bottom of these i believe you will be a happy teddy.
    K1600 GTL
    Oukitel RT3
    iPhone 13 Pro, carpuride 702b
    Corjan Meijerink Michael Doherty 0 2 Replies Last reply
    • Michael Doherty 0 Michael Doherty 0
      @Corjan-Meijerink I used to be able to Open the route, press the compass button twice to have a 3D view and then follow the line. Simple, easy. Now pressing the compass button twice just shows a DOT. When i try following the DOT the map wont track and the DOT goes off the edge of the map.
      @Michael-Doherty-0 why not just start the active navigation? 😉
      Michael Doherty 0 1 Reply Last reply
      • paul69 paul69
        hi,
        new version update
        @paul69 that is absolutely amazing to hear! 🙂
        Thanks for the positive feedback. Waypoints might very incidentally not be marked as visited when in really poor reception / just by chance. Great the app solved it by itself! 😃
        Happy that the in-app planner did its work too! 🎉
          Michael Doherty 0
          Michael Doherty 0
          Michael Doherty 0
          @Corjan-Meijerink I DO USE THE NAVIGATION. while NAVIGATING...it randomly STOPS....asks me " DO YOU WANT TO CONTINUE"... I click "CONTINUE" this wen the app crashes. I have to close the app, restart it. and get back to my route. Im sorry if i seem frustrated. But having people tell me it works fine for them , does not fix the issues i an having.
          paul69 1 Reply Last reply
          • paul69 paul69
            hi,
            new version update
            Michael Doherty 0
            Michael Doherty 0
            Michael Doherty 0
            @paul69 I have years of experience with MRA.. I started back in the Trye To Travel Days
              @Michael-Doherty-0 said in Follow up about my first test of the new version (4.2.0):
              and that is what i wrote, once you find out why the issues occur, it will be good, it wasn't to rub your face in it, i was merely writing some feedback.
              K1600 GTL
              Oukitel RT3
                I uninstalled, re-started my Android phone, then re-installed. After downloading all necessary maps and re-configuring the app nothing changed 😞 The function i used most with the previous version still does not work. For me, NOT using the navigation was the best way to do motorcycle rides. But now with the new version, after opening the ride, i no longer can touch the compass button to zoom in to a 3D view and follow the line. It will not track on the map. Using the Navigate feature, it get random "do you want to continue" messages while riding, causing the app to crash. The app seems unstable. I and NOT a computer/phone engineer. i AM an expert motorcycle racer/rider with 55 years in the saddle. My initial impression is that MRA has become to complicated and has to many features that motorcyclists don't need. Simplicity is a motorcyclists friend. But that is just my opinion. I will continue to experiment with it going forward, but will use my second phone and another app as back up for the rest of the riding season. Thank you for the suggestions in my previous post. - MikeD
                Ton Verkleij
                Ton Verkleij
                Ton Verkleij
                @Michael-Doherty-0 It looks like them navigation app was designed and runs fine on apple car play and then converted to android auto, with all kinds of problems following.
                It's just a small company with a few developers so progress is slow.
                -4
                • Ton Verkleij Ton Verkleij
                  @Ton-Verkleij outright not true.
                  Wouldn’t call progress slow to be fair. For a small team an amazing amount of work is being done.
                  Micheal Jennings Michael Doherty 0 2 Replies Last reply
                    Micheal Jennings
                    Micheal Jennings
                    Micheal Jennings
                    The App crashes for me each time I open music app Spotify, go back to route-app and its blank.
                    I now have to invest in other software for my 10 day ride next month, looks like I will have to invest in Calimoto to ensure I get there and back.
                    This is the only long ride this year so hopefully they can get some of these bigger bugs squashed by then.
                      @Michael-Doherty-0, The dot follows you, not the other way around 😉 You should not press the compass twice, but only once, for the arrow to become full black instead of outlined.
                      @Corjan-Meijerink, can it be that the 3D view in "follow the line" mode has been deprecated? I think Michael has a point here. I don't get the 3D view either, but to be honest I can't remember if it was there before... 😉
                        This is a nice Freudian slip 😉
                          Michael Doherty 0
                          Michael Doherty 0
                          Michael Doherty 0
                          @Corjan-Meijerink I have been through this sort of thing before. An upgrade to an app is released and it does not work for everyone. I understand it is close to impossible to diagnose technical problems from halfway around the world on someone else phone. So far nobody has offered any suggestions of specific settings or possible causes to look into. I cant be the only person that is having issues.
                          Being mid-season, when i have rides planned, i will switch over to another app that i use as a back up. I will revisit MRA another time when riding season is over. Hopefully by then what ever issue i am having might be fixed in a future release. It is just a shame this happened now. I am sure engineering this app to work perfectly for everyone is a challenge.
                          Michael Doherty 0
                          Michael Doherty 0
                          versluis
                          versluis
                          Ton Verkleij
                          Ton Verkleij
                          Micheal Jennings
                          Micheal Jennings
                          • Voice commands cut off or become very quiet halfway through
                            Kevin Bird
                            Kevin Bird
                          • Statement on map spinning
                            3.5k
                          • F02 MRA 6.0.0 (526) Selection - back to the app
                          • Change route color
                          • MRA 6.0.0 (526) - Remotek One Functions and Big Buttons on iPhone with CarPlay
                          • First time version 6 and AA
                          • Some minor improvements ;-)
