  3. [App] Announcements
  4. New update! (4.2.0) In-app MRA Routeplanner
45 Posts 19 Posters 29.7k Views 8 Watching
    @Cookie-On-Tour, These ARE the release notes 😉
    Cookie On Tour Offline
    Cookie On Tour
    @Con-Hennekens said in New update! (4.2.0) In-app MRA Routeplanner:
    LOL okay, so no improvements or fixes to the sound issues....
    Joerg
    (Cookie-On-Tour.de)
    • Cookie On Tour Cookie On Tour
      Corjan Meijerink Online
      @Cookie-On-Tour correct 😉
        Good morning MyRoute-app users!
        We are proud to announce the upcoming release of the in-app MRA Routeplanner 🎉
        After elaborate testing by the Alpha and Beta testers, we are confident that this will be an epic release 💥 With pride we present the in-app MRA Routeplanner to you!
        With this routeplanner you can edit your high quality MRA routes with an interface it deserves.
        • Edit any existing route! 💪
        • Create a new route from scratch
        • Change routes from others
        • All this can even be done offline! 🎉
        The Routeplanner offers many features to help you in building lovely routes.
        Quickly keep adding waypoints to your route to shape the route to your preference.
        • Yellow button starts the adding process and keep tapping it to continuously add waypoints
        • Click add to add a new waypoint and stop adding more
        • Cancel, dismiss what you are doing
        If you make a mistake, no problem! Simply use the undo / redo buttons like you are used to in the website 😉
        Do you want to add information to waypoints? Ofcourse you can do so! 🎉
        Change the colour, type, note, title, pause duration or even the icon of the waypoint! 😮
        Do you want to add a waypoint somewhere along the route? Obviously that's possible too!
        • Tap somewhere along the line to add a waypoint there in order of the route
        • Long press and drag a line to immediately move the marker you are adding in that leg
        Do you need to move a waypoint precisely? Simply use the advanced move interface to place the waypoint exactly where you want. Long pressing and dragging the waypoint works too but that is less precise 🙂
        Then we also allow you to change any of the other settings.
        • Edit the name / description of the route.
        • Alter the privacy / travel mode
        • Avoid specific type of roads
        • View all the waypoints
        Talking about waypoints! Did you know you can drag the waypoints shown in the list to reorder them? 😏 When you've opened a waypoint you can also swipe left / right to jump to the previous / next waypoint 😮
        That's it really!
        So in short:
        • Create new routes from scratch
        • Edit any route
        • Access to our unique MRA Routeplanner features in-app
        • Modify waypoints
        • Change route information / details / options
        Feel free to discover all other features yourself 😉
        Isn't this an amazing update??? We have put a lot of focus in the visual appearance and user experience of this planner so we hope you are satisfied.
        In the upcoming update we will rework your route library to enable easy syncing of all your routes. Meaning that offline created routes will be synced to the website when online again, you can automatically sync routes / your entire library between website and app! 🎉 But that's for later 😉
        If you got any feedback, feel free to share it on this forum 🙂
        Best,
        Corjan
        Team MRA ❤
        marc van der heijden Offline
        @Corjan-Meijerink ik had anders meteen problemen, app liep vast nadat ik wilde proberen ( weet niet of het überhaupt kan ) route overslaan functie, app crashte en kon helemaal opnieuw beginnen want zelfs de route werd niet opgeslagen zoals dat normaliter wel het geval was
        Marinus van Deudekom Corjan Meijerink Con Hennekens 3 Replies Last reply
        • paul69 Offline
          paul69 Offline
          hi @Corjan-Meijerink
          i managed to use the in-app routeplanner while touring recently due to a road closure, i had to re-plan the next day's ride and i must report that it worked extremely well, and it was very easy to use, excellent bit of work MRA gang
          • marc van der heijden marc van der heijden
            @marc-van-der-heijden jammer dat de app vastliep. Je moet bij de in app planner de route wel opslaan anders dan in de web versie. Die stap heb je niet kunnen doen dus ook niks opgeslagen.
              @marc-van-der-heijden dat kan ook gewoon gebeuren hoor 😉 Gaat vaker goed dan fout en foutjes zijn op te lossen. Heb je bij je andere bericht al gevraagd of het te reproduceren is.
              • paul69 paul69
                @paul69 awesome! 🙂
                  @marc-van-der-heijden said in New update! (4.2.0) In-app MRA Routeplanner:
                  Gebeurde dat direct na de app update? Ik heb wel vaker gemerkt dat direct na een update niet alles vlekkeloos werkt. In mijn beleving komt dat door het updaten van een draaiende app. Ik maak er een goede gewoonte van om na een update de app een keer geforceerd te sluiten (niet wegswipen, maar force-close vanuit de Android settings - apps). Een reboot zou natuurlijk hetzelfde resultaat hebben.
                  marc van der heijden 1 Reply Last reply
                  • Richard 18 Offline
                    Richard 18 Offline
                    Richard 18
                    Great work.
                    Thank you for all the effort put in.
                    Richard
                    • Marius Gross Offline
                      Marius Gross
                      Hallo, ich finde die offline Planung als gelungen und hilft mir sehr bei doch noch einigen Standorten mit schlechtem oder keinem Internet. Einen grossen Haken hat es aber für mich immer noch.
                      Ich plane die langen Strecken lieber auf einem Tablet als auf dem Smartphone. Wenn ich nun auf dem Tablet im Offline Modus plane und danach die Route speichere, wird diese bei den Downloads nur auf dem Tablet gespeichert. Ich habe bisher keine Möglichkeit gefunden, diese Route auf dem Smartphone für die Navigation zu speichern oder sogar als Export auf das Garmin Zümo XT2 (via Tread App) zu bringen.
                      Habe ich etwas übersehen?
                      Corjan Meijerink Dirk Kevin K. 2 Replies Last reply
                      • Marius Gross Marius Gross
                        @Marius-Gross no that’s correct!
                        We need to implement that and will be added in the next update 🙂
                        For now a workaround is to modify the route from the downloads folder when you got internet and then you will be able to save it online too!
                          vanuit Android ken ik het, in de iPhone is het volgens mij gewoon app sluiten, ik sluit sowieso vaak apps
                            Rob Verhoeff Offline
                            #33
                            Op de iPhone moet je vanaf de onderkant van het scherm omhoog vegen. Daarna swipe je naar links of rechts om de app te zoeken die je wilt stoppen. Als je de app dan in beeld hebt in de voorvertoning, dan veeg je die app naar boven om hem gedwongen te stoppen.
                            Ik laat ze altijd actief. Op een iPhone is het onnodig om je apps af te sluiten. Vaak wordt gedacht dat het de batterijduur verlengt als je een app volledig afsluit. De meningen zijn daarover verdeeld maar Apple zelf zegt dat het alleen nodig is als een app niet meer reageert.
                              That's it really!
                              So in short:
                              • Edit any route
                              • Modify waypoints
                              Best,
                              Corjan
                              Team MRA ❤
                              JP d Offline
                              JP d Offline
                              JP d
                              @Corjan-Meijerink any chance of adding the Google maps skin to the planner? Using the existing colour scheme makes it hard to distinguish what's what. Thanks 🍻 🇬🇧
                              paul69 Con Hennekens GT JWR 4 Replies Last reply
                              • JP d JP d
                                paul69 Offline
                                paul69 Offline
                                • JP d JP d
                                  @JP-d, If overlays are made available, I would prefer Michelin 😉
                                  • JP d JP d
                                    paul69 Offline
                                    paul69 Offline
                                    hi @JP-d
                                    i did reply to you your post but then realised you were referring to the in-app routeplanner and not the web planner,
                                      Dirk Kevin K. Offline
                                      Dirk Kevin K.
                                      Guten Abend @Marius-Gross
                                      Wenn du ein iPad nutzt dann kannst du die Route via AirDrop an das iPhone schicken oder bei Android existiert Quick Share oder du Installierst dir die Tread App auf Tablet und verbindest dich mit dem Zumo XT2.
                                      iPhone 15 Pro (iOS 18.4.1)
                                      iPad Pro (iPadOS 18.4.1)
                                      MyRoute-APP (5.1.0 - 462), All-Lifetime)
                                      Honda NC750S DCT / Carpuride W502 / Garmin XT
                                      BMW F800R / Carpuride W702B / Navigator VI
                                      SENA 50S / Cardo Packtalk Edge
                                      Marius Gross 1 Reply Last reply
                                      • JP d JP d
                                        GT JWR Offline
                                        GT JWR Offline
                                        #39
                                        @JP-d 2nd the Google Maps overlay. It shows much more road way options.
                                        • Brian McG Offline
                                          Brian McG Offline
                                          @JP-d  I agree more options in the App RoutePlanner would be great,
                                          as the App RoutePlanner is new I am sure this will fill out in time & I hope that along with map layers they are able to include the comparison of routes between the different routing algorithms, Here, TomTom & OPenStreetMap
                                          for me the route comparison function is probably the greatest asset/selling point of MRA as I create routes for groups of riders with multiple different navigation devices
                                          @Con-Hennekens the Michelin map layer is nice, I used the paper versions for many years, the green highlighted roads were a must ride 😀
                                          Now for me a beautiful map layer in MRA is the OpenTopo map, I think the detail / contrast is great for showing twisty roads. It is just a shame the server can be slow to deliver the tiles
                                          Ruurt Visser
                                          Ruurt Visser
                                          JP d
                                          JP d
                                          Richard 18
                                          Richard 18
                                          Cookie On Tour
                                          Cookie On Tour
                                          Tom Grzelinski
                                          Tom Grzelinski
                                          Marius Gross
                                          Marius Gross
                                          Paulusma
                                          Paulusma
                                          versluis
                                          versluis
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Benny Van de Velde
                                          Benny Van de Velde
                                          Stuart Greer
                                          Stuart Greer
                                          • Welke instelling
                                            1.1k
                                          • The slow death of Zumo...
                                          • opslaan naar plantomtom
                                            chris 18
                                            chris 18
                                          • Rejoining routes
                                            Carl Lee
                                            Carl Lee
                                            Terry Cox 0
                                            Terry Cox 0
                                            Karl-Heinz Schwendner
                                          • New Zealand Touring Group
