  3. [App-Beta] Announcements
  4. Updated beta v4.2.0 (321)
21 Posts 7 Posters 268 Views 5 Watching
    @Hubert-Thoring no longer fun? Sorry?
    It’s not that all items someone lists are immediately all processed 😉
    The major issue in 320 was that being fully offline was not working as expected. The entire downloads / offline availability of is being restructured for the next update.
    Track navigation never worked offline ever, that’s not supported due to technical limitations 🙂
    I honestly believe this is a great upcoming update 🎉
    @Corjan-Meijerink :
    @Con-Hennekens :
    Corjan sorry, what is when and how turn or the track does not go offline should then be communicated better. That's what I don't know.
    Note:
    Even in the current update for all users, there should be no possibility at all to get into a wrong state that ends with error messages. That scares new users off, doesn't it?
    Good luck in the future 👋
      @Con-Hennekens and that is why we made the change. Most won’t notice 🙂
      Android 4.2.0 - 321 is now available. 👍
        @Corjan-Meijerink :
        @Con-Hennekens :
        Note:
        @Hubert-Thoring, You are writing riddles... And what is that about a wrong state?
          So mal ohne Übersetzer:
          Corjan tut mir leid, was wann und wie geht, und das der Track nicht offline geht, sollte dann besser kommuniziert werden. Das war mir so nicht bekannt.
          Hinweis:
          Selbst im aktuellen Update für alle Benutzer sollte es überhaupt keine Möglichkeit geben, in einen falschen Zustand zu geraten, der mit Fehlermeldungen endet. Das schreckt neue Benutzer doch ab oder ?
          Viel Glück in der Zukunft!
          • Jaap van Maanen
            Jaap van Maanen
            Jaap van Maanen
            wrote on last edited by Jaap van Maanen
            Very nice and welcome update. For a future update please consider the following:
            • an option to select a different map style. With current map is hard to see the different road types
            • make an option to save the default route options. I never use dirt roads and hardly use highways. Now I have to select them again for every new route. BTW, this is the same on the website.
            • Is routing based on the Here maps or on the OpenStreet maps.
            • Add an option to select curvy roads
            Thanks again for the great work.
            Stefan Hummelink MotoCon 2 Replies Last reply
            • Jaap van Maanen Jaap van Maanen
              @Jaap-van-Maanen said in Updated beta v4.2.0 (321):
              Here
              Based on HERE since those are the maps you download for offline usage, and the nav engine uses HERE SDK.
                Hinweis:
                @Hubert-Thoring, I can only conclude that your reply holds no relevance to the topic you are replying on.
                  Yes, map layers would be welcome. But I don't think the app is intended as a replacement of the full featured web planner. Not all functions will find a place in the app planner.
                  Routing is based on the HERE map indeed. The app planner uses the same SDK as the navigation module does. Hence you will find ONLY the here map in the app planner, and you need a Navigation licence.
                  HERE does not offer that feature (yet). In the roundtrip feature this is mitigated by using OSM for generating the curvy route and feed it to the routing engine as a track. Within the HERE planner it is not possible to do the same trick.
                    @Corjan-Meijerink : Einfach noch mal vielen vielen Dank für die Tolle App 👋 bin begeistert jeden Tag wenn ich die App am Motorrad nutzen darf.
                    Das Update auf V 4.2.0 ist eine tolle Leistung, Dankeschön 🙏 dafür ❗️
                      @Hubert-Thoring nice to hear that! 🙂
                      Jaap van Maanen
                      Jaap van Maanen
                        Michael 2v
                        Michael 2v
                      • Hide warnings on the map
                      • Map Layers
                        Martin White
                        Martin White
                      • Bollard trouble
