  4. spoken directions do not work every time (plus volume question)
8 Posts 4 Posters 937 Views 2 Watching
  • Martijn 1lundefined Offline
    Martijn 1l
    wrote on last edited by Martijn 1l
    hello!
    So I use the navigation app on my iphone (15 pro if relevant) and i noticed that sometimes the directions are not spoken, for me that is my main form of information on the motorcycle.
    I used a route i found via the app in my area and drove it for a while when i noticed that it didn't tell me every turn.
    and a side question, I also use spotify most of the times while riding, and i find that the music is louder than the instructions, is there a way to adjust this?
    (I mean that the i want the volume of the navigation instructions on a louder setting that my music, when i now have instructions on the same volume as my music i have the urge to turn the volume up)
    hoping that these issue can be resolved, thank you!
    • Martijn 1lundefined Martijn 1l
      hello!
      @Martijn-1l, It is a known issue that instructions are not spoken when a waypoint is too near to the junction/roundabout. Try to place your waypoints 150 to 200 mtrs away from them. On IOS my thought was that the instructions come from a separate sound channel, and you can adjust that while it is speaking but I cannot speak from experience. On Android I know for sure that the instructions are mixed into the media channel, and that independant volume therefore is not possible.
      Martijn 1lundefined M. Schrijverundefined 2 Replies Last reply
        Martijn 1l
        Thank you for your reply, i almost forgot about this question, i thought i would get an notification when someone would respond, turns out it didnt 🙂 probably my own settings....
        regarding the missing instructions, the route was not made by me, I just picked a route in my area and drove it. so i had no influence on the location of the waypoint, when designing my routes I will keep it in mind, thank you!
        Regarding the volume, I have tried to change the volume when the app is telling me instructions but then the music volume also goes down.
        So the music and the navigation has one volume channel, unfortunately…
        I would really like a solution to the volume thing because the music is background for me, so I can just hear it, and the instructions should be loud and clear 😉
        otherwise i need to look for an other solution / navigation app.
          M. Schrijverundefined Offline
          The volume issue can be solved with a third party TTS engine.
          Martijn 1lundefined 1 Reply Last reply
            Martijn 1l
            @M-Schrijver
            Do you have a suggestion what TTS engine would work on IOS?
              @Con-Hennekens said in spoken directions do not work every time (plus volume question):
              Sadly there is not always a possibilty to do this. A stop can be just around the corner.
              A WP just before a roundabout/junction seems less of an issue than the a WP just after a roundabout/junction
                @M-Schrijver
                @Martijn-1l said in spoken directions do not work every time (plus volume question):
                @M-Schrijver
                IOS is a unkown territory for me.
                But i use Acapella for Android on my phone. I did the trick for me.
                Acapella seems to be available for IOS also
                  On my last daytrip (i thought with 4.2.0) both WP and directions were not spoken if a WP is close to a junction.
                  This whole thing need some work. Notes and names of WP are also not always spoken even when the distances between the last en next WP/junction is big enough.
                  Martijn 1lundefined
                  Martijn 1l
                  • New beta! 5.0.2 (438) - free drive
                  • Updated beta! 5.0.2 (441)
                  • Search for POI while navigating - weird logic now
                    Jon Hye-Knudsenundefined
                    Jon Hye-Knudsen
                  • Improve Favorite POI management (visibility, categories, icons)
                    3.1k
                  • Garmin XT reflecting planned routes
                    David Gilliesundefined
                    David Gillies
                  • Imported GPX file Waypoint Names
                    Kerry Lebelundefined
                    Kerry Lebel
                  • Autovelox
                  • Since upgrade Quick Route seems locked in scenic
