  4. Auto - Zoom not working via Carplay
10 Posts 6 Posters 2.1k Views 3 Watching
  • P1LTSundefined Offline
    P1LTS
    *** cross posted form the EN area, but as this does not appear to be an isolated issue, I thought it worth posting in here too, so hopefully somebody form MRA will reply***
    Just returned from a 1000mile trip around Scotland. My setup is iPhone 15 Pro with a Chigee AIO5 Play.
    The CarPlay map screen stays zoomed out and does not zoom in when speed changes nor when approaching a junction/roundabout etc. I have the auto zoom correction set to “ON”.
    Also I tried the zoom correction on all settings and it made absolutely no difference to the amount that the map is zoomed in/out.
    These are pretty fundamental settings in my opinion and it makes the app very difficult/almost impossible to use.
    Am I doing something wrong?
    • P1LTSundefined P1LTS
      @P1LTS Could it be that you had selected the top-down camera mode in CarPlay?
      When set to dynamic / north-up, it should definitely zoom in /out automatically.
      P1LTSundefined KeesVundefined Eric Bovelanderundefined 3 Replies Last reply
        P1LTS
        @Corjan-Meijerink thanks for the prompt reply. It is definitely not set to top-down camera mode and it does not zoom at all but stays fully zoomed out at all times. From the responses in the EN forum, I am not the only one experiencing this issue neither.
        I am sure that you can imaging that this makes the app very, very difficult to use.
          @P1LTS said in Auto - Zoom not working via Carplay:
          A screenshot might take the guesswork out of it 😉
            P1LTS
            Interestingly, I think I may have found the issue. I had the camera selected to "dynamic" mode which should automatically zoom, but it wasn't. If I toggle through all of the camera modes through "top down", "north up" and then back to "dynamic", the auto zoom function appears to work correctly. Not sure why this happens but it does appear to restore the auto zoom functionality.
            I just thought that I would share my findings.
              @P1LTS That definitely is an interesting find!
              I'll make sure we check if the setting is synced correctly. Might be falsely claiming to be in "dynamic".
              P1LTSundefined RetiredWingManundefined 2 Replies Last reply
                P1LTS
                @Corjan-Meijerink no problem. Im just pleased it is now working. 🙂
                  KeesVundefined Offline
                  KeesV
                  Aha… so auto-zoom currently doesn’t work in top-down mode. That explains the zoom-issues during my trip.
                  Please add auto-zoom for top-down mode in the next release!
                    @Corjan-Meijerink I had a situation where auto zoom was not working. I think it was because I had manually zoomed out. After I tapped the compass the auto zoom began working again.
                      Eric Bovelanderundefined Offline
                      Eric Bovelander
                      @Corjan-Meijerink ik ben gewend om het scherm in de rijrichting te hebben staan, begrijp ik het goed dat de auto-zoom met Apple Carplay dan niet functioneerd, en dus in "Noord Boven? moet staan ?
                      KeesVundefined
                      KeesV
                      Eric Bovelander
                      P1LTSundefined
                      P1LTS
                      • Preview
                        Iain Cochrane 0undefined
                        Iain Cochrane 0
                        Martin Wilckeundefined
                        Martin Wilcke
                        guenniguenzelsenundefined
                        guenniguenzelsen
                      • Routepunten en viapunten in carpuride
                        De Ploey Georgesundefined
                        De Ploey Georges
                      • mra route afsluiting naderland
                      • Carpuride
                        Léon Hassingundefined
                        Léon Hassing
