  4. Sort order
Sort order
9 Posts 6 Posters 1.6k Views 2 Watching
  • john 1qundefined Offline
    john 1q
    When you combine routes and click the "add" button, the list of routes to choose from are not in alphabetical order.
    Hope you can help.
      john 1q
      @Peter-Schiefer
      Peter, look at the attached, the sort order problem is when you are adding another route to your existing route.
      John
      • john 1qundefined john 1q
        @Peter-Schiefer
        John
        @john-1q refresh the page will help
          @Peter-Schiefer and @Marinus-van-Deudekom, guys, do you even try the advice you give for yourself?
          @john-1q, you are right, the sorting is on the date, newest on top. There is no column header to click, and why the sorting would change after a page reload is beyond me...
            @Con-Hennekens my bad. I didn'tlook close enough so I thought it was the list of the routes itself where you can choose a collum. 🙂
              @Marinus-van-Deudekom, that's an easy mistake indeed 😉
              • Tony 13undefined Offline
                Tony 13
                it is irritating, hope putting a sort option is on a to do list somewhere
                • Tony 13undefined Tony 13
                  @Tony-13, it's inconvenient, it get's irritating if you have no folders to structure your routes. Devs are reading along, so let's hope for the best 😉
                    Some adjustments will be made 🙂
                    Tony 13undefined
                    Tony 13
                    john 1qundefined
                    john 1q
                      Lenny Oundefined
                      Lenny O
                    • Updated beta! 5.2.1 (486)
                    • wrong routing
                      John S Parryundefined
                    • Veekeersinfo en omleiden
                      Herman Veldhuizenundefined
                    • Request login credentials
                    • [Suggestion] Mark 'skipped' routepoints in sidebar
                      Yannick_van_Vugtundefined
                      Yannick_van_Vugt
