  4. Offline cards - currently not on SD...
7 Posts 4 Posters 941 Views 3 Watching
  • Bodenseematzeundefined Offline
    Bodenseematze
    I'm totally new to the Android MyRoute-app and like to use it on a longer motorcycle tour (end of next week).
    For that it's very important to download all the maps - now I saw a note that it's "currently not possible because of issues" to store them on my SD card.
    But to store them in my internal RAM there's not enough space available.
    So when will it available again?
      @Bodenseematze They definitely are not stored on your internal RAM 😉
      Not sure when the issue will be fixed however.
      How many countries are you going to visit? The chances that you have a few gigs left on your internal memory is quite high.
      Bodenseematzeundefined 1 Reply Last reply
      • Peter Bijnsdorpundefined Offline
        Peter Bijnsdorp
        Ik had de kaarten eers gedownload op de sd kaart en toen later op het interne geheugen van de telefoon na de uodate van MRA. Staan de oude gedownloaden kaarten nog op de sd kaart of zijn die door MRA gewist? En als ze nog op de sd kaart staan kan ik ze dan wissen en waar staan ze dan op de sd kaart?
        Groet, Peter
          Bodenseematze
          I travel from Germany to Albania and then back with a ferry from Greece to Italy and from there back by motorcycle to Germany - so there are quite a lot of countries 😉 (Germany, Austria, Slowenia, Kroatia, Bosnia and Herzegowina, Serbia, Montenegro, North Macedonia, Kosovo, Albania, Greece, Italy)
          What exactly is the technical problem with the SD card?
          • Peter Bijnsdorpundefined Peter Bijnsdorp
            Groet, Peter
            @Peter-Bijnsdorp Deze zullen er nog staan. Wanneer het probleem is opgelost, zouden de kaarten op de SD kaart ook weer moeten werken dus.
            • Bodenseematzeundefined Bodenseematze
              @Bodenseematze Quite some countries! Enjoy your trip 🙂
              Technical issue that due to some formatting issue in the HERE SDK for SD card maps, the offline maps become useless.
                Bouke Entundefined Offline
                @Corjan-Meijerink als ik oude android app hou en ook de kaarten op sd blijft dat dan offline werken ?
                ik heb ook beperkte ruimte en ik begrijp dat oplossing nog wel lang kan duren.
                Bouke Entundefined
                Peter Bijnsdorp
                Bodenseematze
                  Lenny Oundefined
                  Lenny O
                • Updated beta! 5.2.1 (486)
                • wrong routing
                  John S Parryundefined
                • Veekeersinfo en omleiden
                  Herman Veldhuizenundefined
                • Request login credentials
                • [Suggestion] Mark 'skipped' routepoints in sidebar
                  Yannick_van_Vugtundefined
                  Yannick_van_Vugt
