  4. Routeplanner doesn't work
10 Posts 6 Posters 2.2k Views 3 Watching
  • DAVID PUEYO TORRESundefined Offline
    DAVID PUEYO TORRES
    I have less than 30 routes and the application won't let me create new routes.
    Can you please help me?
    Thank you!
    • DAVID PUEYO TORRESundefined DAVID PUEYO TORRES
      Thank you!
      @DAVID-PUEYO-TORRES Do you only have a basic account?
      DAVID PUEYO TORRESundefined 1 Reply Last reply
        DAVID PUEYO TORRES
        @Nick-Carthew Yes, I have a basic account. But I've never had this problem before.
          @DAVID-PUEYO-TORRES You have reached your free storage limit. Save some of your routes as .gpx files on your PC and then delete them from your MRA account. Or, you could pay for a MRA subscription.
            DAVID PUEYO TORRES
            @Nick-Carthew Thank you Nick, but it doesn't work! ๐Ÿ˜ž
              @DAVID-PUEYO-TORRES, I guess you need to delete some more routes? I am not sure, but the stored tracklogs could be added as well?
                DAVID PUEYO TORRES
                @Con-Hennekens Thank you for your help! Finally I get the subscription and the problem is finish. Regards!
                • TomOnTourundefined Offline
                  TomOnTour
                  wrote on last edited by TomOnTour
                  Hi @Dennis-Dawson!
                  I think I donโ€˜t fully get your problem. May I ask you to give some more information on your problem?
                  What I understood so far:
                  • You have a silver subscription for MyRoute-app routenplaner
                  • You have planned a route on the web with the planner
                  • You have some kind of navigation device/app that you transfer the route to and starts navigating
                  • When you start the navigation the planned route is not used, but instead it โ€žroutesโ€œ/tells you to go back from you have been
                  And here is the point where it is getting a bit tricky:
                  • Which navigation device your are using/want to use?
                  • How did y get the planned route from the web-based route planner to the device?
                  • What is meant with its routes you back tithe point where you come from?
                  • Have you opened a already defined route from the route lab library or did you plan a brand new one?
                  I know these are lots of questions, but with what I know and/or understood so far, I Donโ€˜t know how to help you ๐Ÿ™‚
                  Greetings
                  Thomas
                  using iPad Pro (iPadOS 26.5) and Macbook Air (macOS 26.5.1)
                  • RetiredWingManundefined Online
                    @Dennis-Dawson it sounds like you need to move waypoint # 1 away from your starting location. Assuming you are using the MyRoute-app, it thinks you never passed waypoint 1. The quick and easy solution is to skip the waypoint.
                      @Dennis-Dawson once you have started navigation you can't move waypoints. That has to be done in the planner. You can however skip a waypoint. Assuming you are displaying the next wapoint (top right corner),you can easily skip to the next waypoint by tapping on the waypoint and then answering yes to the confirmation message, or long press on the next waypoint to quickly skip it.
                      To display waypoints, use the (...) menu and select Waypoints. Once you have the list of waypoints you can skip to another waypoint by pressing on the waypoint.
                      Honestly, this is all basic operation if you simply took the time to watch some of the training videos and perhaps even reviewed the manual.
                      TomOnTourundefined
                      TomOnTour
                      DAVID PUEYO TORRES
                        Eric Bovelanderundefined
                        Eric Bovelander
                        -2
                      • Waypoints and POIs disappear while moving/zooming the map in web planner
                        Tom Balmerundefined
                        Tom Balmer
                      • Veerpont als routeovertreding gaat te ver
                        Koen Vandecauter 0undefined
                        Koen Vandecauter 0
                      • Fout in route bibliotheek
                      • Testrit met AA ivm tracklog
                        supergundefined
                      • Track log functionality - compared with BaseCamp
                        John Matthews 0undefined
                        John Matthews 0
                      • Moving the map
                        Dave J 0undefined
