  4. Skip waypoints not working?
16 Posts 9 Posters 3.6k Views 5 Watching
  • P1LTS Offline
    P1LTS Offline
    P1LTS
    wrote on last edited by P1LTS
    During yesterday’s ride, the app continually tried to reroute me back to a missed waypoint. This was NOT a via point and I have checked that the automatically skip waypoint option is enabled. This went on for a few miles before I manually skipped the waypoint. This happened on more than one occasion. Any ideas?
    • P1LTS P1LTS
      Rob Verhoeff Offline
      @P1LTS The auto-skip mechanism has been adjusted to be slightly stricter with the latest update, primarily to prevent you from missing a significant part of your route by skipping too quickly. If you notice that it takes a long time to be directed to the next point, you can always manually skip a part of your route by either skipping the next suggested route point or by long-pressing a point on the map and navigating from there.
      P1LTS 1 Reply Last reply
        P1LTS Offline
        P1LTS Offline
        P1LTS
        @Rob-Verhoeff thanks for the feedback, I’ll admit it was a touch annoying though using CarPlay in a motorcycle. Manually skipping waypoints using only a number makes it sub-optimal too. I’d prefer a rapid “skip” to avoid doing u-turns just to pass a waypoint that you may have missed by a small number of meters.
        George M 0 1 Reply Last reply
        • P1LTS P1LTS
          George M 0 Offline
          George M 0 Offline
          George M 0
          @P1LTS I agree this is an issue and makes MyRoute Planner as a navigator product difficult to use while actually riding a motorcycle and leading a group of other riders... This happened to me yesterday as a lead rider (as I made the route and had navigation) of 8 bikes. When you ride with a group of bikes, things come up, gas stops, breakdowns, piss stops, on and on that can easily cause a slightly missed Waypoint marker. You cant keep pulling over while riding a motorcycle with gloves on to hit the Waypoint and find the skip icon. Question - I have the MyRoute Planner subscription only, where do you enable "Automatically Skip Waypoint" setting ? I cant find it in Route Planner or on the Android App ? May I make a suggestion, when a Waypoint is missed enroute while navigating, simply have a pop up button that comes up that you can touch to bypass the missed Waypoint and keep going to your next Waypoint...
          Rob Verhoeff Peter van der Steen Con Hennekens 3 Replies Last reply
          • richtea999 Offline
            richtea999 Offline
            @P1LTS The quickest way I've found is a long press on the waypoint indicator (top right of the screen) - that skips to the next one.
            You can try that at home - load a route, and then long press on the waypoint 1 indicator. You'll see waypoint 2 gets shown.
            • George M 0 George M 0
              @George-M-0 said in Skip waypoints not working?:
              In the MyRoute-app itself, not in the planner.
                Peter van der Steen Offline
                Peter van der Steen
                That's not in androidauto screen.
                  P1LTS Offline
                  P1LTS Offline
                  P1LTS
                  @Rob-Verhoeff yep. It’s an app setting.
                  • Nick Carthew Offline
                    You could consider using Bluetooth bar buttons. It completely changes the experience of using the app. I use SilverFox bar buttons and I highly recommend them, complete game changer.
                      It actually helps you ride your pre-planned route instead of skipping every time something comes up. As a lead rider you have to be alert for these things. If you leave a gas station or continue after taking a piss, reassure yourself about going to the right waypoint BEFORE you take off 😉
                      In the current version after the second recalculation, you will be sent back to a waypoint if that waypoint still is the closest one of the (maximum) 10 upcoming waypoints. After 5 (I believe, not sure) times being sent back it will skip to the next one anyway, even if it is still the closest one.
                      • M. Schrijver Offline
                        It is logical the navigation sends you back to the missed waypoint. But after 2 or 3 (ignored) attempts it should guide you next closest upcoming waypoint. Not a shapingpoint where you need to turn around and go back.
                        Offcourse everything changes in case of a Viapoint. But i think that is obvious.
                        This is also a reason why you need enough waypoints. When you choose to use limited amount of waypoints. It will be possible you will miss a big chunk of the original route when (auto) skip a waypoint.
                        • richtea999 richtea999
                          P1LTS Offline
                          P1LTS Offline
                          P1LTS
                          @richtea999 DI dont think this option works on Carplay.
                            P1LTS Offline
                            P1LTS Offline
                            P1LTS
                            @Nick-Carthew I use a Chigee AIO-5 which allows the "wonderwheel" on my GS, so I can hit the skip waypoint button without reverting to the touchscreen. However, when you are unfamiliar with a particular route, it is still difficult to ascertain whether you are being re-routed back to a missed waypoint. It would be great if you could set a radius around a waypoint such that if you missed it by say 200m, it would be automatically skipped. Also when you choose to a skip a waypoint manually, you only have the option of "skip wayoint x". The actual name of the waypoint would be much better.
                            • George M 0 Offline
                              George M 0 Offline
                              George M 0
                              wrote on last edited by George M 0
                              Thank you to all for your input, it was very helpful. What I learned to help with the Waypoint issues in my original post. 1. Add more frequent Waypoints, I originally had them too far apart, thus the app kept looking for the last missed Waypoint and couldn't see the next or I assume too far away Waypoint soon enough. 2. I was using the navigator in the MRApp in Track mode, there is not a "Skip Waypoint" button in Track mode in my Android Auto screen. When I switched to Navigate mode while loading the route on my phone first, the skip Waypoint button appeared as described. 3. I enabled the "Skip Waypoints" in the phone app as I found the setting there as it is not in the Android Auto settings of the MRApp... Thanks again for the input, I am confident now in managing Waypoints better while on the ride ...
                              • Tom Cat Offline
                                Tom Cat Offline
                                Tom Cat
                                I had a similar issue this weekend. I went through a via point, stopped for fuel and when I was back on my way it kept trying to route me back to the via point. Even after riding through the next waypoint, it still kept trying to route me back. After going through the next two waypoints without the app skipping forward, I had to pull over and skip to the next waypoint manually. You cannot do this while using Android Auto.
                                • Tom Cat Tom Cat
                                  @Tom-Cat said in Skip waypoints not working?:
                                  It seems like you haven't reached the viapoint. This can easily happen if you didn't place that viapoint on the road. The routecalculation will keep redirecting you until you actually hit the viapoint. This is just an assumption since I haven't seen your route.
                                  P1LTS
                                  P1LTS
                                  Tom Cat
                                  Tom Cat
                                  George M 0
                                  George M 0
                                  Peter van der Steen
                                  Peter van der Steen
                                  • Questions and suggestions
                                    Mike wiruth
                                    Mike wiruth
                                    Philip Verbeek
                                    Philip Verbeek
                                  • Rondrit maken lukt niet
                                    Rob Vonk
                                    Rob Vonk
