  4. Offline Navigation and Battery Overheat
15 Posts 5 Posters 3.1k Views 2 Watching
  • Andree 1
    Andree 1
    Andree 1
    Ich habe das gleiche Problem, schlechtes Internet und bekomme trotz online Karten, keine Navigation. Ich will morgen in den Urlaub und stehe da jetzt vor einem Problem, habe keine Navigation.
      @Dave-P-3 Please share a route in this topic and let's see what happens if I hit the navigate button!
      Dave P 3
      Dave P 3
      Dave P 3
      @Rob-Verhoeff I have just tried to use a route offline and it appears to work. All the other downloaded journeys are tracks A to B. Could this be the problem?
        Dave P 3
        Dave P 3
        Dave P 3
        @Rob-Verhoeff I just made a test route in MRA and built the same route that failed earlier but this time I used a whole load of waypoints and it appears to work ok. If I use the other version which is starting at my home location and ending at the destination without waypoints the App wants to go online.
        Now I'm really confused!
          Dave P 3
          Dave P 3
          Dave P 3
          @Rob-Verhoeff https://www.myrouteapp.com/en/social/route/9238166?mode=share
          Hope this works. As you can see its a track from point A to point B
          It definitely doesn't work offline for me.
          cheers
          RetiredWingMan Con Hennekens 2 Replies Last reply
          • Dave P 3 Dave P 3
            cheers
            @Dave-P-3 the route you shared is a track. Tracks can only be navigated on-line.
            Dave P 3 1 Reply Last reply
            • Dave P 3 Dave P 3
              cheers
              @Dave-P-3, Tracks need to be calculated online. I think it is okay of you go offline after having it started, but as soon as you deviate it needs to recalculate and hence it will need a live internet connection.
              • Andree 1 Andree 1
                @Andree-1, Are you using tracks too? Then you will need to convert them to routes in the web planner. I am sorry to say, but it is not very wise preparing your routes the day before you leave...
                  Dave P 3
                  Dave P 3
                  Dave P 3
                  @RetiredWingMan Thanks for that. I think I'd almost figured it out but appreciate the confirmation. Cheers.
                    Dave P 3
                    Dave P 3
                    Dave P 3
                    @Con-Hennekens Thank you. I think I had more or less concluded the same thing last night after playing around with the app. Definitely a case of user error on my part.
                      Dave P 3
                      Dave P 3
                      Dave P 3
                      @Con-Hennekens Thank you for the advice, much appreciated. I'm a retired airline pilot so planning an hour before departure is the norm for me. I guess old habits die hard!
                      • Dave P 3 Dave P 3
                        @Dave-P-3 All awnsers given, I rest my case šŸ˜‰
                        šŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
                        Andree 1
                        Andree 1
                        Dave P 3
                        Dave P 3
                          Glenn.B
                          Glenn.B
                          3.7k
                          Robineke
                          Robineke
                        • Overlay Routes like the App does and waypoints without routes
                          Rob Kelley
                          Rob Kelley
                        • How to plan correctly
                        • Brittany routes
                          Tony 13
                          Tony 13
                        • Slow Favorites
