  4. Distance 0 mi, Duration 1 min
21 Posts 7 Posters 155 Views 2 Watching
    @Stefan-Hummelink Yes, all very true. I was merely pointing out that the TomTom planning map had been used.
    @Nick-Carthew said in Distance 0 mi, Duration 1 min:
    Hehe I know. 😃
      Hehe I know. 😃
      @Stefan-Hummelink Also interesting or strange is that the map on the screenshot that @Eugene7 shared is not in focus. And the route title is different.
      Eugene7 1 Reply Last reply
        Eugene7
        Eugene7
        Eugene7
        Ignore the TEST route...
        I stupidly made it in MyRoute, not in TYRE.
        As said, the issue is with routes made outside of MyRoute.
        www.7-dna.com
        www.youtube.com/user/bogclub7
        • Eugene7 Eugene7
          Eugene7
          Eugene7
          Eugene7
          Here is another Test route that has the issue: https://www.myrouteapp.com/en/social/route/9123837?mode=share
          www.7-dna.com
          Nick Carthew Corjan Meijerink Lynchy67 3 Replies Last reply
          • Eugene7 Eugene7
            @Eugene7 Again this is caused because the TomTom map has been used for planning the route and the onscreen message tells you this. Press Navigate and after choosing to use as a route or a track the time and distance calculations are available. If using the track you will need to be online.
            You can of course use the Compare with tool in the route planner to align the HERE route to the TomTom route.
            • Eugene7 Eugene7
              @Eugene7 Interesting, I just checked the metadata of this route and can indeed confirm that distance / duration is not set (therefore the app displays these values).
              Did you import the route and that's it? Metadata is updated on every waypoint placement / adjustment but if you never modified anything that might explain why information is missing! 🙂
              • Eugene7 Eugene7
                @Eugene7
                In "New Test" there is no Waypoint 25?
                Waypoint 26 is duplicated.
                • Lynchy67 Lynchy67
                  @Eugene7
                  Eugene7
                  Eugene7
                  Eugene7
                  True - it is a duplicated point - makes no difference to the issue though.
                  Seems any externally generated routs show zero duration when imported into MyRoute...
                  www.7-dna.com
                  • Eugene7 Eugene7
                    @Eugene7 so when importing a route, this is indeed the issue? I can fix that!
                    Can you confirm that simply dragging one waypoint slightly updates the route information correctly? 🙂 (or adding / removing one, just any route manipulation to be fair)
                    Dae 0 1 Reply Last reply
                      Dae 0
                      Dae 0
                      Dae 0
                      I’ve definitely seen that when I imported my old Basecamp routes. All had zero time and distance until I “touched” them
                      • Dae 0 Dae 0
                        @Dae-0 thanks! I’ll get that sorted 🙂
                          Fixed 🙂
                          Dae 0
                          Dae 0
                          Eugene7
                          Eugene7
                          • Log in
                            Rod Sydenham
                            Rod Sydenham
                          • Restriction on scenic length?
                            Jeroen ekkel c
                            Jeroen ekkel c
                          • AI pricing is too high
                            Cleo
                            Cleo
                          • Segment function with the HERE map
                            Emanuele 5
                            Emanuele 5
                          • Library Structure
                            John Matthews 0
                            John Matthews 0
                          • Nieuw start punt maar krijg de route niet hernummerd in logische volgorde
                            Juudje39
                            Juudje39
                            Andy Beviere
                            Andy Beviere
                            1.7k
