  4. Distance 0 mi, Duration 1 min
21 Posts 7 Posters 155 Views 2 Watching
  • Eugene7 Eugene7
    When you open a route, the initial info always shows Distance 0 mi, Duration 1 min...
    ObviouslyScreenshot_20240505_101437.jpg not correct.
    @Eugene7 that is definitely not the case for all routes ๐Ÿ˜‰ Are these imported routetracks?
    • richtea999
      My loops are showing accurate time and distance.
      Can you share your route by making it public, and we can try and decipher what's not working. (Change the start/stop point if it's sensitive - like your home.)
      Thanks.
      Eugene7 1 Reply Last reply
      • richtea999 richtea999
        Thanks.
        Eugene7
        Eugene7
        Eugene7
        I've shared a TEST route - made it Public.
        Hope that works.
        The routes are all generated via TYRE, as that is our preferred method for generating routes.
        www.7-dna.com
        www.youtube.com/user/bogclub7
        • Eugene7 Eugene7
          Hope that works.
          @Eugene7 said in Distance 0 mi, Duration 1 min:
          shared
          Please share the URL of the route here ... That way we don't have to search for your route in your account if we can even find your account since your forum nick may not be the same as your account name.... ๐Ÿ˜ƒ
            shared
            Eugene7
            Eugene7
            Eugene7
            https://www.myrouteapp.com/en/social/route/9115557?mode=share
            www.7-dna.com
            • Eugene7 Eugene7
              @Eugene7
              The route has been made using the TomTom planning map. Not recommend for MRA Navigation.
                @Eugene7
                @Nick-Carthew Even though that is correct, it does not explain the behaviour of the app @Eugene7 is showing. It seems like the app was unable to calculate the route... That has nothing to do whether or not the route was made in TomTom or HERE, surely discrepancies may occur but that's irrelevant for now imho regarding the issue @Eugene7 has. ๐Ÿ˜Š
                What I do notice is that the route he shared with us has 12 waypoints, and his has 13. What happened there? It seems like his app calculated directly to the end which is also almost his start position.
                Anyhow, I cannot explain the app behaviour based on this shared route. There seems nothing wrong with it. ๐Ÿ˜…
                  @Stefan-Hummelink Yes, all very true. I was merely pointing out that the TomTom planning map had been used.
                    @Nick-Carthew said in Distance 0 mi, Duration 1 min:
                    Hehe I know. ๐Ÿ˜ƒ
                      Hehe I know. ๐Ÿ˜ƒ
                      @Stefan-Hummelink Also interesting or strange is that the map on the screenshot that @Eugene7 shared is not in focus. And the route title is different.
                        Eugene7
                        Eugene7
                        Eugene7
                        Ignore the TEST route...
                        I stupidly made it in MyRoute, not in TYRE.
                        As said, the issue is with routes made outside of MyRoute.
                        www.7-dna.com
                        • Eugene7 Eugene7
                          Eugene7
                          Eugene7
                          Eugene7
                          Here is another Test route that has the issue: https://www.myrouteapp.com/en/social/route/9123837?mode=share
                          www.7-dna.com
                          Nick Carthew Corjan Meijerink Lynchy67 3 Replies Last reply
                          • Eugene7 Eugene7
                            @Eugene7 Again this is caused because the TomTom map has been used for planning the route and the onscreen message tells you this. Press Navigate and after choosing to use as a route or a track the time and distance calculations are available. If using the track you will need to be online.
                            You can of course use the Compare with tool in the route planner to align the HERE route to the TomTom route.
                            • Eugene7 Eugene7
                              @Eugene7 Interesting, I just checked the metadata of this route and can indeed confirm that distance / duration is not set (therefore the app displays these values).
                              Did you import the route and that's it? Metadata is updated on every waypoint placement / adjustment but if you never modified anything that might explain why information is missing! ๐Ÿ™‚
                              • Eugene7 Eugene7
                                @Eugene7
                                In "New Test" there is no Waypoint 25?
                                Waypoint 26 is duplicated.
                                You donโ€™t stop riding when you get old, you get old when you stop riding.
                                • Lynchy67 Lynchy67
                                  @Eugene7
                                  Eugene7
                                  Eugene7
                                  Eugene7
                                  True - it is a duplicated point - makes no difference to the issue though.
                                  Seems any externally generated routs show zero duration when imported into MyRoute...
                                  www.7-dna.com
                                  • Eugene7 Eugene7
                                    @Eugene7 so when importing a route, this is indeed the issue? I can fix that!
                                    Can you confirm that simply dragging one waypoint slightly updates the route information correctly? ๐Ÿ™‚ (or adding / removing one, just any route manipulation to be fair)
                                    Dae 0 1 Reply Last reply
                                      Dae 0
                                      Dae 0
                                      Dae 0
                                      Iโ€™ve definitely seen that when I imported my old Basecamp routes. All had zero time and distance until I โ€œtouchedโ€ them
                                      • Dae 0 Dae 0
                                        @Dae-0 thanks! Iโ€™ll get that sorted ๐Ÿ™‚
                                          Fixed ๐Ÿ™‚
                                          Dae 0
                                          Dae 0
                                          Eugene7
                                          Eugene7
                                          • Log in
                                            Rod Sydenham
                                            Rod Sydenham
                                          • Restriction on scenic length?
                                            Jeroen ekkel c
                                            Jeroen ekkel c
                                          • AI pricing is too high
                                            Cleo
                                            Cleo
                                          • Segment function with the HERE map
                                            Emanuele 5
                                            Emanuele 5
                                          • Library Structure
                                            John Matthews 0
                                            John Matthews 0
                                          • Nieuw start punt maar krijg de route niet hernummerd in logische volgorde
                                            Juudje39
                                            Juudje39
                                            Andy Beviere
                                            Andy Beviere
                                            1.7k
