  4. Display position lags actual position
18 Posts 9 Posters 7.2k Views 3 Watching
  • Stefan Hummelink
    @GEORGIOS-PANTELIDIS-0 said in Display position lags actual position:
    how much it delays showing your actual position.
    Dear Georgios, please read this thread: https://forum.myrouteapp.com/topic/6677/position-delay-lag-quick-fix-which-app-works-which-do-not/18
    Have you already tried running another gps app simultaneously with the MRA app? For me running Flitsmeister or Waze in tandem with MRA, almost completely solve the delay.
    Please also post your phone data in that thread. Thank you.
    GEORGIOS PANTELIDIS 0 1 Reply Last reply
      @Stefan-Hummelink
      "I tried it today and it almost solved the problem, but why should all this be necessary, and just not work perfectly and smoothly? The enemy of good is the best."
      My mobile phone is the Ulefone Armor X12 Pro, and I didn't have any issues with any GPS program, and I've tried almost all of them.
      • GEORGIOS PANTELIDIS 0 GEORGIOS PANTELIDIS 0
        @Stefan-Hummelink
        Who said that this should be necessary and that this issue is accepted? It is not!
        On the contrary, this issue is on priority 2 of the issues the Dev's are in contact with HERE about. Priority 1 is the battery issue... So these two are at the utmost priority of the MRA dev team, but the root cause of both these issues lie with HERE(!), the SDK and map provider.
        Running another GPS app in tandem with MRA is only a temporary fix for a issue that shall be solved in the near future, it just depends on the pace at which HERE is finding out how to solve it, until then, a temporary fix is applicable.
        *PS I urge you to read back on the forum history from the moment on the BETA project started;) Many of these persistent bugs were already identified from the getgo.
          @Stefan-Hummelink
          "I don't want to disagree either, and I truly believe it's the perfect navigation application. I've recommended it to my friends and acquaintances. I didn't know this was a problem with Here and not yours. From now on, I'll wait for it to be resolved and will continue to use it. However, the link you provided below doesn't open for me: https://forum.myrouteapp.com/topic/6677/position-delay-lag-quick-fix-which-app-works-which-do-not/18"
          Corjan Meijerink Stefan Hummelink 2 Replies Last reply
            @Stefan-Hummelink
            @GEORGIOS-PANTELIDIS-0 now it does πŸ™‚
              @Corjan-Meijerink Ah, I started the topic in the beta section... I see you fixed it. 😜
                @Stefan-Hummelink
                not yours
                Haha that are credits I don't deserve. I'm a simple user just as you are, but only a bit more informed, but hey, that's the sole purpose of this forum! Sharing and caring, right!? πŸ˜ƒ
                Huibertus 1 Reply Last reply
                  not yours
                  Huibertus
                  Huibertus
                  Huibertus
                  @Stefan-Hummelink Ik had het gisteren ook met mijn "Fietsroute app". De GPS was erg traag en week veel af. Ik durf het haast niet te zeggen, maar zou het misschien ook kunnen zijn dat bij het bereiken van de maximale data van je abbo, deze functionaliteit "op een laag pitje" draait?. Ik was gisteren nl door mijn max data heen waardoor ik deze ingeving had.
                  • Huibertus Huibertus
                    @Huibertus said in Display position lags actual position:
                    data van je abbo
                    Het wel-of niet hebben van connectiviteit met WiFI, 2G/3G/4G of zelfs 5G maakt niets uit voor de GPS ontvanger en daarmee dan ook niet hoe de app met die GPS data omgaat. GPS staat helemaal los van internet connectiveit πŸ˜‰
                      data van je abbo
                      Huibertus
                      Huibertus
                      Huibertus
                      @Stefan-Hummelink 🀦 Thnx Stefan voor de uitleg. Zat ik er even naast.
                      JP d
                      JP d
                      Kudee
                      Kudee
                      Huibertus
                      Huibertus
                      dungbeetle
                      dungbeetle
                      Vincent Curren
                      Vincent Curren
                      Adam Sobanski
                      Adam Sobanski
                      • BΓ©ta to no-bΓ©ta
                        Cleo
                        Cleo
