  3. Joining Rides
Joining Rides
4 Posts 2 Posters 833 Views 1 Watching
  • Andrew Vaughan Offline
    Andrew Vaughan
    Hello to everyone .Is there a way you can combine a few routes together to make one ? on my Scenic app it allows you to do this.
    but i now want to only use MRA so just seeing if there is a way . see picture can i put 1.2 and 3 together
    thank you
    Nick Carthew 2 Replies Last reply
    • Andrew Vaughan Andrew Vaughan
      thank you
      Nick Carthew Offline
      @Andrew-Vaughan Yes, this is called Merge and if you type merge into the support search box you will find a support article. Tip: make a copy of the first route and use this to merge the other routes to. This is because the first route or the base route will change.
      Andrew Vaughan 1 Reply Last reply
        thank you
        @Andrew-Vaughan https://www.myrouteapp.com/support
          Andrew Vaughan
          @Nick-Carthew
          Thank you Nick
          Andrew Vaughan
          Andrew Vaughan
          • Verkeersinfo uitleg gevraagd
            2.5k
          • Offline navigeren
            jonathan maes 0 0
            jonathan maes 0 0
          • No navigation instructions
          • Beeld loopt achter
          • CarPlay says that I need a subscription
            Martin Garand
            Martin Garand
          • Traffic information
            RainerT
            RainerT
