  4. POI visible while navigating
9 Posts 5 Posters 1.7k Views 2 Watching
  • Con Hennekens Offline
    It would be great if users could select standard POI categories, and uploaded personal libraries to be shown on the map while navigating. At the moment we can add POI to a route, so that we see those specifically added POI, which is useful, but it would also be very handy to activate complete categories like "streckensperrungen", mountain passes, viewpoints to be always visible while navigating.
    Jörgen 1 Reply Last reply
      Jörgen Offline
      Jörgen Offline
      @Con-Hennekens said in POI visible while navigating:
      add POI to a route
      Yes, would be nice to have.
      Do you remember where adding POI to a route was described? I can not find it, I think it was from you?
        add POI to a route
        @Jörgen, Select a POI category to show up on the planning map, click a POI symbol on the map, and choose "Add as waypoint" or "add as POI". Doing this from memory so excuse me for the details 😉
          martin-phogel.de Offline
          martin-phogel.de
          since the selection is implemented as a checkbox, "both" is supported as well 🙂
          • Corjan Meijerink Offline
            Good suggestion 🙂
            • Nick Carthew Online
              Nick Carthew Online
              @Jörgen @Martin-Wilcke @Con-Hennekens Only use Add as POI option as quite often the POI is off of the road and this could cause problems.
              martin-phogel.de Con Hennekens 2 Replies Last reply
                martin-phogel.de
                @Nick-Carthew
                Yes, I am aware of that.
                I often use "both", as I almost always want to have a Viapoint in this position as well. But of course I correct the position of the VP if necessary.
                Btw: I think it's a shame that the name is changed when Viapoints are moved - I only find this behaviour appropriate for SPs.
                  @Nick-Carthew
                  @Martin-Wilcke said in POI visible while navigating:
                  Yes that is quite nagging indeed. I believe I already outed that frustration on this forum not long ago 😉
                    @Nick-Carthew, True. I usually place the POI only, and add a WP manually with some information about the POI in the name and note. ON the road of course 😉
                    This combines beautifully with my other suggestion of the day, about "snapping" WPs to the road automatically.
                    martin-phogel.de
                    martin-phogel.de
                    • Offline kaarten downloaden
                    • Questions and suggestions
                      Mike wiruth
                      Mike wiruth
