  4. Hand vs. drop
Hand vs. drop
10 Posts 6 Posters 1.9k Views 3 Watching
  • Radek Šátkaundefined Offline
    Radek Šátka
    How to change all points on the HAND in bulk. Thanks, Radek
    Con Hennekensundefined GT JWRundefined 2 Replies Last reply
    • Radek Šátkaundefined Radek Šátka
      @Radek-Šátka, there is no function for that. Why would you want to do that? The only thing it does, is to prevent them from autoskipping. You can disable autoskipping altogether in the app menu (Functional, second option), and leave the waypoints as they are.
      Radek Šátkaundefined 1 Reply Last reply
        GT JWRundefined Offline
        @Radek-Šátka having a selectable option to do so, or select how many is preferred, would be nice.
        • Meesterundefined Offline
          Meester
          Changing the amount of points in a route. Thats what you do in the online planner right? Its right there in the toolkit under routetools but its a gold option.
            M. Schrijverundefined Offline
            Still the question of @Con-Hennekens is open. Why do you want that? I also like to know it.
            The Hand forces a limitation which the drop don't has. You cannot auto skip this point. Which is fine in some circumstances but normally autoskip a point helps you while riding.
              Radek Šátka
              wrote on last edited by Radek Šátka
                Radek Šátka
                @Con-Hennekens Hi, I have 47 points on my route. Often with my own description. Or maybe for colleagues with a question. For example: we are driving up a mountain and the GPS says: what mountain is it and how high is it? At the next point is the answer. Or, the dam is xxx metres deep. The dam is xxx meters wide. For Zumo XT2 export 1.0 and no problem, everything will be Via Point. But the Zumo XT can only do 29 Via Point. Therefore I need 29 x hand and other drops.
                  @Radek-Šátka Thank you for your explanation. Unfortunately the restriction to only allow 29 via points is a Garmin rule, MRA cannot do anything about this. To overcome this (silly) rule you will have to stick with a limit of 29 via points in 1 route or split your route into two.
                    @Radek-Šátka, Always good to know someones methods, thanks.
                    It gets harder and harder to work around the limitations of all available dedicated satnavs. I am so happy to use a rugged phone instead, without all those limitations! 😉
                    On the other hand, if you are already in the waypoint menu to alter names and notes, changing from shaping point to via point is just one more click.
                      Radek Šátka
                      @Nick-Carthew Zumo XT2, 50 points is no problem. But in the group we also have a Zumo XT and there I have to make only 29 points (hand) and the rest of the points as a drop. It would be good to set somewhere to make points (hand) in the base.
                      GT JWRundefined
                      Radek Šátka
                      Meesterundefined
                      Meester
                      • Joining a planned route from a differant position.
                        coupe_vsundefined
                        coupe_vs
                        433
                      • Rijrichting in route
                        1.4k
                      • Problemen route opslaan naar plan.tomtom
                      • running myRoute-app on a carpuride
                      • Offline Navigation
                      • sorting of routes by departure date
                        Lex.Kloet.RXundefined
                        Lex.Kloet.RX
                      • What exactly am I looking at?
                        D Griffinundefined
                        D Griffin
                      • Exporting route from app to Garmin XT webpage not available
