  4. Route Import
Route Import
9 Posts 4 Posters 1.5k Views 3 Watching
  • Bill Stephensundefined Offline
    Bill Stephens
    When I import an itn file to my Tom Tom rider550 I have a large number of routes to choose from to import Is there a way to clear some of these routes all I have is an option to select or de-select all of them. where are they stored ???
    Bill
    Hans van de Ven MR.MRAundefined Nick Carthewundefined 2 Replies Last reply
    • Bill Stephensundefined Bill Stephens
      Bill
      @Bill-Stephens
      Probably in TomTom MyDrive
      Bill Stephensundefined 1 Reply Last reply
        Bill
        @Bill-Stephens @Hans-van-de-Ven-MRA-Master is correct. Go to MyDrive, login and click the 3 horizontal lines in the top left and select My items. With your list of routes showing click the 3 vertical dots and choose Delete. You can only delete these one at a time.
        Going back to your original question, your latest .itn routes will be at the top of the list so you just need to select the ones you want to import.
          @Bill-Stephens
          Bill Stephens
          Cannot see them in Tom Tom MyDrive anywhere, they only appear on the tom tom rider screen where I can check which route I want to import
            @Bill-Stephens See my reply above.
              Bill Stephens
              @Nick-Carthew
              Hi Nick
              I understand how to delete routes in my drive its the list of routes to import that I would like to tidy up a bit as there are to many in there ( probably because I play around with routes a lot modifying them changing names & creating new routes ) idle hands and all that.
              Bill
                @Nick-Carthew
                Hi Nick
                Bill
                Jörgenundefined Offline
                @Bill-Stephens These routes are in the pre memory of the Rider. Connect your Rider to a PC click Import routes on the Rider and take a look into the folder that's open now on your PC. Here you can delete everything you do not need.
                • Jörgenundefined Jörgen
                  Bill Stephens
                  @Jörgen
                  Hi Jorgen
                  Thanks for that it did not work on my Mac tried it on a windows laptop and it worked fine.
                  thank you
                  Bill
                    @Jörgen
                    Hi Jorgen
                    thank you
                    Bill
                    @Bill-Stephens 👍
                    Bill Stephens
                    • Problems with DIY POI Files
                    • Route analysis in WEB planner...
                      Corrado Miniati 0undefined
                      Corrado Miniati 0
                    • Start route bij dichtstbijzijnde routepunt werkt niet
                    • Different paths between TT and Here algorithms
                      RainerTundefined
                      RainerT
                    • TyuTyu from Hungary
                      Cleoundefined
                      Cleo
                    • Gpx naar mra-route gaat fout
                      BertMundefined
                    • MRA V5.0.3 (449) iOS Gebührenpflichtige Straßen Autobahn ??
