  4. Show elevation
Show elevation
14 Posts 9 Posters 2.2k Views 4 Watching
  • Graziano 0undefined Offline
    Graziano 0
    I have been using the planner for quite some time in combination with a Garmin navigator, now I am starting to use the app. One thing I miss compared to the navigator is having the elevation on the screen. Agreed, it's not essential and probably not an issue in the Netherlands 😉 , but I miss not seeing the elevation as I ride from pass to pass in the Alps. Thanks for your attention!
    Con Hennekensundefined GT JWRundefined 2 Replies Last reply
    • Graziano 0undefined Graziano 0
      @Graziano-0, I( would welcome that to. The Garmin way of choosing your own data fields is quite clever.
        GT JWRundefined Offline
        @Graziano-0 if it is part of a selectable menu, it sounds intriguing...if not, in my opinion (I'm sure everyone has a view 😊 ) the screen is busy enough. I'd prefer lareger roadway/POI icons - at least a size that is recognizable from the current very small, mostly indiscernable ones.
        • Jörgenundefined Offline
          @Graziano-0 May be this helps until it is implemented.
          https://forum.myrouteapp.com/post/33669
          Graziano 0undefined 1 Reply Last reply
          • Jörgenundefined Jörgen
            Graziano 0
            @Jörgen Thank you, but it seems I have no access to that link
              Nick Carthewundefined Online
              @Graziano-0 @Jörgen was referencing a post from the closed BETA forum, this is why you don’t have access from the link. Jörgen has found an app that works for Android phones and it will add an altimeter to your maps, including MRA. You can find it in the PlayStore and it’s called: Maps Altimeter
              Graziano 0undefined Jörgenundefined 2 Replies Last reply
                Graziano 0
                @Nick-Carthew Thanks! I did not know that app, it looks to be very nice, to be seen how it works while riding (ie elevation continuosly changing), but if it works it's a very good option.
                  @Nick-Carthew Thank you Nick.
                  Yes this App will help until there is something in MRA.
                  I made it look like it is in MRA, the setup makes it possible.
                  • Ramon Cutanda Lopezundefined Offline
                    Ramon Cutanda Lopez
                    I too miss this option. Temperature changes linked to elevation variations are usually significant, and I like to have that information at hand. When riding mountain roads, changes in elevation are pretty obvious, but quite often it's hard to tell when riding through plateaus. I am using MyrouteApp + Carplay, so Jörgen's suggestion is not an option for me and I would appreciate the team to have this suggestion into consideration.
                    Thanks,
                      Ramon Cutanda Lopez
                      wrote on last edited by Ramon Cutanda Lopez
                      @Peter-Schiefer Thank you for your insight.
                      Personally, I see plenty of room to implement the requested feature either on the right side or at the bottom:
                      alt text
                      But even if it is not possible to add a new info widget for whichever the reasons, I would personally trade one of the current info widgets. For instance, showing the Estimated Time of Arrival AND the remaining time, at the same time, is redundant in my opinion. I would gladly swap one of those for the elevation (or any other at the choice of the user).
                      I too used a Garmin sat navigation device for years and I loved being able to choose which info blocks to have available. And elevation was definitely always on for me. I really cannot see why MyRoute-app cannot, or should not, offer the user the possibility to choose among the options most useful for each user.
                      I understand that this may not be a very popular request. But, being a "suggestion forum", I believe I am entitled to make mine. If fact, I am just supporting another user's request.
                      Thank you for your time.
                      Regards,
                      GT JWRundefined Corjan Meijerinkundefined 2 Replies Last reply
                      • Ramon Cutanda Lopezundefined Ramon Cutanda Lopez
                        alt text
                        Regards,
                        @Ramon-Cutanda-Lopez having a menu of options to choose from would be ideal.
                          alt text
                          Regards,
                          @Ramon-Cutanda-Lopez That is the old app 😉
                          Not that the new app supports the elevation to be displayed but you should stop using that app 🙂
                          Ramon Cutanda Lopezundefined 1 Reply Last reply
                            Ramon Cutanda Lopez
                            Thank you Peter and Corjan. When I wrote this post I was away from my device and, just for illustration purposes, the screen capture I used was actually one taken from the YouTube channel: https://www.youtube.com/watch?v=QMCG76K3F0g
                            I had once access to the betas, but lost it at some point. I was not using the Navigation app because its lack of loading routes directly from Carplay. I am currently using 4.2.0, but now that MRA is finally my main navigation app I will ask access to the beta again to test any new features.
                            Regards,
                            alt text
                            alt text
                            alt text
                            • David Emmettundefined Offline
                              David Emmett
                              Just like to chip and agree that I would also like to be able to see elevation while riding. I am using the app directly, not via CarPlay. I'll give the app mentioned above a go, but I'd love to have it in the MRA app as well.
                              GT JWRundefined
                              Graziano 0undefined
                              Graziano 0
                              David Emmett
                              Ramon Cutanda Lopez
                              • Problems with DIY POI Files
                              • Start route bij dichtstbijzijnde routepunt werkt niet
                              • TyuTyu from Hungary
                                Cleoundefined
                                Cleo
                              • Kaart Griekenland in griekse letters
                                ErikMatthezingundefined
                                ErikMatthezing
                              • Different paths between TT and Here algorithms
                                Corrado Miniati 0undefined
                                Corrado Miniati 0
                              • MRA V5.0.3 (449) iOS Gebührenpflichtige Straßen Autobahn ??
                              • Distances between waypoints
                                Wallace Shackletonundefined
                                Wallace Shackleton
                                2.2k
