  3. [App-Beta] Announcements
  4. Updated beta v4.1.0 (276)
35 Posts 14 Posters 559 Views 6 Watching
    Here we are again! ๐Ÿ˜ƒ
    An updated beta is currently coming your way. Traditionally it will be available to iOS in a heartbeat and Android will have to wait slightly longer ๐Ÿ˜‰
    Looking forward to the feedback once again โค
    In summary: everything needs to be stable and working as expected. Especially CarPlay / Android Auto.
    Best,
    Corjan
    Android v4.1.0 (276) is now available. ๐Ÿ‘
    You donโ€™t stop riding when you get old, you get old when you stop riding.
    • Lynchy67 Lynchy67
      @Lynchy67 I loaded 276 on my S20 and also on my older S7. On the S7 the map is no longer displayed. Just a blank screen. I'm able to load a route and start navigation but a map is never displayed. I emailed a log file to you.
      Lynchy67 1 Reply Last reply
        @RetiredWingMan
        I'm just a end user like yourself.
        For me the 4.1.0 (276) works fine on my Samsung S21+
        The log file should go to @Corjan-Meijerink
          Best,
          Corjan
          Edwin_M
          Edwin_M
          Edwin_M
          @Corjan-Meijerink blank screen issue when switching between app still there
          Tested after upgrade
          Did a chache delete retested
          Deleted and reinstalled the app.
          Issue still there.
          Created a log file here.
          Selecting another destination does not refresh to a new map. Only after a specific forced app closure ,and fully restarting the app the map is visible again.
          Log file sent
          • Lynchy67 Lynchy67
            @RetiredWingMan
            @Lynchy67 sorry, it did go to Corjan
              Best,
              Corjan
              Jan Weerheim
              Jan Weerheim
              Jan Weerheim
              @Corjan-Meijerink hallo Corjan, ik heb je per mail de file toegestuurd van m'n s7 alwaar ook met de laatste update (276) de kaart wit blijft. Ik vergat in de mail te vermelden dat de laatste update het op de s10 wederom goed doet.
                Best,
                Corjan
                @Corjan-Meijerink de 276 versie voor Android geรฏnstalleerd en vandaag de eerste test met allen de telefoon. Die verliep perfect. Stabiel, keurig met de routeaanwijzingen. Reageerde goed en snel op afwijkingen van de route.
                So far so good. Nu de test Android Auto nog om te kijken hoe dat gaat. Tot toe een dikke ๐Ÿ‘
                • Jan Weerheim Jan Weerheim
                  @Jan-Weerheim het lijkt er inderdaad sterk op dat hele oude Android versies moeite hebben met de moderne staat van de app ๐Ÿ˜‰
                  Welke Android versie draai je op die s7? En welke op de s10?
                  Jan Weerheim 1 Reply Last reply
                    Jan Weerheim
                    Jan Weerheim
                    Jan Weerheim
                    @Corjan-Meijerink dat zou jammer zijn, temeer het los van AA voorafgaand aan de laatste drie updates prima werkte op android 8 en ik heb ook getest met een oude s6 met android 7 dat ging ook prima.
                    Om je vraag te beantwoorden; op de s7 draait android 8. Op de s10 android 12.
                    Edwin_M 1 Reply Last reply
                      Edwin_M
                      Edwin_M
                      Edwin_M
                      #23
                      @Jan-Weerheim @Corjan-Meijerink
                      Niet helemaal waar. S24+ met laatste Android versie heeft ook problemen wanneer gewisseld wordt tussen apps. Dan blijf ik (soms) ook met een scherm zonder kaart
                      Hoewel ik dat nog niet helemaal kan plaatsen. Later in het proces vroeg de app om 'altijd' rechten. Wellicht dat dat de situatie verbeterd. Deze vraag komt pas als je echt een navigatie wilt starten. Na nieuwe installatie van de app.
                      Zojuist kunnen reproduceren weer.
                      1. Doel kiezen
                      2. Wisselen naar andere applicatie. Bv YouTube
                      3. Terug naar mra . Geen kaart
                      4. Staat navigatie, dan is er nu weer wel een kaart.
                      • Edwin_M Edwin_M
                        1. Doel kiezen
                        @Edwin_M dank voor het doorgeven daarvan! Welke app versie heb je momenteel geรฏnstalleerd? (ik heb in deze 276 versie geprobeerd dat op te lossen zonder dat ik het probleem had ๐Ÿ˜‰)
                        Ik probeer het zeker na te bootsen om de tot mij beschikbare Android telefoons en die tonen (helaas / gelukkig) dit gedrag niet.
                          Edwin_M
                          Edwin_M
                          Edwin_M
                          @Corjan-Meijerink 276, ik heb je 1 maart 20:28 een log gemaild
                          • Edwin_M Edwin_M
                            @Edwin_M ah check, heb hem inderdaad ๐Ÿ™‚
                              @Corjan-Meijerink I also emailed you a log from my S7 Andriod 8. The map is no longer displayed in the app. Navigation works but without a map display. This has just started with the last few updates.
                              I was out today using my S20. I found the tracking of my position on the map to be very jerky and lagged my actual position. I found it to be worse than previous versions (it was a very foggy day if that should matter).
                              I started a GPS Speedometer app in the background. Immediately the tracking was very smooth and no longer lagged behind my actual position.
                                Ik ben zeker geen kenner. Maar lees zo links en rechts wel meer problemen met Android Auto en Samsung S-serie van de laatste paar generaties. Lijkt Samsung smartphone procentueel meer te treffen dan andere merken. Ook de oude Galaxy's lijken minder problemen te hebben.
                                Overigens. Nu 2 routes gereden met de laatste versie van de app op Android Auto. Blijf nog wat voorzichtig maar ben zeker optimistisch. Durf het nu wel voor een weekendje weg te gebruiken. Maar nog niet als enige app.
                                Het aan de gang maken van de app met route gaat nog niet helemaal lekker. Moest de laatste keer 2 of 3 keer de app starten en de route starten voor dat het goed op Android Auto te staan.
                                Toen het eenmaal liep, ging het allemaal goed. Ook het afwijken van de route en automatisch overslaan van shaping points gaf geen problemen.
                                Ga komend weekend nog maar eens paar een keer een ritje maken.
                                  Best,
                                  Corjan
                                  @Corjan-Meijerink Nog weer een test gedaan met alleen de telefoon. App haperde niet
                                  Nog 2 dingen die niet goed gingen.
                                  1 de aanduiding van de benzine pompen op de route ging heb enkele keer goed
                                  2 bij herberekening van de route bleef hij proberen op de aanvankelijke route terug te komen. Sinds zou dat een extra reistijd van ruim 30 minuten opgeleverd hebben. Goede nieuws het herberekenen ook zich ging wel snel๐Ÿ˜
                                    @Marinus-van-Deudekom said in Updated beta v4.1.0 (276):
                                    Wat bedoel je precies. Bedoel je de afstand tot de eerstvolgende benzinepomp langs de route? Wat ging daar precies fout dan?
                                    Is dat niet ook de essentie van de functie? Volgens het huidige algoritme wordt er sowieso pas een WP overgeslagen na 2 herberekeningen naar dat punt.
                                    Ik zie daar overigens wel verbeter mogelijkheden in. Bijvoorbeeld dat op het moment dat je terugkeert op de route, er niet meer wordt teruggeleid naar een vorig punt op de route, maar wordt overgeslagen naar het eerstvolgende punt verdere op de route. Dat is nu niet vanzelfsprekend, maar hangt erg van het verloop van de route af. Dus stel bij route punt 10 geraak je van de route af, om er tussen 15 en 16 weer op terecht te komen. Dat de app dan automatisch verder gaat naar 16 en niet naar punt 15 of eerder, tenzij dat een VIA punt is natuurlijk.
                                      Zo zou het inderdaad moeten werken. Ik kan het niet met zekerheid zeggen maar bij mijn laatste rit leek het inderdaad zo te werken.
                                      Ik heb nog veel te weinig ervaring met de app om er meer over te kunnen zeggen.
                                        @M-Schrijver, nu is het zo dat je wordt geleidt naar het routepunt dat via de weg het dichtst lag bij de positie lag waar je afweek. Een besluit tot het al of niet overslaan wordt pas genomen op het moment dat je van de berekende route afwijkt, en dan pas na de 2e herberekening. Zo kan het gebeuren dat je meerdere routepunten verder terug op de route komt, maar je in feite terug de route in gestuurd wordt. Dat werkt op zichzelf goed in sommige gevallen, maar ik denk dat je als naa routepunt 10 navigeert, door een omleiding tussen 14 en 15 terug op de route komt, en je in de richting van routepunt 15 beweegt, dat je dan kunt aannemen dat je niet meer naar 10 t/m 14 wilt.
                                          @Con-Hennekens hoi Con
                                          De benzinepompaanduiding. Ik bedoel dat op mijn simpele A B route, in dit geval Tilburg Baarn er diverse pompstations langs deze snelweg liggen. Ik kreeg bv de aanduiding dat er een pomp zou komen over 20 km en de pomp die binnen die 20 km werkelijk lag niet werd aangeduid. Als de aanvankelijke 20 km tot een pomp voorbij waren, bleek er daar geen te liggen en werd de aanduiding veranderd naar over 65 km. Ondertussen bleef ik maar pompen passeren die nooit werden aangeduid.
                                          V.w.b de herberekening. Ik reed van Tilburg naar Baarn en werd de A58 als eerste gekozen. Die wilde ik het eerste stuk niet nemen en ik reed binnendoor over Oosterhout. Hij bleef tot voorbij Rijen zeggen dat ik terug naar Tilburg moest. Eindelijk voorbij Rijen kwam de juiste herberekening via Oosterhout.
                                          Op de terug Idem dito maar nu met terugsturen naar de A2 terwijl ik wist dat via de A27 sneller zou zijn. Ook dat bleef hij volhouden tot ik voorbij de A15 was en toen kwam de juiste herberekening
                                          Ik hoop dat het zo duidelijker was. Zoals gezegd het goede nieuws: hij bleef het wel doen ๐Ÿ™‚
                                          Edwin_M
                                          Edwin_M
                                          Jรถrgen
                                          Jรถrgen
                                          Dikke Wim
                                          Dikke Wim
                                          Ruud Schouten
                                          Ruud Schouten
                                          Jan Weerheim
                                          Jan Weerheim
                                          • Hide warnings on the map
                                          • Map Layers
                                            Martin White
                                            Martin White
                                            Michael 2v
                                            Michael 2v
                                          • Bollard trouble
