  3. [App-Beta] Announcements
  4. Updated beta v4.1.0 (276)
35 Posts 14 Posters 559 Views 6 Watching
    Here we are again! 😃
    An updated beta is currently coming your way. Traditionally it will be available to iOS in a heartbeat and Android will have to wait slightly longer 😉
    Looking forward to the feedback once again ❤
    In summary: everything needs to be stable and working as expected. Especially CarPlay / Android Auto.
    Best,
    Corjan
    Dave J 0 Dikke Wim Jörgen Ruud Schouten Lynchy67 9 Replies Last reply
      Best,
      Corjan
      @Corjan-Meijerink so far so good. Updated with no apparent issues on iOS for me. Will test more later.
      Ducati Multistrada V4 Rally
      iPhone 18 Pro
      CHIGEE AIO-6 LTE
        Best,
        Corjan
        Dikke Wim
        Dikke Wim
        Dikke Wim
        Found it Corjan! Thanks, I will test this version again.
          Best,
          Corjan
          @Corjan-Meijerink What are the changes?
          Thanks!
          Dikke Wim Corjan Meijerink 2 Replies Last reply
            Thanks!
            Dikke Wim
            Dikke Wim
            Dikke Wim
            @Jörgen
            If you install the new version you will see the changes the first time you use the MRA App.
              Thanks!
              @Jörgen nothing much compared to last one. Just focussing on stability 🙂 So it should be more stable once again. We also now improved the general zoom behavior while driving.
              @Dikke-Wim correct but not always in great detail. Especially minor changes are not noted there.
              Jörgen Hubert Thoring 3 Replies Last reply
                @Corjan-Meijerink said in Updated beta v4.1.0 (276):
                Ok, thank you.
                  @Corjan-Meijerink: Ist schneller geworden… damit sauberer im Ablauf … Danke dafür 👍
                    @Corjan-Meijerink : kleiner Hinweis
                    Beim Start zum Routenlabor kommt der Kreis kurz doppelt auf den Bildschirm zumindest bei meinem Handy Xr und iPad 9 mit je mit iOS 17.3.1
                      @Hubert-Thoring and they both disappear too 😉 Especially one should be gone very quickly.
                        @Corjan-Meijerink: Sorry für diese Meldung, aber Absturz der App beim Konto öffnen, also oben rechts klick dann Absturz ❗️
                        Fehler lässt sich wiederholen…
                        Habe es auch an Euch geteilt weil die App es gemerkt hat und beim Neustart darum gebeten hat den Fehler zum Absturz zu teilen
                          @Corjan-Meijerink: meine Lösung, App vom Handy gelöscht, noch einmal installiert dann gehts ohne Absturz…
                          So jetzt Test Life on Bike das Wetter passt heute und Zeit habe ich jetzt auch 👋
                            Best,
                            Corjan
                            Ruud Schouten
                            Ruud Schouten
                            Ruud Schouten
                            @Corjan-Meijerink 👍😃
                              Best,
                              Corjan
                              Android v4.1.0 (276) is now available. 👍
                              • Lynchy67 Lynchy67
                                @Lynchy67 I loaded 276 on my S20 and also on my older S7. On the S7 the map is no longer displayed. Just a blank screen. I'm able to load a route and start navigation but a map is never displayed. I emailed a log file to you.
                                Lynchy67 1 Reply Last reply
                                  @RetiredWingMan
                                  I'm just a end user like yourself.
                                  For me the 4.1.0 (276) works fine on my Samsung S21+
                                  The log file should go to @Corjan-Meijerink
                                    Best,
                                    Corjan
                                    Edwin_M
                                    Edwin_M
                                    Edwin_M
                                    @Corjan-Meijerink blank screen issue when switching between app still there
                                    Tested after upgrade
                                    Did a chache delete retested
                                    Deleted and reinstalled the app.
                                    Issue still there.
                                    Created a log file here.
                                    Selecting another destination does not refresh to a new map. Only after a specific forced app closure ,and fully restarting the app the map is visible again.
                                    Log file sent
                                    • Lynchy67 Lynchy67
                                      @RetiredWingMan
                                      @Lynchy67 sorry, it did go to Corjan
                                        Best,
                                        Corjan
                                        Jan Weerheim
                                        Jan Weerheim
                                        Jan Weerheim
                                        @Corjan-Meijerink hallo Corjan, ik heb je per mail de file toegestuurd van m'n s7 alwaar ook met de laatste update (276) de kaart wit blijft. Ik vergat in de mail te vermelden dat de laatste update het op de s10 wederom goed doet.
                                          Best,
                                          Corjan
                                          @Corjan-Meijerink de 276 versie voor Android geïnstalleerd en vandaag de eerste test met allen de telefoon. Die verliep perfect. Stabiel, keurig met de routeaanwijzingen. Reageerde goed en snel op afwijkingen van de route.
                                          So far so good. Nu de test Android Auto nog om te kijken hoe dat gaat. Tot toe een dikke 👍
                                          Edwin_M
                                          Edwin_M
                                          Ruud Schouten
                                          Ruud Schouten
                                          Jan Weerheim
                                          Jan Weerheim
                                          Dikke Wim
                                          Dikke Wim
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                          • Download club route folders
                                            Mosimann
                                            Mosimann
