  4. Navigation event option
12 Posts 3 Posters 1.6k Views 2 Watching
  • Albert Rentingundefined Offline
    Albert Renting
    Hello, a question: when creating an event, it used to be, in the past, that, when clicking on the Navigation Event option, that tracklogs were automatically added to the event when it was driven.
    Is it me, or does this not work anymore?
    Jack van Tilburgundefined 2 Replies Last reply
    • Albert Rentingundefined Albert Renting
      Jack van Tilburg
      @Albert-Renting
      When creating the event, there is an option to organize this.
      I think there is a check box asking if it is a navigation event.
      You can also place a check mark afterwards. If you choose to edit the event, the check box will be at the top right of the screen.
      Albert Rentingundefined 1 Reply Last reply
        Jack van Tilburg
        @Albert-Renting
        It all in: manual-events
          @Albert-Renting
          Albert Renting
          @Jack-van-Tilburg
          Hello Jack, I am aware of this option and I use it as well, only, after having driven the event route, I have to add the tracklog manually to the event!
          In the past this tracklog was added automatically!
          The tracklog would appear under 'Tijdlijn'
            @Jack-van-Tilburg
            Jack van Tilburg
            @Albert-Renting
            Could it not be that the track log ridden on 24 - 02 is added? That is the start date of your event.
            The other screenshot shows the option to "also". manually add tracks.
              @Albert-Renting
              Albert Renting
              @Jack-van-Tilburg
              Hello Jack, I am aware that the pictures I included are from events in the future, so there is no Tracklog (yet) for this event. The pictures were only to 'clarify' my intentions.
              But, past events had the problem that I had to add the Tracklog manually to the event while in the past this happened automatically (when the box was checked beforehand)
                @Jack-van-Tilburg
                Jack van Tilburg
                @Albert-Renting
                Since there have been no changes to the MRA Planner for quite some time, it is unlikely that the cause lies there. I have pointed out the obvious causes. If they are not, you will probably have to look for the cause somewhere in your own settings. That becomes difficult with something that is in the past.
                I would then do a test myself with a new event. Unless you can point out that this not functioning appeared after a known new version of the NavApp?
                  @Albert-Renting
                  Albert Renting
                  @Jack-van-Tilburg
                  Hello Jack, same thing happened yesterday after driving an event; I had to manually add the tracklog while the Navigation event box was checked.
                  If I recall correctly, this started when the 'new' MyRouteapp was introduced, so a long time ago!
                  When it was still the 'old' version, MyRoute-app Navigation, it worked fine.2024-02-18 10.10.39.jpg
                    @Jack-van-Tilburg
                    Jack van Tilburg
                    @Albert-Renting said in Navigation event option:
                    That seems like a clear indication.
                    Let's wait for responses from other NAV users here. Otherwise it might be better if you create a support ticket.
                    (maybe @Corjan-Meijerink reads along)
                      Correct! This was not used as much and therefore it hasn’t been added in the new app.
                      I will put this up for discussion again.
                        Albert Renting
                        Okay, so, I was not imagining this.
                        I did use it a lot and am now manually adding the Tracklogs to my events after I've ridden them.
                        If it can not be re-implemented, perhaps remove the option from the settings?
                          @Albert-Renting yeah exactly. We will either implement it in the app, or remove the option 🙂
                          Albert Renting
                          Jack van Tilburg
                          • Imported POI files visible in App
                            Keith Hofgartnerundefined
                            Keith Hofgartner
                          • How to exclude short time road blocks during navigation
                            Axel Härtlundefined
                            Axel Härtl
                          • The route is planned to go the wrong way round the roundabout
                          • Geen routeberekening
                          • Onbegrijpelijke omweg
                            Lex.Kloet.RXundefined
                            Lex.Kloet.RX
                          • Apple Carplay. MRA Navigation stops after re-calculating
                          • Truck / Camper Dimensions
                            Herman Veldhuizenundefined
                            Steve 2vundefined
                            Steve 2v
