  3. Nav 6 without plugging in
7 Posts 4 Posters 1.1k Views 2 Watching
  • Colin Hodgkinsonundefined Offline
    Colin Hodgkinson
    Good afternoon,
    I have plotted loads of routes on my route and downloaded but my wife has asked that if we get there and a road is closed for whatever reason can we create a route on a tablet that we take and get it onto a nav6 with plugging it in.
    Stuart Greerundefined Mzokkundefined 2 Replies Last reply
    • Colin Hodgkinsonundefined Colin Hodgkinson
      Good afternoon,
      Stuart Greerundefined Offline
      Stuart Greer
      @Colin-Hodgkinson the only way I have found is to share the map from another Garmin device via Bluetooth. during a recent tour I would produce the route for the day on MRA and upload it to an XT via Garmin Drive app and then share it with the Nav 6s and 5s via Bluetooth sharing. It works well.
      I used to use a NAV 6 and had a USB C to A adaptor that I could upload to the device via a cable from an android tablet or phone. I dont use iphone so cant comment on that
      Colin Hodgkinsonundefined 1 Reply Last reply
      • Stuart Greerundefined Stuart Greer
        Colin Hodgkinson
        @Stuart-Greer hi, thanks for that. If I have it on my phone can I Bluetooth it,
        K
        Hubert Thoringundefined Stuart Greerundefined 2 Replies Last reply
          K
          @Colin-Hodgkinson : Beim N6 gehts nur mit dem Kabel und USB Adapter…!
          iPad 9. Gen iOS 26.3.1 / iPhone 16e iOS 26.3.1/ iPhone Xr iOS 18.7.6 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
            K
            Stuart Greer
            @Colin-Hodgkinson unfortunately not Colin, hard to believe on such as expensive device.
              Good afternoon,
              Mzokkundefined Offline
              @Colin-Hodgkinson If you have an Android phone you can connect the Nav 6 directly to the phone and download the GPX file to the device.
              Older Garmin GPS devices can’t use Garmin Drive to transfer routes to the unit. For those with Old units and an Android phone the GPX files can be transferred as follows. (Tested on a Zumo 340 390 and BMW Nav 4). So that you can have a compact on the Fly routing solution for trips.
              1. Download the route you want to put on the device from MRA routeplanner to your phone.
              2. Connect the phone to the Garmin GPS device with the Garmin unit lead and a USB (A) female to USB (C) adaptor or a USB (C) to mini USB(B) lead. I’m not sure that this will work with a phone that has a micro USB connector (with the appropriate adaptor or with an apple phone)IMG_20231031_195702573sml.jpg
              3. Open the phone and navigate to its file manager. This varies depending on the make of mobile phone/personal choice but you should see the Garmin as an attached device. The Garmin USB device is just the SD card if you have one in your unit.
              1. I had downloaded a route from MRA routeplanner onto the phone so I hit the downloads button and selected the file I wanted to transfer.
              2. And copied it into the Garmin>GPX folder
              3. The file will appear on your imports on the device.
              Similar transfer capabilities could be achieved with a USB(C) micro SD card reader and transfer the micro SD card with the GPX file on it from unit to unit.
              • Mzokkundefined Mzokk
                Colin Hodgkinson
                @Mzokk Thank you
                Mzokkundefined
                Colin Hodgkinson
                Stuart Greer
                  Martin Wilckeundefined
                  Martin Wilcke
                  guenniguenzelsenundefined
                  guenniguenzelsen
                • Preview
                  Iain Cochrane 0undefined
                  Iain Cochrane 0
                • batterij verbruik
                • Carpuride
                • What is this symbol?
                  Aiello antoninoundefined
