  4. Battery drain
Battery drain
24 Posts 16 Posters 12.7k Views 6 Watching
  • Kudee
    Kudee
    Kudee
    wrote on last edited by Kudee
    I'm slowly getting tired of it. 3 hours of driving and MRA sucks 4.5Ah! I just expect a statement! "We don't know either and we won't be able to solve it in the foreseeable future? or we concentrating on other things?"
    • Kudee Kudee
      @Kudee You have probably missed this: https://forum.myrouteapp.com/topic/4995/statement-regarding-battery-usage (as well as multiple other threads on this forum discussing the same topic).
      Drabslab 1 Reply Last reply
        @Herko-ter-Horst
        We are Q1 2024, not Q3 2023.
        Also for me Next is fairly useless under current conditions and I am waiting "patiently" until I read here that the battery issues are resolved.
        The advantage is that I don't comment on Next, and don't make feature suggestions, as I am not using it. 🙂
        Not the fault of the MRA team, that may be correct, but still (''çà§ annoying
        • Drabslab Drabslab
          @Herko-ter-Horst
          @Drabslab said in Battery drain:
          I fully support this statement by @Drabslab . I have a lifetime subscription but don't use it.
          (Although I have more reasons then mentioned here, but that is not what this topic is about 😉 )
          GT JWR Adam Collier 0 2 Replies Last reply
          • TorqueRider TorqueRider
            @Jack-van-Tilburg agreed....very annoying. I've been able to use it in the 'winter' months here in Texas, but now as it is getting nice again (temps 80degF and higher), using the Nav app is longer feasible. The combination of the excessive heat caused by the battery drain issue, combined with the warmer ambient temp, the iphone goes into protect mode and when it does this, the screen becomes too dark to see the app. 😠 😧 😖 😞 ....perhaps.one.day...
              Adam Collier 0
              Adam Collier 0
              Adam Collier 0
              @Jack-van-Tilburg
              Completely agree. Same issue here. Lifetime subscription and not used at all because of the battery drain.
              App is not fit for purpose
              Fix as a priority or offer a full refund to lifetime subscriptions
              Gerrit van Kuilenburg 1 Reply Last reply
              • Adam Collier 0 Adam Collier 0
                @Jack-van-Tilburg
                @Adam-Collier-0 Is the still the case? I have also stopped using it because of battery drain. Waiste of life time money. Was hoping it might be solved now.
                • Gerrit van Kuilenburg Gerrit van Kuilenburg
                  @Gerrit-van-Kuilenburg, It is still not on par with most other navigation apps, but it has been mitigated quite a lot. Although the drain is still large in some (almost random) cases, the amount of users having to put the app aside because of it is much much smaller.
                  • Mopetenpit
                    Mopetenpit
                    Mopetenpit
                    Here is my experience on the subject: the USB socket (BMW 1250 GSA, 2.4 A) can actually charge my iPhone XS Max while the navigation system is running. However, if I set the iPhone display to full brightness (=100%), the charging power is not sufficient - the iPhone then only lasts a few hours... Perhaps this information will help some MRA users.
                    • Anonymouse
                      Anonymouse
                      Anonymouse
                      Just waking this thread up to see if there is any improvement in the works. MRA is pulling so much power that the phone goes into thermal protection mode and (a) dims the screen so we can't see anything; and/or (b) disables charging and the battery level plummets.
                      • MartinW
                        MartinW
                        MartinW
                        I used consumer smartphones for navigation over several years, including both iPhones and Android devices. And yes, there were some rugged phones.
                        It never worked well; the most critical issue was overheating with all the effects you mentioned.
                        Besides all the information available regarding this topic, it was this one blog entry that opened my eyes:
                        https://www.thorkracing.com/android-nav-devices-reality/
                        (have a look at "The Battery Discharge Problem").
                        I'm not a technician and therefore can't judge the importance of the points mentioned there. However, after switching to one of these devices (I had an 8" first but stepped down to the 6"), all problems are gone. No overheating, no draining, no nothing. It's a "buy once, cry once" decision, but it's worth it.
                          Update 4.4.0 now in beta has the most significant improvements in battery usage up until now!
                          We see ~20% less energy consumption om all devices.
                          We expect it to be released to the public next week 🎉
                          • stuart marritt
                            stuart marritt
                            stuart marritt
                            Lets hope this update doesn't break mine 😬
                            Never had any battery issues using a samsung S20 in all sorts of conditions with the screen on full brightness. Always stays fully charged and never overheats!
                            • MartinW MartinW
                              @Martin-Wilcke hi Martin
                              Since I am using the T865X there are no problems on my sidecar as well. When I go out riding with 50% battery, I come back after a day of riding with a fully charged tablet
                              MartinW 1 Reply Last reply
                                MartinW
                                MartinW
                                MartinW
                                @Marinus-van-Deudekom
                                That's exactly my experience.
                                The supposedly high price puts off many users - but for the 6" device, you pay approx. €600 (EU price), including holder and power supply, providing a solution particularly designed for use on a motorbike. Compared to a corresponding setup, such as a consumer or rugged smartphone (or Garmin/TomTom, by the way), it's competitive.
                                You also get a lifetime licence for DMD2, which, in my opinion, is the best solution for "real" track navigation at the moment.
                                I am very pleased with the combination of T665, MRA and DMD2.
                                • Marinus van Deudekom
                                  I couldn’t agree more. Very happy with the T865X witch is €865. Things of great quality are not cheap. With the DMD2 you get the best Off both worlds
                                  • Twan Verbeek
                                    Twan Verbeek
                                    Twan Verbeek
                                    With the latest version the power drain should have been reduced significantly. It got al lot worser on my iPhone the battery drain without using the app is horrendous.
                                    • Anonymouse
                                      Anonymouse
                                      Anonymouse
                                      Version 4.4.0 has significantly improved battery drain in use … but I see that MRA is still drawing power even when the app is killed. Overnight it seems to be the only app on my phone doing so except for “Find My”, and MRA is using 15x as much as that.
                                      Is this intended behaviour?
                                      If I turn off “background app refresh” for MRA what effect on functionality would that have?
                                      Anonymouse 1 Reply Last reply
                                      • Anonymouse Anonymouse
                                        Anonymouse
                                        Anonymouse
                                        Anonymouse
                                        wrote on last edited by Anonymouse
                                        Further to my post above, MRA seems to be draining battery when killed on my phone but not my partner’s phone. Is it because I have killed the app after day 1 of a road trip while it was navigating, so I can resume on day 2?
                                        I can’t see why it needs to drain power when the app has been killed, whether or not there was a journey in progress when it exited.
                                        • Anonymouse
                                          Anonymouse
                                          Anonymouse
                                          Anonymouse
                                          Anonymouse
                                          Kudee
                                          Kudee
                                          MartinW
                                          MartinW
                                          Mopetenpit
                                          Mopetenpit
                                          stuart marritt
                                          stuart marritt
                                          Twan Verbeek
                                          Twan Verbeek
                                          Adam Collier 0
                                          Adam Collier 0
                                            randy etheridge
                                            randy etheridge
                                          • Question on Beta access
                                          • Add "Upload File"
                                            John Matthews 0
                                            John Matthews 0
                                          • Miscalculations of distance and time between waypoints
                                            Matjaz Valjavec
                                            Matjaz Valjavec
                                          • Kan ik mijn oude account van de standaardrouteplanner verwijderen?
                                            Parantapa
                                            Parantapa
                                          • On my "Route lab" on my computer, what version
                                          • Elevation profile: cursor that follows the route on the map
                                            LE DIZES Freddy
                                            LE DIZES Freddy
