  3. Offline maps and routing
34 Posts 13 Posters 25.7k Views 4 Watching
    @Doug-Robinson
    Thanks Doug. The app is really not very intuitive, and it seems the offline navigation isn’t really offline navigation if it will only run a pre calculated route, and only then if started from the download folder.
    Why would I read a manual? If I have to read a manual to do something very basic then there’s an issue with the app. Especially if it’s for something like offline navigation which I would use only if I couldn’t use online navigation.
    Some different thinking form the devs needed here, maybe.
    @Berin, on the contrary, the app is VERY intuitive. Even intuitive software has a certain learning curve, especially if you previously used another tool for the same thing. I did not read the manual either, and I think it is VERY intuitive 😉
    The app makes perfect sense if you understand what it is doing. What it is doing is probably a bit different from what you are used to. Downloading offline maps is not the only thing needed to navigate completely offline. Offline maps are there mainly to prevent bandwidth usage while navigating. And of course offline maps are obligatory for offline navigating. Offline navigation is enabled in the settings: Navigation settings - Functional.
    Pay attention also to the setting at the arrow. This one automatically makes available for offline usage all previously chosen routes. You only need to enter the download folder if at the time of choosing a route, you have no internet connection. The folder-view you see when tapping the Routes button in the main menu is a view into your online routes library. It is not so strange that it is not available when not having an internet connection. If you compare this to downloading routes to a Zumo or Rider, it is pretty much the same thing. With the added benefit of not having to do that at all, if your phone is connected to the internet. See? Pretty intuitive 😉
    A Former User? NineLizards 2 Replies Last reply
    • paul69
      hi all,
      just my two penneth,
      I only ever use offline navigation, and currently use an oukitel rugged tablet mounted on bike, so obviously android OS.
      i am a beta tester and have been for many months, initially iOS but now android due to the tablet.
      what i have noticed is, if my tablet battery runs empty, i.e. not used it for a few days and I then have to charge it, when turned on it will not run in offline mode immediately. I use addresses that are in my favourites to test this.
      every time i must connect to wifi, for a few seconds and then place next back in offline mode, all then works as it should.
      this leads me to believe that when the app completely shuts down it needs an internet connection following reboot, this could be a problem with tablet or other outside factors, but i write it here in hope it may help someone out.
      this is also not a concern to me as i now know what i need to do, periodically I shut down the tablet completely, which gives the same result.
      hope it's of some use to somebody
      K1600 GTL
      Oukitel RT3
      iPhone 13 Pro, carpuride 702b
      Jörgen 1 Reply Last reply
      • paul69 paul69
        hi all,
        @paul69 said in Offline maps and routing:
        hi all,
        Interessing point! I use also an Oukitel tablet and I have not noticed that, because when the battery was empty I always was in my home wlan.
        It could be an issue in an "no internet" region.
        paul69 1 Reply Last reply
          hi all,
          hi @Jörgen
          this wasn't a complaint, and only intended as info for other users who may have a similar issue.
          i don't let the battery run down when it's on the bike, i have a usb lead attached. when in sleep mode this issue never happens.
          the tablet is at home when the battery runs out, if left for 2-3 days of no use.
          I have wifi at home, it is with this i carry out updates etc. I do not use a sim card, hence the offline navigation.
          When i charge it up and start the app, it opens up in offline mode as that is how i have it set up.
          as explained above, it always needs to have wifi enabled after reboot.
          K1600 GTL
          Oukitel RT3
          • paul69 paul69
            hi @Jörgen
            complaint
            Don´t worry, I understand this as Info only. 👍
              A Former User?
              A Former User?
              A Former User
              Thanks for that. So, in summary, to navigate offline, while online;
              Download maps
              Set routing to offline
              Set routes to be available offline
              I’ve tried that with. The phone set to airplane mode and everything worked fine, including poi searches like petrol stations!
                Download maps
                @Berin said in Offline maps and routing:
                Download maps
                You are welcome, glad it worked out.
                Hmm, I am thinking after a reboot perhaps the app needs to re-validate your account info...
                  Download maps
                  hi @Con-Hennekens said in Offline maps and routing:
                  I have never actually made any tests of this, it just happens. I did not think it was an issue, i just presumed it was normal, and everyone had to do it.
                  I will carry this task out a number of times using different methods, with online, offline, airplane mode and any other way i can think of and report my findings
                  K1600 GTL
                  Oukitel RT3
                  • Dikke Wim
                    Dikke Wim
                    Dikke Wim
                    I'm wondering: is the satellite view also downloaded when downloading a map for off-line use, or is it only the HERE map?
                    • Bouke Ent
                      ik weet dat dit misschien niet direct te maken heeft met dit topic. ik begrijp dat focus van MRA is offline is geheel offline. ik heb dit in italie aantal keren gedaan en dan kreeg ik in 50% van de gevallen route is niet te bereken. er zijn inmiddels updates geweest dus misschien werkt het nu wel. ik begrijp alleen niet de keuze volledig offline. in mijn oude kurviger v1 app kan ik gewoon kiezen kaarten offline gebruiken en routing offline gebruiken. zou dit niet een betere keuze zijn om deze 2 te scheiden dan kan je in hotel met wifi route starten en met offline kaarten rijden. mocht je onderweg even geen internet hebben dan gaat alles wel door.
                      • Dikke Wim Dikke Wim
                        @Dikke-Wim said in Offline maps and routing:
                        Goeie vraag... Gebruik jij die daadwerkelijk voor het navigeren? In eerste instantie zou ik denken van niet, want het betreft een kaartlaag. Als je ine vliegtuigmodus een route start met de sateliet-laag aan, zie ik in eerste instantie wèl de satelliet kaart, waarschijnlijk vanuit de eerder gedwonloade cache. Echter als je gaat scrollen kom je in gebieden waar de kaart heel pixelig wordt. Ik denk dat dat een soort basis-kaart betreft, maar die is niet bruikbaar voor navigatie. Voor de route maakt dat verder niet uit, (die calculeert op de gewone kaart) maar de omgeving wordt wel onherkenbaar op het scherm.
                        @Bouke-Ent said in Offline maps and routing:
                        Volgens mij is dat al precies wat we doen, toch? De optie "offline navigeren" doet precies wat Kurviger doet met "routing offline gebruiken". De Kurviger optie "Kaarten offline gebruiken" hebben we niet nodig, want dat doet MRA al vanzelf zodra de kaarten offline beschikbaar zijn. Het lijkt me vreemd dat je zou kiezen voor online kaarten als je ze al offline gedownload hebt.
                        Bouke Ent 1 Reply Last reply
                        • paul69
                          good morning @Con-Hennekens
                          I told you I would report my findings following tests.
                          it would appear I was mistaken, although the anomaly I reported had happened a number of times, perhaps it was bug within my tablet.
                          my tablet had no internet connection, wifi or otherwise during these tests. this is to imagine I was in the middle of nowhere with no connection.
                          tests as follows;
                          airplane mode and offline nav enabled>power off>power on>choose favourite destination>could not navigate route>10 seconds later>navigation possible.
                          and the ability to search for an address and navigate to that address i.e. A-B route.
                          also possible to load and navigate a downloaded route including the ability to continue from a different waypoint other than the start point.
                          airplane mode>offline navigation disabled>power off>power on> choose different favourite>short delay>navigation possible.
                          point to note, offline navigation had enabled automatically.
                          @Con you are probably aware of the above, but maybe this will help others understand the offline nav and no internet problem.
                          this is why I always use offline navigation and my tablet in airplane mode, this also helps battery life.
                          TBF I don't need traffic reports when on my motorbike, it would be different if I was in my campervan of course.
                          K1600 GTL
                          Oukitel RT3
                          • paul69 paul69
                            tests as follows;
                            @paul69, thanks, I am glad it worked out.
                              I believe, for me and in my experience, the best way is to always use navigation with the device in airplane mode, this was the same when using my iPhone, this prevents all the problems with internet connection being lost or intermittent.
                              Personally. I have not yet found a reason for the need to have an internet connection while navigating a route, pre-planned or otherwise.
                              Caveat, providing you have previously downloaded all the routes you had planned for the tour, which is a must, as I learned the hard way.😠
                              K1600 GTL
                              Oukitel RT3
                                @Con-Hennekens hoe gaat offline dan om als je een regio niet gedownload hebt ? bv je hebt nederland gedownload en die zou hij dus offline pakken maar je rij belgie in pakt hij dan wel de online ? in kurviger krijg je dan al te voren melding route is niet mogelijk en op je scherm zie je geen kaart. bij kurviger v1 als je dan geheel offline ging had je optie om brouter te gebruiken maar dan moest je ook dekking hebben. ik zelf download altijd geheel mijn regio's en ik begrijp dus nu dat hij automatisch die pakt en dat scheelt al een deel van je data. hopelijk gaat offline route berekening komend jaar wel goed maar dat is afwachten.
                                • Bouke Ent Bouke Ent
                                  @Bouke-Ent, Je route staat gecached, dus die gaat gewoon door. Je kaartweergave zal leeg zijn, maar de routelijn is nog steeds conform de werkelijkheid. Op het moment dat er iets van herberekening moet plaatsvinden ga je de mist in. Vraag me niet hoe ik dat weet... 😉
                                    @Con-Hennekens bedankt voor uitleg.
                                      @Doug-Robinson
                                      @Berin many of the functions are very intuitive for basic operation. If you play with it long enough and try everything possible on the screen, eventually you learn most of it. I had a lawyer complain to me that the new phone system we installed should be intuitive enough that he should not have to attend training. I told hom that I'm sure he can figure out how to receive and make phone calls, but if he wants to learn how to make full use of the features of the system he should attend training. He eventually did.
                                      A Former User? 1 Reply Last reply
                                        A Former User?
                                        A Former User?
                                        A Former User
                                        @RetiredWingMan Fascinating story, I'm sure.
                                        However all this was resolved about 2 months ago.
                                        Jorge del Valle 1 Reply Last reply
                                          Jorge del Valle
                                          Jorge del Valle
                                          Jorge del Valle
                                          wrote on last edited by Jorge del Valle
                                          #25
                                          I've tried using offline navigation today for the first time, and it didn't work. I had both the country map and the route downloaded. My phone was in airplane mode when I launched the app. I selected the route from the downloads list, and then tapped the button to start navigation, which then resulted in this screen.
                                          I've checked the online manual and the forums and as far as I can tell it should work as long as I've downloaded the region map and the route. Am I missing something?
                                          Edit: I've found a forum post that I somehow missed in my initial search, where another user says they solved the problem by rebooting the phone and then waiting a few minutes when they got the message and the routing eventually started working. I'll give that a try, but is that (having to wait several minutes for offline navigation to work) expected behaviour for the app?
                                          Jorge
                                          Dikke Wim
                                          Dikke Wim
                                          NineLizards
                                          NineLizards
                                          Nigel Ralphson
                                          Nigel Ralphson
                                          Jorge del Valle
                                          Jorge del Valle
                                          A Former User?
                                          [[global:former-user]]
                                          • Routenplaner on iPad
                                          • Rondrit generator ervaring
                                            Sam Kramer
                                            Sam Kramer
