  4. Feature Request: POI and Favorites rework
4 Posts 4 Posters 994 Views 3 Watching
  • mdjundefined Offline
    mdj
    Hello, I would love to see a more robust POI and Fav system implemented. Afaik, currently personal POIs are only saved in the route you created them in, when you open a different route you cant access them anymore. It would be more usefull if they were permanently in your liberary, just like Favorites are.
    I would also like to be able to organise my POIs into folders and give them different icons. Then, out of this library of POIs (or map-bookmarks) i can choose which ones i want to favorite.
    I have a lot of POIs in a different software i have been using and when trying to port them over, i realized the only way to really do it is to add all of them as a Favorit. But i really dont want to have a 200+ items long unorganized Fav list 😕 also if everything is a Fav, nothing is 🙂
    Anyway, thanks for reading. I hope this gets considered since it would make my routeplaning much much more plesant.
    Jack van Tilburgundefined Hans van de Ven MR.MRAundefined Corjan Meijerinkundefined 3 Replies Last reply
    • mdjundefined mdj
      Jack van Tilburg
      @mdj said in Feature Request: POI and Favorites rework:
      All your points have been mentioned several times on the forum and I think there will be improvement. Although I have no idea when.
      you can import POIs by means of the 'upload' button on the general Routelab screen or the 'new' button in your route list. You need to select the POI option instead of route/route-track/tracklog option.
      These POIs can then be found in the <Points of interest> in the left column on your screen (if you have opened a route).
      • mdjundefined mdj
        @mdj
        This will be taken into account as soon as the website undergoes major maintenance
        • mdjundefined mdj
          @mdj All of this is definitely in consideration! 🙂
          Jack van Tilburg
          mdjundefined
          mdj
            PieterGundefined
            PieterG
          • route from Amsterdam to Amalfi coast please
            Lex.Kloet.RXundefined
            Lex.Kloet.RX
          • MyRoute-app wedding
            LE DIZES Freddyundefined
            LE DIZES Freddy
          • 1richtingsweg staat verkeerom in de App
          • Adding Toilets as a POI
          • MyRouteApp eigen gemaakte Route 2x langs afgesloten weg ???
            Marcel Versluisundefined
            Marcel Versluis
          • Update Afsluitingen Nederland
            Herman Veldhuizenundefined
            1.1k
