  4. Vehicle cursor not visible
10 Posts 6 Posters 1.3k Views 3 Watching
    Corrado Miniati 0
    When navigating in landscape mode, the vehicle cursor is often not visible and does not remain in the center of the screen to allow you to understand the road you are traveling on, is this normal?
    Thanks a lot
    Nick Carthewundefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
    • Corrado Miniati 0undefined Corrado Miniati 0
      Thanks a lot
      @Corrado-Miniati-0 Touch the compass to centralise the screen.
        Thanks a lot
        @Corrado-Miniati-0
        Did you already have a manual for Navigation Next?
        https://mranavigationnext.app/manuals/
        • Jörgenundefined Offline
          happens sometime also on my tablet, open and close the menu, then the cursor is back (works for me).
          Corrado Miniati 0undefined 1 Reply Last reply
          • Jörgenundefined Jörgen
            Corrado Miniati 0
            @Nick: I had done that but it didn't center the vehicle slider.
            Driving in a busy intersection you can't take your hands off the handlebars to touch the screen, it would be nice to solve the problem.
            @Hans: no, thanks a lot for the link.
            @Jorgen: Thanks for the tip.
            It is also true that if it happens to you while you are busy driving you cannot do it.
            So can you confirm that it's a bug?
            • richtea999undefined Offline
              @Corrado-Miniati-0 said in Vehicle cursor not visible:
              A Bluetooth controller will solve that issue (at a cost). They mimic keypresses which the MRA app recognises - including re-centreing the map.
              Several are available from make-it-yourself, though to affordable up to top end ones.
              Corrado Miniati 0undefined Con Hennekensundefined 2 Replies Last reply
                Corrado Miniati 0
                @richtea999
                Hi Richt and thanks for feedback.
                However, I think it would be more useful if the app centered the vehicle symbol on the screen without adding any additional devices, it could certainly do that.
                  @richtea999
                  @Corrado-Miniati-0, Your flyer can get out of center if you accidentally touch or swipe the screen a little. Sometimes that happens unintentionally. Since a few versions ago, the app automatically recenters when driving and no screen interaction is done for 5 seconds or such. So what you think it should do, it already does 😉
                  I might seem far fetched, but I have some experience with problematic touch LFD's: clean your screen thoroughly, with some moisturized screen cleaner fluid. And check if there is anything between your screen and the screenprotector, if there is any. If your device has a glove-setting, try to toggle it to see if it helps.
                    @richtea999 said in Vehicle cursor not visible:
                    It looks like the screen thinks it gets touched. Extra buttons will not solve that, unless you use a touch-blocker.
                      Corrado Miniati 0
                      @Con-Hennekens Thanks for the advice, I'll try to see if it still happens by cleaning the screen.
                      I must say, however, that with other navigation apps on the same device this situation does not happen.
                      Corrado Miniati 0
                      richtea999undefined
                      • How to exclude short time road blocks during navigation
                        Herman Veldhuizenundefined
                      • Imported POI files visible in App
                      • Onbegrijpelijke omweg
                        Lex.Kloet.RXundefined
                        Lex.Kloet.RX
                      • Routeoptie wordt niet meegenomen
                        Axel Härtlundefined
                        Axel Härtl
                      • Geen routeberekening
                      • DMD - T865x + BMW sync box + bedienen MRA met Wonderwiel
                        PieterH_GSundefined
                        PieterH_GS
                      • Routepunt overslaan werkt niet correct?
                        reinier.beenengmail.comundefined
                      • Geen notificatie bij uitnodiging evenement
