  4. Navigation next doesn't restart navigation from the current position?
20 Posts 8 Posters 2.9k Views 4 Watching
    Corrado Miniati 0
    When navigating today's itinerary 1 (attached), after restarting from stop no. 25 the app wanted me to return to point 1 instead of proceeding with waypoints no. 26 even though I had chosen the "calculate from your current location" option ", to proceed correctly I had to manually delete all points 1-25.
    Where did I go wrong?
    Thanks a lot
    Rob Verhoeffundefined Hans van de Ven MR.MRAundefined 2 Replies Last reply
    • Corrado Miniati 0undefined Corrado Miniati 0
      Thanks a lot
      Rob Verhoeffundefined Online
      @Corrado-Miniati-0 I'm not sure why this happens, but you can easily correct it. If you restart the app and find yourself being directed back to the starting point, longpress and hold the point on the map from which you want to continue the route. From that moment on, you'll navigate from the point where you restarted the app, continuing along the rest of your route as usual.
        Corrado Miniati 0
        @Rob-Verhoeff
        Hi Rob and many thanks for feedback.
        We should investigate because in any case it is very inconvenient for this to happen if you are already ready to go and have put on your winter gloves.
        If I hold down the waypoint on the map (on attached example n.26) the message appears: "Skip waypoint, continue from n.26", did you mean this?
          @Rob-Verhoeff
          @Corrado-Miniati-0 said in Navigation next doesn't restart navigation from the current position?:
          Yes I do.
          Corrado Miniati 0undefined 1 Reply Last reply
            Yes I do.
            Corrado Miniati 0
            @Rob-Verhoeff
            ok thanks but but I hope that the evidence that users transmit in the forum is also read by the developers in order to be able to carry out checks and improve the software more and more.
              @Rob-Verhoeff
              Yes, they do!
                Yes, they do!
                Corrado Miniati 0
                @Rob-Verhoeff
                Even in today's navigation I encountered the same problem as yesterday, Navigation Next continues to want to take you to starting point 1 even when you have already gone far along the path, in this way the app becomes unusable for me, is it a bug?
                Thanks a lot
                  @Rob-Verhoeff
                  Thanks a lot
                  is it a bug?
                  I really have no idea. The app works fine for me.
                    Thanks a lot
                    @Corrado-Miniati-0
                    Do you use the Here map to create your routes? Navigation Next uses the Here card for Navigation.
                    Place the shaping and waypoints correctly on the black route line
                      @Corrado-Miniati-0
                      Corrado Miniati 0
                      @Rob: thanks for the feedback, I need to understand the reason for this incorrect management
                      @Hans: thanks for the feedback, I don't use Here but OpenStreetMap because it is the only option that allows me to use the segments, with Here they are disabled.
                      Do you have any suggestions?
                        M. Schrijverundefined Offline
                        The few times i used the app to restart a route it always tried to sent me back to the 1. point.
                        This already so for multiple software versions.
                        The chose map in the routeplanner should not have any influence on this behaviour.
                          @Corrado-Miniati-0
                          After you planned the route, change map to Here and check the route
                            @Corrado-Miniati-0
                            Corrado Miniati 0
                            @M. Schrijver: thanks for the feedback but if you also noticed this behavior does it mean that the app has a major bug?
                            Do the developers read the forum and are aware of it?
                            @Hans: thanks for the feedback, ok I will.
                            I thought some users had already verified this solution.
                              When you stop navigation you should get a screen like the one below. At this point just close the app. When you restart the app, this screen should reappear and you choose to resume navigation by clicking the yellow navigation box or click No to end this resume option.
                              • Vincent Currenundefined Offline
                                Vincent Curren
                                I was out for a ride today. I strategically planned my route to go past a wine store that I liked. I pulled into the parking lot, stopped navigation, went in and bought my wine. When I came out, I pressed "resume navigation," and the software picked up my route from where I was. So, it's working for me. This is on an Android phone, by the way, a Pixel 6.
                                I'm glad to be reminded of the Long-press option, though, in case I need it in the future.
                                Vinnie
                                  Corrado Miniati 0
                                  @Douglas: Thanks for the feedback.
                                  I checked, it's as you say, but if you accidentally click on "No" then the app doesn't understand where you are to continue with the planned itinerary?
                                  What is the purpose of the "Calculate from your current location" option that you can use if you start browsing again?
                                  @Vinnie: great review, worth what was written for Douglas.
                                    @Corrado-Miniati-0, Yes, if you pressed "NO" in that position, it is quite clear that starting a new route will advance from the first WP. That is no bug, that's just how it works. Change your habit to put the gloves on only AFTER the route is correct on your device 😉
                                    The slider makes it possible to not include the part from the location where you are to the start point of a route, in the duration and the distance of the route.
                                      Corrado Miniati 0
                                      Thanks Con for the explanation but knowing the current location via GPS, couldn't the app proceed to the next waypoint without returning you to the starting point?
                                      Maybe I'm wrong but it seems logical to me.
                                        As good as the app is, it is still not capable of reading minds 😁
                                        If navigation was turned off and a second confirmation to turn off was chosen the app will think that you want to start the route again from the beginning.
                                        A long press on the next route point or choosing the route point from the waypoint list in the navigation menu will start the route from your chosen position.
                                          Corrado Miniati 0
                                          @Nick-Carthew
                                          Nick thanks for the feedback.
                                          Maybe with AI MRA will also get there....😊
                                          Jokes aside, I will use the method you suggested, even if for my way of thinking it seems logical to continue along the planned route after a stop and instead I would force it if I decided to change it.
                                          RetiredWingManundefined
                                          Corrado Miniati 0
                                          Vincent Curren
                                          • How to exclude short time road blocks during navigation
                                            Herman Veldhuizenundefined
                                          • Imported POI files visible in App
                                          • Onbegrijpelijke omweg
                                            Lex.Kloet.RXundefined
                                            Lex.Kloet.RX
                                          • Routeoptie wordt niet meegenomen
                                            Axel Härtlundefined
                                            Axel Härtl
                                          • Geen routeberekening
                                          • DMD - T865x + BMW sync box + bedienen MRA met Wonderwiel
                                            PieterH_GSundefined
                                            PieterH_GS
                                          • Routepunt overslaan werkt niet correct?
                                            reinier.beenengmail.comundefined
                                          • Geen notificatie bij uitnodiging evenement
