  4. Offline maps on SD card manage too difficult
8 Posts 3 Posters 1.7k Views 2 Watching
  • Corrado Miniati 0
    Corrado Miniati 0
    Corrado Miniati 0
    Hi everybody,
    offline maps stored on the device's SD card often don't work and the app freezes, while if I store the offline maps on the internal memory everything works better, why?
    Best Regards
    • Corrado Miniati 0 Corrado Miniati 0
      Hi everybody,
      Best Regards
      @Corrado-Miniati-0
      Maybe the reading speed of the sd-card?
      Corrado Miniati 0 1 Reply Last reply
        @Corrado-Miniati-0
        Corrado Miniati 0
        Corrado Miniati 0
        Corrado Miniati 0
        @Hans-van-de-Ven-MRA-Master
        Hi Hans,
        maybe, I have a Samsung SD card 128 GB, U3 until 100 MB/s.
          Hi Hans,
          @Corrado-Miniati-0
          That should work
            @Corrado-Miniati-0
            That should work
            Corrado Miniati 0
            Corrado Miniati 0
            Corrado Miniati 0
            yes it should but it isnt happend
              @Corrado-Miniati-0, SD card performance is very dependent on the device it is being used in. What phone are you using? Also the mechanical pressure on the contacts can fail easily under motorcycle vibrations if the SD card slider is a bit worn. Besides that, SD memory will never be as performant as the internal storage. If at all possible, I would try to avoid the use of an SD card. That has nothing to do with the app, but everything with the extra problem-sensitivity you add with it.
                Corrado Miniati 0
                Corrado Miniati 0
                Corrado Miniati 0
                Hi Con, thanks for the feedback.
                I'm using the Samsung Tab Active 3, now I have tranfer the maps into internal memory and the app funcions better.
                  @Corrado-Miniati-0, great! You're welcome.
                  Corrado Miniati 0
                  Corrado Miniati 0
                  • Help please, new user
                    Bull Tahr
                    Bull Tahr
                  • My Routeapp Stays questions
                  • MRA 6.0.0 (515) Live Tracking - What exactly is shared?
