  3. [App-Beta] Announcements
  4. New Beta! (v4.0.6)
New Beta! (v4.0.6)
42 Posts 11 Posters 687 Views 4 Watching
  • Arno 0 Arno 0
    Today, I tested again the same route to and from the Office. I took care that I only used my mobile connection to both start and drive the route. The test was successful and I did not encounter any problems with constantly switching between online and offline modes and route calculations etc. So it seems important to not use different internet connections for starting and driving your routes.
    @Arno-0, Thank you! I know it is asking a lot, but it would be great to see if this is really structural. So if you have the chance, repeat the test a few times, to deduct if it is really only happening when you started the route on wifi. I am doing the same thing, and it certainly looks that way.
      @Con-Hennekens I've done the same thing. When starting a route being connected to my home WiFi network the same problems occur.
      Your explanation could be the cause of the problem. When starting a route in gsm mode no problems. It seems to me that the problem only occurs when starting an A to B route and not with a planned trip
      I' ve posted a couple times with the same problem
      Hope the team can find a solution
      Arno 0 MotoCon 2 Replies Last reply
        Arno 0
        Arno 0
        Arno 0
        @Marinus-van-Deudekom I only checked it for planned routes and not for A-B routing. You say "it seems to me" but did you really test it or is it only a thought?
          @Marinus-van-Deudekom said in New Beta! (v4.0.6):
          Well, I am experiencing this with planned routes too. Direct routes I have not tried 😉 So it definitely is not limited to direct routes.
          • Arno 0 Arno 0
            @Arno-0 with a planned route I didn’t have the problem. With A B routes I had problems. Since You and @Con-Hennekens both had the problems with a planned route we’re Back to square one with thinking it has something to do with starting with WiFi connections.
            Still hoping for a fix by thé team
              Arno 0
              Arno 0
              Arno 0
              @Marinus-van-Deudekom I will test next week with an A-B route. Start the route with a WiFi connection and then see what happens when I’m driving the rout using my mobile connection.
                @Marinus-van-Deudekom, I don't see why we are back to square one. If a problem arises when switching networks, why would that only affect direct-routes or only multi-waypoints routes? In both cases, in online mode, data traffic will be generated by the app. So we are definitely not back to square one 😉
                • Arno 0 Arno 0
                  @Arno-0 said in New Beta! (v4.0.6):
                  If you do that, and nothing happens, try a detour, forcing the app to recalculate. Do that on online mode of course. Thank for your cooperation.
                    @Con-Hennekens what I meant was that we’re Closer to vinding the sollution
                      @Con-Hennekens tried that but that wasn’t thé answer. Will keep on trying
                      Arno 0
                      Arno 0
                      • Hide warnings on the map
                      • Map Layers
                        Martin White
                        Martin White
                        Michael 2v
                        Michael 2v
                      • Bollard trouble
