  4. pop-up <Move-Save as-Delete> doesn't show (solved)
30 Posts 7 Posters 16.6k Views 2 Watching
  • TorqueRider TorqueRider
    @Rob-Verhoeff
    Thank you for your response.
    I didn't email Apple. It was an MRA service ticket.
    And I don't want to use any other browser than Safari because as far as I'm concerned it's a good and safe browser.
    It is up to the developer to make the application function browser independently. And I know that's difficult.
    @Jack-van-Tilburg said in pop-up <Move-Save as-Delete> doesn't show:
    Okay, hoping MRA solves it for us... 😉
    A bit offtopic: I use Firefox now as a crossplatform browser with all my favorites at hand. And it has some nice plugin's. Regarding safety, I think all "major" browsers have that in order.
    Drabslab 1 Reply Last reply
      Who recognizes this and knows the solution?
      When using the checkbox to select multiple items in the personal library for an action <Move|Save as|Delete>, a pop-up will appear to activate that action.
      On my iPad (7th gen), iPadOS 17.03 and on my MacBook (M1Pro) with MacOs Sonoma 14.0 in combination with Safari 17.0, the Pop-up flashes but disappears in a fraction of a second and cannot be used. I have set all settings in Safari for additional functions for Myrouteapp to "Allow". Without exception.
      When using Firefox I do not have this issue. But I want to use Safari exclusively.
      @Jack-van-Tilburg I just checked in Safari and unfortunately I cannot see what the issue possibly could be 🙂
      Everything works as expected based on my tests but obviously this isn't the case. I'll try again on a different device later on.
        Maybe this will help.
        https://youtu.be/cOEGPExqgTU
        By clicking on a folder, the box just flashes and disappears.
        MotoCon TorqueRider 2 Replies Last reply
          @Jörgen said in pop-up <Move-Save as-Delete> doesn't show:
          The video seems to be private, I can't watch it.
          It's up to the developer of a browser to make it compliant too. All software contains bugs. It's too easy pointing only at MRA, while Safari seems to be the only browser having this problem. Although of course it still may be an MRA bug, it is as easy to point it to the Safari browser.
          Jörgen TorqueRider 2 Replies Last reply
            @Con-Hennekens please try again: https://youtu.be/cOEGPExqgTU
              @Jack-van-Tilburg Same issue here (latest software versions): when selecting an item, the actions box pops up very briefly.
              I've looked into the code a bit, stepping through it in the debugger, and I've noticed the pop-up becomes visible when, on line 473 of base.js, the CSS class "in" is added to the ".explorer-selectedactions" block. However, it immediately becomes invisible again as well, when stepping over this line. I can only assume a different part of the code reacts to the addition of the "in" class and changes the CSS to make the pop-up invisible, or perhaps the z-index isn't handled correctly by Apple. The "in" class is on the box when inspecting the element.
              Just noticed it also popups very briefly when deselecting a previously selected row.
              It only happens when selecting the first (or deselecting the last) item.
              Rob Verhoeff TorqueRider 2 Replies Last reply
              • TorqueRider
                I can’n answer now. Because I am on tour with friends
                  @Herko-ter-Horst perhaps Safari is more strict in the handling of those pop-ups then other browsers do?
                  Herko ter Horst TorqueRider 2 Replies Last reply
                    @Rob-Verhoeff If so, that has to be a very recent development (worked just fine last time I checked). And I would expect to see some error message in that case. Also, it isn't really a "pop-up" pop-up as far as I can see.
                      @Rob-Verhoeff said in pop-up <Move-Save as-Delete> doesn't show:
                      You think that Google spyware is safe?
                      https://www.forbes.com/sites/zakdoffman/2021/03/20/stop-using-google-chrome-on-apple-iphone-12-pro-max-ipad-and-macbook-pro/?sh=69a169514d08
                      https://www.bleepingcomputer.com/news/security/chrome-use-subject-to-restrictions-in-dutch-schools-over-data-security-concerns/
                      MotoCon Rob Verhoeff 2 Replies Last reply
                      • Drabslab Drabslab
                        @Drabslab, Apple warning for data gathering by Google is rather funny, don't you think? 🤣
                          Yes, a typical example of a kettle accusing the pot from being black.
                          But it remains a fact that the majority of concerns expressed by governments on privacy, security and spying on users are about two compnaies with Google being one of them.
                          • Drabslab Drabslab
                            @Drabslab, certainly true, but I think it's about more than 2 companies. Apple, Google, Microsoft, Meta and many many more companies are no popes in the subject.
                            Drabslab 2 Replies Last reply
                              there is a main difference:
                              • Users are clients in the case of Microsoft, and Apple,
                              • they are the product sold to other companies in case of Google and Facebook
                                and there is a difference between "not being a pope" and being fined 8.3 billion euro for slightly illegal activities 🙂 🙂 🙂
                                • Drabslab Drabslab
                                  #22
                                  @Drabslab, I believe Apple is still subject to a 39 billion fine... 😉
                                  Oh, and do you really think Apple does NOT sell off bigdata? Users are clients indeed, AND the product at the same time. I am not downplaying the privacy problems. But don't pin them just on Google and Facebook. The other are equally evil...
                                    @Con-Hennekens said in pop-up <Move-Save as-Delete> doesn't show:
                                    turn to the dark side.... we have coockies 🙂
                                      @Jörgen
                                      Yep. That's what it actually looks like.
                                      Big thanks for this video!
                                        @Herko-ter-Horst said in pop-up <Move-Save as-Delete> doesn't show:
                                        This is beyond my knowledge 🙂
                                        But hopefully the technicians can do something with it 👍
                                          That's definitely true. But Safari also offers the option to cancel the pop-up blocker in the settings.
                                          • Online map settings
                                            MartinW
                                            MartinW
                                          • Real-time traffic
                                            Òscar
                                            Òscar
                                            Andy Nicholson
                                            Andy Nicholson
                                          • HERE map not calibrated
                                            MartinW
                                            MartinW
                                          • Myrouteappstay
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Navigatie met DMD tablet
                                          • Show on the maps's button
