  4. Length of 'text to speech' function
22 Posts 7 Posters 5.7k Views 2 Watching
  • motorwimtimmerman.euundefined Offline
    The new 'text to speech' function is great. On a VIA point, you change the Text on the route point in anything you want. Like: the next point gives you a great view on the lake'. Text could be anything but shall not contain numbers. So no 7 but if you want to have it in, make it 'seven'.
    However, it does not speak out the whole text I have entered. Probably it is too long.
    Is there a restriction on the text length? And if so, how long can e sentence be.
    Hans van de Ven MR.MRAundefined Con Hennekensundefined 2 Replies Last reply
    • motorwimtimmerman.euundefined motorwimtimmerman.eu
      @WimTim
      512 characters
        @WimTim, You have the option of the WP name and the WP note. Those are two different things that both get read underway. If you only change the name it will NOT be read if there is a figure in it. It WILL get read of there is a figure in it AND there is a note present. If, like @Hans-van-de-Ven-MRA-Master says, the name can be up to 512 characters, I suppose the note is at least equally long. But hey, if you put that much text in, you will probably miss the next turn (or the text gets interrupted, don't know). 😉
          @Con-Hennekens and @WimTim
          512 characters is the note. The name is much shorter
            Rob Verhoeffundefined Offline
            @Hans-van-de-Ven-MRA-Master @Con-Hennekens I tried to fill the name of the waypoint. Stopped at 100 charchters... I wonder how long one can go on putting text in that field!
            When putting spaces in between you can go as far as 101 characters...
            Nick Carthewundefined Jack van Tilburgundefined 2 Replies Last reply
              @Rob-Verhoeff But they will not be seen in the app.
                Jack van Tilburg
                @Rob-Verhoeff said in Length of 'text to speech' function:
                As long as you don't go to Llanfairpwllgwyngyllgogerychwyrndrobwllllantysiliogogogoch, that's not that important, is it? 🤣
                Rob Verhoeffundefined Con Hennekensundefined 2 Replies Last reply
                  @Nick-Carthew that's right.
                    @Jack-van-Tilburg 😁
                      Actually it isn’t 😅 I have just tested this and the title has rolling text like the note.
                      Corjan Meijerinkundefined Rob Verhoeffundefined 2 Replies Last reply
                        @Nick-Carthew Correct! When there is no (scrolling) description / note, the title will be scrolling if required by the length of that text 🙂
                          @Nick-Carthew said in Length of 'text to speech' function:
                          Check... Indeed the textlenght scrolls by to a max of 101 charchters. I moved the first waypoint before checking. Then your given name is changed back to the original name of the waypoint.
                          Nick Carthewundefined 3 Replies Last reply
                            @Rob-Verhoeff I titled RP1 123456789 123456789 123456789
                            I can’t share the video in the forum so I added it to YouTube: https://youtube.com/shorts/PfBJa6n-x9s?si=rxDl0wAEU_1IQqa8
                              @Rob-Verhoeff Here’s the title.
                                @Nick-Carthew I did it the same way, then it show to a max of 101 characters.
                                  @Rob-Verhoeff I added 3 sets of 123456789 for the title but looking at my video it appears that only 2 sets are scrolling. There is a large gap after 2 sets.
                                    @Jack-van-Tilburg said in Length of 'text to speech' function:
                                    Thanks... Now I want to hear the navigation voice pronounce that... 😉
                                      It seems there was not much on TV yesterday evening 😉
                                        Jack van Tilburg
                                        @Con-Hennekens said in Length of 'text to speech' function:
                                        But only when you. are in that region of course. Driving via Llangollen and Betws-Y-Coed to the Yr Wyddfa 😁
                                          @Jack-van-Tilburg Using the Wales 360 RouteXpert route is a nice way to pass Llanfairpwllgwyngyllgogerychwyrndrobwllllantysilio gogogoch 😊
                                          View 'Wales 360 Bala Caernarfon Holyhead Llandudno' in MyRoute-app! https://www.myrouteapp.com/route/open/7933523
                                          Jack van Tilburg
                                          • After coffee, MRA does not continue from where we left off.
                                          • Mileage to destination versus waypoint to waypoint
                                            Eric Colón 3 0undefined
                                            Eric Colón 3 0
                                          • Route ging prima; nog wel twee wensen!
                                          • No display of current speed and linit speed after update
                                            D Griffinundefined
                                            D Griffin
                                          • MRA tijdens een trip door de Eifel
                                            Thomas Neumeyerundefined
                                            Thomas Neumeyer
                                            4.8k
                                          • volume loopt terug
                                            supergundefined
                                          • Herschikken routepunten
                                            RobdHundefined
                                            RobdH
