  4. Experience gained over 3200km with 4.0.3
5 Posts 3 Posters 951 Views
  • Kudeeundefined Offline
    Kudee
    I have driven in Slovakia, Poland, Romania, Moldavia, Transnistria and Hungary.
    App works well, I also had the already known problems like grey screen, an error occurred, route cannot be calculated, or that app simply closes. I know that they are working on it, thank you!
    The compass, I still don't understand its function but how many times have I stopped, gloves off to press the stupid compass?
    The waypoint list is very cool! I name the points and can decide whether I want to drive to the point or not.
    Battery consumption: I don't know what happens but it has completely drained my 4.5Ah battery twice. I never have any problems otherwise and the wireless charger even charges the battery in use with MRA on my P30Plus.
    Question:
    I had 9 WP set in a city I want to look at. WP2 was my hotel. So I marked WP2 and drove along other interesting streets to take photos. . Suddenly WP3 was my next destination because I didn't follow the instructions. Is this normal? It should be possible to set WP2 as the absolute destination.
    So far so good, i love this app, Thank you!
    Kudee
    Nick Carthewundefined Corjan Meijerinkundefined 2 Replies Last reply
    • Kudeeundefined Kudee
      Question:
      Kudee
      @Kudee said in Experience gained over 3200km with 4.0.3:
      The compass is for re-centring your position. The next update will automatically re-centre your position when you start moving.
      This is a known problem and has been linked to the HERE map that MRA are supplied with. The developers are working with the map suppliers to resolve this problem.
      Question:
      Using a Via point for WP2 would have solved this problem. Do you have 'Skip waypoints automatically' turned on in the navigation settings? This could have caused you to miss WP2. Via points cannot be skipped automatically.
      Always good to read positive feedback.
      Kudeeundefined 1 Reply Last reply
        Question:
        Kudee
        @Kudee thanks for sharing the experience!
        I don’t have much to add to what @Nick-Carthew said.
          Question:
          Kudee
          @Nick-Carthew said in Experience gained over 3200km with 4.0.3:
          What would fix my problem now? Just turn off skipping waypoints or set WP as Via Point point?
          Can i do that quickly on the road? Guess i need to be Online, right?
            Both should fix the problem that you had with WP2.
            You can switch off ‘Automatically skip waypoints’ when you are offline but you would need to be online to edit the route to change the waypoint to a Via point.
            Kudeeundefined
            Kudee
            • How to exclude short time road blocks during navigation
            • Routeoptie wordt niet meegenomen
              Axel Härtlundefined
              Axel Härtl
            • Onbegrijpelijke omweg
              Lex.Kloet.RXundefined
              Lex.Kloet.RX
            • Imported POI files visible in App
            • Waypoint size
            • Routepunt overslaan werkt niet correct?
              Herman Veldhuizenundefined
            • UI button contrast when highlighted
            • DMD - T865x + BMW sync box + bedienen MRA met Wonderwiel
              PieterH_GSundefined
              PieterH_GS
