  4. Low volume on voice prompts
16 Posts 8 Posters 4.1k Views 1 Watching
  • Steve Bendellundefined Offline
    Steve Bendell
    The sound app is working, needs a bit of fiddling to set it up correctly but solved this problem.
    • Wesley Moinilundefined Offline
      Wesley Moinil
      wrote on last edited by Wesley Moinil
      Personally I also find the voice prompts to soft using an Apple Device.
      Last week I was using the instructions in combination with some music.
      During the time my music was playing I noticed that the prompts were to soft to overcome the music.
      Maybe there could be an option to pause the music during instruction instead of just lowering the volume?
      Lluis Arasanzundefined 1 Reply Last reply
      • Wesley Moinilundefined Wesley Moinil
        Hi!,
        I also confirm that volume on iPhone is too low even setting volume on MyRoute- App as "full".
        If I'm hearing music, is almost impossible to interpretate audio guidelines from app.
        If app can low audio output for other apps, will be a good idea (as Amigo, Tomtom, etc.)
        I tested it on 2 iphones with same behavior.
        • BMW F750GS
        • Lluis Arasanzundefined Lluis Arasanz
          Hi!,
          @Lluis-Arasanz update for next week has different audio channel configurations for iOS which will most likely solve the issues.
          Marinus van Deudekomundefined Lluis Arasanzundefined 2 Replies Last reply
            @Corjan-Meijerink Will the update contain improvements for Android as well
              Perfect!!!! I'm waiting for it ... πŸ‘ πŸ‘ πŸ‘ 😊
              • BMW F750GS
                @Marinus-van-Deudekom yes. But what exactly are you referring too? πŸ™‚
                • richtea999undefined Offline
                  Corjan has probably already solved it in the next beta, but just in case, here's what we found on a recent trip:
                  • changing the volume control whilst MRA is speaking increases the volume as expected
                  That was on Android
                  Possible reason (with my highlight):
                  https://developer.android.com/guide/topics/media/platform/output
                  By default, pressing the volume control modifies the volume of the active audio stream. If your app isn't currently playing anything, hitting the volume keys adjusts the music volume (or the ringer volume before Android 9).
                  Hope that may be of use.
                    That was on Android
                    Con Hennekensundefined Online
                    @richtea999, yes, but nav voice and music are the same stream. So if you up the voice you up the music too. There does not seem to be a seperate audiochannel voor speech on Android 😠 I guess we are gonna have to stalk Google about that...
                      @Corjan-Meijerink it would be a great step forward if we could start MRA when Android radio is already running. For me it is impossible to start it while Android radio is already running. ThΓ© only way that I can get MRA running in thΓ© car is to start MRA first and then start my car and as a result Android radio
                        @Marinus-van-Deudekom yes, we are working on that now! πŸ™‚
                        Next update will have some minor improvements that hopefully solve some issues people have but we are deep diving into the matter now.
                          @Corjan-Meijerink πŸ‘πŸ˜
                          • Jack van Tilburgundefined Jack van Tilburg referenced this topic on
                          richtea999undefined
                          D A Wakefieldundefined
                          D A Wakefield
                          Wesley Moinil
                          Steve Bendell
                            Nomko Nomdenundefined
                            Nomko Nomden
                          • A to B Routing incorrect behavior
                            Herman Veldhuizenundefined
                          • Kan mijn track op de HERE kaart niet gelijk krijgen met TomTom kaart.
                            Nomko Nomden
                          • Here kaart
                          • Geen notificatie bij uitnodiging evenement
                          • Routepunt overslaan werkt niet correct?
                          • DMD - T865x + BMW sync box + bedienen MRA met Wonderwiel
                            PieterH_GSundefined
                            PieterH_GS
