  4. Skipping shaping points automatically
21 Posts 8 Posters 13.0k Views 3 Watching
  • MartinW MartinW
    @Rob-Verhoeff
    ok, got it!
    This also explains my situation today:
    I briefly deviated from the planned route (black), as can be seen in the track log (yellow, red circle). During the recalculation, shaping points 12 and 13 were skipped.
    However, I had not noticed that the route was recalculated several times, which probably happened too quickly on the short stretch 🙂 But now it is clear.
    @Martin-Wilcke Make WP 12, 13, next time a Via-Point, that will not be skipped.
    I had a similar situation in Frankfurt, I had to pick up something before the Hotel, for some reason (traffic, or?) the pickup Shaping point was skipped, and I was guided direct to the Hotel. Next time I will make it a Via-Point to prevent this.
      @Jörgen, that is exactly the purpose of VIA points: Waypoints that you don't want to auto-skip, no matter what 😉
      MartinW 1 Reply Last reply
        MartinW
        MartinW
        MartinW
        @Con-Hennekens @Jörgen :
        I absolutely agree with you about the different meaning of via and shaping points. I also like the algorithm according to which shaping points are automatically skipped.
        In this specific case, of course, I didn't want to skip route points 12 and 13, and the interesting question is how to prevent this.
        I looked at a few routes from the MRA library to get an understanding of whether there is a kind of "standard" for dealing with route points that relate to POIs / favourites or should otherwise be given a special meaning. It seems that such route points (in addition to being coloured other than blue) are then set as via points if the author recommends a "mandatory" stop here. However, if it is more of an "opportunity", a shaping point is set. From my point of view, this approach is correct and good and I have adopted it in the same way when creating my own routes.
        That is why I would not set one of the points 12/13 as a viapoint (because they are "opportunities"), but instead add another (blue) shaping point and/or move point 14 a little. What do you think about this?
        In any case, it is good to know that with such loops in a route, a "shortcut" can arise in the event of an auto skip, which one may not want at all.
        • MartinW MartinW
          @Martin-Wilcke
          Here’s how I would do it:
          MartinW RetiredWingMan 2 Replies Last reply
            @Martin-Wilcke
            MartinW
            MartinW
            MartinW
            @Nick-Carthew said in Skipping shaping points automatically:
            I would add a pink via point with a note...
            A clever solution!
            Do you really mean via point? Not shaping point?
            • MartinW MartinW
              A clever solution!
              @Martin-Wilcke yes, a via point to ensure that you have the option to visit to 12/13.
                @Martin-Wilcke
                @Nick-Carthew if you add a pink viapoint with a message, how do you display the message during navigation?
                  MartinW
                  MartinW
                  MartinW
                  Right, that makes sense. Via point simply means "pass here" but not necessarily "stop (have a break) here".
                    @Doug-Robinson said in Skipping shaping points automatically:
                    In the app while navigating: shortly press the viapoint. Then you will see the text you typed in the viapoint-menu under 'Note'. When you added a photo, it will also apear.
                      @Rob-Verhoeff @Doug-Robinson
                      No need to long press the route point if you select the option in Screen layout to show waypoint information. The information that you have added is displayed as scrolling text as you navigate.
                      Rob Verhoeff RetiredWingMan 2 Replies Last reply
                        You're right, but that takes forever when you have a long text! Simply press SHORT (not long, because that skips the waypoint 😉
                        The text will be presented in a textbox on the bottom of your screen. In CP the extra text presents itself on the left of the screen (in my car).
                          @Nick-Carthew thanks for the info, I was not aware of that recent change. The app is starting to get very complicated with all these features and options.
                          MartinW
                          MartinW
                          Marco 7v
                          Marco 7v
                          nano
                          nano
                          • Kaart niet zichtbaar
                          • Trains like Ferries?
                            Corrado Miniati 0
                            Corrado Miniati 0
                          • Xpert overlay not clear
                          • MyRoute-app Studio
                            Robbo
                            Robbo
                            Bé Jeuring
                            Bé Jeuring
                            Corrado Miniati 0
                            Corrado Miniati 0
