  4. Position Error
Position Error
34 Posts 11 Posters 443 Views 4 Watching
  • Dave J 0 Dave J 0
    Hi @StefanHummelink @Stuart-Greer I have been using Flitsmeister in the background previously when running the MRA app on Android and I thought I would check your observations about improved position and less lag. I was running the iOS version alongside on CatPlay to compare and it does appear to significantly improve the lag issue. Whereas I had previously observed about a 4 second lag, the location appears to be spot on and the same compared with iOS when Flitsmeister is running in the background.
    Useful to get @Corjan-Meijerink view on this.
    @Dave-J-0 Oh nice you also came along to check upon this! Thanks! This surely helps 😃
    I'm happy to see the observations by you are identical. That makes two of us and it means I am not a loner hahah!
    Dave J 0 1 Reply Last reply
      @StefanHummelink could not leave you as a loner. Ha ha
      Ducati Multistrada V4 Rally
      iPhone 18 Pro
      CHIGEE AIO-6 LTE
        @Stuart-Greer Great, I am very curious!
        If you're phone supports split screen, you could really run the apps in parallel. Perhaps make a screen recording to see whether the track line in relation to the cursor changes. In my case I can observe a very distinct change when it comes to the track line relative to the cursor. 😃
        Stuart Greer
        Stuart Greer
        Stuart Greer
        @StefanHummelink hi Stephan, as per your suggestion I ran both apps in split screen this morning on a run into Glasgow City centre and it was perfect. I had it zoomed in to the max and it was as good as any sat nav.
        Thanks for your help
          This is all very interesting indeed!
          My testing device for Android has no other apps installed that use location services - only MRA.
          My positioning is spot on like with iOS or your observation with another app running.
          We will definitely use these findings to further investigate 🙂
          Stuart Greer
          Stuart Greer
          Stuart Greer
          @Corjan-Meijerink excellent, the app is really good and getting better and better.
          Looking forward to the camper functionality in the future
          • Dave J 0
            @StefanHummelink @Stuart-Greer Just done some more testing this morning and you really notice the difference and lag (especially when turning) after Flitsmeister running in the background is closed. Turned Flitsmeister off and on multiple times during a route to double check what we are seeing. Really strange but with Flitsmeister on in the background, the position is spot on and direction changes quick.
            iPhone 18 Pro
            CHIGEE AIO-6 LTE
            • Dave J 0 Dave J 0
              @Dave-J-0 @Stuart-Greer Woa, thanks a lot guys!
              This may help @Corjan-Meijerink in solving the issue. Let's cross our fingers and put all our money on him. 😃
                @StefanHummelink Where can I share my bank details with you? I'd more than happy carry all your money 😃
                Stefan Hummelink Rob Verhoeff 2 Replies Last reply
                  @Corjan-Meijerink I don't own my money, my wife does. 😃
                    Ah, good to know that I am not alone. My Minister of Finance also has the total control. 😂
                    • MotoCon
                      It's about time we MEN stand up for ourselves and become financially independent of our wives!
                      Nick Carthew Stefan Hummelink 2 Replies Last reply
                        @Con-Hennekens said in Position Error:
                        You go first and we’ll look at the consequences 😀
                        Bart De Medts MotoCon 2 Replies Last reply
                          @Nick-Carthew very good suggestion 😄
                            @Con-Hennekens As @Nick-Carthew already said, put your money where your mouth is! 😃
                              @Nick-Carthew, hmmm. long way to go I see 🤣
                                @Corjan-Meijerink said in Position Error:
                                Carry it? Call me when I can spend it! 😜
                                • Stuart Greer Stuart Greer
                                  Samsung S22+ Android 13
                                  Updated to the new version which I think is really good and a huge step forward .
                                  The zoom feature is superb
                                  The position error is still there and I calculated that the map lags my actual position by between 100 and 120m. I missed a few turnings as a result of this.
                                  #31
                                  @Stuart-Greer
                                  For comparison of different Samsung Phones regarding the position lag.
                                  The video below shows my Galaxy S21+ 5G.
                                  Build is 4.0.0, I will record the same video when 4.0.1 is available for Android.
                                  Excuse the wind noise from the GoPro as I wanted to get some Tiger loveliness in the Audio.
                                  The syncing of the GoPro and the S21+ inbuilt Screen Recording was synced as best I could at the first turn for the Screen Recording and the GoPro.
                                  Android 13
                                  Screen Brightness 50%
                                  OneUI 5.1
                                  Power Source 2.1 Amp Dual Port Din (Only one port ever used)
                                  Quad Lock Wireless and Dampener mounted on a 1” Ball so I can easily remove it when out and about and put it in the Back Box.
                                  I never login to the Samsung Account on my Android Phones and avoid Bixby at all costs.
                                  Video is realtime.
                                  Video Link:
                                  https://youtu.be/-azFCa3G8kY
                                  Stefan Hummelink Stuart Greer 2 Replies Last reply
                                  • Lynchy67 Lynchy67
                                    @Stuart-Greer
                                    Android 13
                                    OneUI 5.1
                                    Video is realtime.
                                    Video Link:
                                    @Lynchy67 Well, yours is truly spot on! I'm seriously jealous. Gosh!
                                    • Lynchy67 Lynchy67
                                      @Stuart-Greer
                                      Android 13
                                      OneUI 5.1
                                      Video is realtime.
                                      Video Link:
                                      Stuart Greer
                                      Stuart Greer
                                      Stuart Greer
                                      @Lynchy67 that seemed to work really well, nice bike. I tried the new Tiger earlier this year and really liked it
                                      • Dave J 0
                                        @Lynchy67 Nice run and your GPS is spot on. Mine is only like that with Flismeister running in the background. 🤣 Nice bike as well.
                                        iPhone 18 Pro
                                        CHIGEE AIO-6 LTE
                                        bert74
                                        bert74
                                        Stuart Greer
                                        Stuart Greer
                                          Rene van Maanen
                                          Rene van Maanen
                                        • One crash today
                                          Mosimann
                                          Mosimann
                                        • Download club route folders
